Question about Janome DC3050 Computerized Sewing Machine
RETURN MY MACHINE TO FACTORY SETTINGS
NOTHING
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 120 Answers
I could not find any "reset" information on this machine. It would likely be in a service manual which are hard to find free. The Janome website has some online support but they basically state to contact a local distributor.
Posted on Nov 30, 2014
I don't have a manual what are the tension for this machine
Difficult to address without knowing the make & model.
However, generally speaking, the standard factory setting for the upper tension is the midway point between the high & low numbers.
Bobbin tension is set at the factory and is tricky to reset by a novice. For the most part, it is recommended that the tension skrew setting on the bobbin case be marked with a permanent marker before any changes are made. That gives a reference point so that if it needs to be returned to the original setting, it is easier to do so. Make only 1/8 turns at a time and retest.
The correct tension is when the upper and bobbin threads meet in the middle of the fabric.
Keep in mind that the needle, thread, and fabric all impact tension. Before beginning a new project, test the tension first on a scrap of the fabric and get it set where you want it before sewing the project. That being said, tension (mostly upper thread) is static so it is important to get familiar with adjusting it to fit your project. One tension setting will usually not work for every project.
Apr 01, 2016 | Sewing Machines
Janome 11000
I'm guessing here but you might need to calibrate the touch screen or possibly a circuit board has moved inside the machine. I don't know if you can reboot the machine or return it to factory settings which might reset everything. Failing all of that I'd be asking a computer/phone repair place to look at it.
Apr 23, 2013 | Sewing Machines
Model 7467. bought in april and it was working. now top and bottom threads will not form "stich". it is threaded correctly! took off face plate - nothing jamming up. machine made a clunking noise...
try changing the needle
check the top thread tension
check to make sure the bobbin is inserted in the bobbin case correctly
check to make sure the bobbin case is correctly inserted into machine
Sep 30, 2010 | Singer Confidence 7467 Mechanical Sewing...
Bobbin knotting & jamming on Singer 2250
Put the tensions back to the factory setting.
Re-thread the machine with the presser foot up and make sure the bobbin thread is feeding from the bobbin in the correct direction and through the proper guides.
Change the needle to one that is new and appropriate for the type of sewing that is being done.
If problem continues take the machine back for assistance if you purchased it from a sewing machine dealer. They usually do not take "returns".
Or, back to the store that it was purchased from if not from a dealer. You may have a limited time in which it can be returned.
Apr 18, 2010 | Singer 2250 Tradition
Bottom thread loops
More than likely the Bobbin is not threaded correctly and the tension is not being controlled.  review the manual carefully, pay attention to the direction the thread is wound on the bobbin and place it in the case exactly as illustrated, feed the thread through the tension groove.
I would also advise returning to the bobbin to the factory setting and leave it there.
Jan 01, 2009 | Singer 3116 Simple
My kenmore sewing machine bottom tension is not tight can you help?
The bottom tension is set in the factory and should not be changed. Take it to a service technician and get them to fix it for you.
Oct 23, 2008 | Sewing Machines
Tension factory settings for Baby Lock serger Model BL400
The factory settings are 4, 4, 4, 4, and width at M. Hope this helps.
Mar 03, 2008 | Baby Lock Eclipse Serger
Problem with trac feeds
When you drop the feed dogs on most modern machines they do not return to the up position until the motor rotates one full turn. Your feed dog will then be up and ready to use.
Dec 28, 2007 | Sewing Machines
Janome DC3050 Computerized Sewing Machine Logo
106 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
