Question about Clymer Evinrude/Johnson 2-40 HP Outboards Includes Electric Motors 1973-1990 - B732
We replaced the water pump on a 1990 Evinrude 25 hp motor, but it isn't working. Can you help us?
We replaced the water pump on our Evinrude 25 hp outboard motor with a new one, but it is not working.
    Champion:
  • 254 Answers
It may look easy in the book but there are a few things that can go out. Such as the key/roll pin that drives the impeller can slip out on assembly. Water tube out of hole or damaged OR pieces of old impeller in it depending on why you needed to replace it. There are more but if you are not a trained tech it may be time to find one.
Posted on Dec 13, 2014
I have a 1973 evinrude 25 hp motor that does not circulate water through. I took out the water pump and the rubber propeller is in good shape.Any other ideas?
look at the prop part closely
see if the water flushes fully through the block without the pump fitted
seals
blocked gauze/water pick up fouled
i know these corrode even with the best of flushing
make sure the pump drive shaft is spinning with the base of the motor sometimes the shaft spline will splinter or break
Aug 04, 2016 | Boating
Does motor on 1975 25 horse evinrude have to be in gear for water pump to work
The water pump HAS to be working whenever the motor is started. You'll burn you water pump impeller out very quickly if it isn't.
Jun 28, 2014 | Boating
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
Can't get 1976 evinrude 6hp to pump water I changed water pump
have you changed the impeller inside the lower unit.
There is copper pipe to redirect water up into the engine.
When you replaced the impeller make the copper pipe is insert onto the engine.
Jul 31, 2012 | Light Outboard Motor Boat Bass Fishing...
1997 50 hp Evinrude won't fire
Take off the top & expose the magneto clean with a fine grit sandpaper that should get fire to the plugs if still no fire u may have.to replace the points
Jul 23, 2012 | Boating
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
Where does the water exit a 1971 25 hp evinrude? how do I know it's pumping water?
I do believe the water jets are down on the lower unit by the prop. There should be a white swirl of white bubbles shooting out.
Apr 16, 2010 | Light Outboard Motor Boat Bass Fishing...
1991 EVINRUDE 25 HP 2CYL 2CYCLE IT RUNS ON BOTTOM
get a spark tester that has 2 leads and test spark .
Jan 26, 2010 | Light Outboard Motor Boat Bass Fishing...
1977 115 hp evinrude outboard water pump problem
Depending on the year motor, make sure the throttle is in the neutral position, drop the lower unit and the motor foot should come off, will probably take some wiggling and with the age of the motor, possibly a few light taps around the cavitation plate with a mallet would be helpful.
Mar 28, 2009 | Boating
Clymer Evinrude/Johnson 2-40 HP Outboards Includes Electric Motors 1973-1990 - B732 Logo
258 people viewed this question
Top Clymer Boating Experts
Fabrice Wolters
Colin Stickland
Colin Stickland
Are you a Clymer Boating Expert? Answer questions, earn points and help others
