My viewsonic lapgop is a blsck screen with administrator system32.at top an asking for x;files whay do i type n the soirce?
System32 drivers ntfs sys
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows XP startup disks or the Windows XP CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows XP installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command):
  6. --->cd \windows\system32\drivers
    --->ren ntfs.sys ntfs.old
    Note This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  7. At the command prompt, type the following command, and then press ENTER:copy cd:\i386\ntfs.sys drive:\windows\system32\drivers
    Where cd is the drive letter for the CD-ROM drive that contains the Windows XP CD, and drive is the drive where you installed Windows XP.
  8. Remove the Windows XP CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  9. Restart the computer.
May 17, 2014 | eMachines Computers & Internet
Tip
Hack windows
Here are the steps involved to <b>Hack</b> the <b>Window XP Administrator Password</b> .<br /> <ol> <li>Go to <b>Start</b> -&gt; <b>Run</b> -&gt; Type in <b>CMD</b></li> <li>You will get a command prompt. Enter these commands the way it is given</li> <li>cd\</li> <li>cd\ windows\system32</li> <li>mkdir temphack</li> <li>copy logon.scr temphack\logon.scr</li> <li>copy cmd.exe temphack\cmd.exe</li> <li>del logon.scr</li> <li>rename cmd.exe logon.scr</li> <li>exit</li></ol> Wait its not over read the rest to find out how to <b>Hack</b> the <b>Window XP Administrator Password</b><br /> A Brief explanation of what you are currently doing here is<br /> Your are nagivating to the windows system Directory where the system files are stored. Next your creating a temporary directory called <b>mkdir. </b>After which you are copying or backing up the <b>logon.scr</b> and<b> cmd.exe</b> files into the <b>mkdir</b> then you are deleting the <b>logon.scr</b> file and renaming <b>cmd.exe</b> file to <b>logon.scr</b>.<br /> So basically you are telling windows is to backup the command program and the screen saver file. Then we edited the settings so when windows loads the screen saver, we will get an <b>unprotected dos prompt without logging in</b>. When this appears enter this command<br /> <b>net user password</b><br /> Example: If the admin user name is clazh and you want change the password to pass Then type in the following command<br /> <b>net user clazh pass</b><br /> This will chang the admin password to pass.<br /> Thats it you have sucessfully <b>hacked</b> the <b>Window XP Administrator Password</b> now you can Log in, using the <b>hacked</b> <b>Window XP Administrator Password</b> and do whatever you want to do.<br /> Here are the steps involved to De <b>Hack</b> or restore the <b>Window XP Administrator Password </b>to cover your tracks.<br /> <ol> <li>Go to <b>Start</b> -&gt; <b>Run</b> -&gt; Type in <b>CMD</b></li> <li>You will get a command prompt. Enter these commands the way it is given</li> <li>cd\</li> <li>cd\ windows\system32\temphack</li> <li>copy logon.scr C:\windows\system32\logon.scr</li> <li>copy cmd.exe C:\windows\system32\cmd.exe</li> <li>exit</li></ol> Or simply go to C:\windows\system32\temphack and copy the contents of temphack back into system32 directory click <b>Yes </b>to overwrite the modified files.<br />
on Dec 24, 2010 | Computers & Internet
Tip
How to Recover Windows 2000 Password
Forgot administrator password on a system running Windows 2000 can be problematic when the administrator to perform maintenance. There is a trick that allows a computer user to reset his password, if you forgot. The process to recover a password in Windows 2003 and XP is different from the process used for Windows NT and Windows 2000.
Step 1. Insert the installation CD of Windows 2000 / DVD into the drive of the computer and then restart the computer.
Step 2. Select the destination directory for the alternative Windows operating system when the program asks you to do. This directory is not the same as the default installation of Windows. This is the computer is a dual-boot system.
Step 3. When the computer restarts, select the alternate Windows installation from the dual-boot menu.
Step 4. Find the logon.scr file. It should be located in the %systemroot%\System32 folder of the Windows folder.
Step 5. Rename logon.scr and move it into the C: folder of the hard drive. You can choose to move it to a different directory. The important thing is to remember where the file gets copied.
Step 6. Find cmd.exe and make a copy of it in the %systemroot%\System32 folder. Move this file to the C: folder of your hard drive.
Step 7. Right-click on the original cmd.exe file and select "Rename." Delete the cmd.exe text and replace it with logon.scr.
Step 8. Restart the computer and start Windows installation. Do not touch the computer until the start of the screensaver. Since the screen saver file, get the default is replaced with the file cmd.exe, then a command prompt instead of the screen saver.
Step 9. At this prompt type: net user administrator <password>
Step 10. Delete logon.scr from the %systemroot%\system32 folder.
Step 11. Issue the following commands from the command prompt:
copy c:\logon.scr c:\windows\%systemroot\system32
copy c:\cmd.exe c:\windows\%systemroot\system 32
Step 12. Restart the computer in the original. From here you can remove the additional installation if desired. If the administrator installation alternatives are on a different drive or partition to reformat the hard disk or partition is the easiest way to achieve this goal.
on Apr 26, 2010 | Computers & Internet
I forgot my password and I can only log in as a guest
You can try the below given steps to reset administrator password using guest account (you must have write access to system32 file):
1. Navigate to location C:/windows/system32
2. Copy cmd.exe file to desktop and rename it to sethc.exe
3. Now copy this sethc.exe file and paste to system 32 (when windows asks for overwriting click yes).
4. Log out from guest account and at user login screen press shift key 5 times.
5. It will open command prompt with full administrator privileges.
6. Now type "NET USER ADMINISTRATOR xyz123" (where "xyz123" can be any password according to your choice) and press enter.
7. You will see "The Command completed successfully" and then exit the command prompt and login into administrator with your new password.
If you don't have write access to system32 file then you can use stellar phoenix password recovery software to reset administrator password.
Nov 12, 2012 | Computers & Internet
User password
Resetting Your Forgotten Windows Password
Boot off the Windows disk and select the "Repair your computer" option from the lower left-hand corner.
Follow through until you get to the option to open the Command Prompt, which you'll want to select.
First you'll want to type in the following command to backup the original sticky keys file:
copy c:\windows\system32\sethc.exe c:\
Then you'll copy the command prompt executable (cmd.exe) over top of the sticky keys executable:
copy c:\windows\system32\cmd.exe c:\windows\system32\sethc.exe
Resetting the Password
Once you get to the login screen, hit the Shift key 5 times, and you'll see an administrator mode command prompt.
Now to reset the password-just type the following command, replacing the username and password with the combination you want:
net user geek MyNewPassword
That's all there is to it. Now you can login.
Of course, you'll probably want to put the original sethc.exe file back, which you can do by rebooting into the installation CD, opening the command prompt, and copying the c:\sethc.exe file back to c:\windows\system32\sethc.exe.
source: http://www.howtogeek.com/?post_type=post&p=96630
Jul 14, 2012 | Toshiba Satellite A205-S5803 Notebook
File:\windows\system32\config\system file is missing or corrupt laptop : sony vaio
boot you computer using OS CD and at first screen use recovery console command prompt
at command prompt
wait for 10 second and the enter your administrator password
then go to c:\windows\system32\repair
the type copy system c:\windows\system32\config
press y to overright file
and restart your computer
Nov 23, 2010 | Computers & Internet
Netio.sys vista error 0xc0000221
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue, and then replace the file. To do this, follow these steps:
  1. Open an elevated command prompt. To do this, click Start, click All Programs, click Accessories, right-click Command Prompt, and then click Run as administrator. If you are prompted for an administrator password or for a confirmation, type the password, or click Allow.
  2. Type the following command, and then press ENTER: sfc /scannowThe sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
To determine which files could not be repaired by the System File Checker tool, follow these steps:
  2. Type the following command, and then press ENTER: findstr /C:"[SR] Cannot repair member file" %windir%\logs\cbs\cbs.log >sfcdetails.txtNote The Sfcdetails.txt file contains details from every time that the System File Checker tool has been run on the computer. The file includes information about files that were not repaired by the System File Checker tool. Verify the date and time entries to determine the problem files that were found the last time that you ran the System File Checker tool.
  3. Type the following command, and then press ENTER: edit sfcdetails.txtThe Sfcdetails.txt file uses the following format: Date/Time SFC detail
If the System File Checker tool cannot repair a file, follow these steps:
  1. At an elevated command prompt, type the following command, and then press ENTER: takeown /f Path_And_File_NameFor example, type takeown /f E:\windows\system32\jscript.dll.
  2. Type the following command, and then press ENTER to grant administrators full access to the file: icacls Path_And_File_Name /GRANT ADMINISTRATORS:F For example, type icacls E:\windows\system32\jscript.dll /grant administrators:F.
  3. Type the following command to replace the file with a known good copy of the file: Copy Path_And_File_Name_Of_Source_File Path_And_File_Name_Of_DestinationFor example, type copy E:\temp\jscript.dll E:\windows\system32\jscript.dll.
Aug 23, 2010 | Computers & Internet
Error prompt: \WINDOWS\system32\c_437.nls
you have a windows system file corruption on the c_437.nls file which is a national languages file required by windows to run.
repair this problem following these instructions-
1. Boot your computer from your Windows installation CD- ie-insert the CD and restart your computer.
2. Select 'R' for the recovery console and log on as administrator.
3. At the command prompt type the following:
cd system32
then press enter
4. Then type the following:
ren c_437.nls c_437.old
then press enter
EXPAND D:\I386\c_437.nl_ C:\WINDOWS\system32\c_437.nls
then press enter
(If your CD drive is different than D: or your primary hard
drive/partition is other than C:, substitute the appropriate
drive letters.)
4. Select yes when you're prompted to overwrite the existing file.
5. Reboot the computer.
Depending on the level of file corruption, you may have to repeat this
process for additional files. To do this follow the instructions above substituting the file name.
//javaftper
Aug 01, 2010 | Dell Latitude D620 Laptop (Latitude-C620)...
I am installing a recovery disk for an emachines computer and i get error message stating that the system 32hal.dll is missing or corrupt. i cant get back to the windows screen to install the missing file...
You have to start your PC with the XP cd-rom install disk, if you have
one.
Then, when you come to the screen with the following option displayed :
Recovery Console, press R.
Then press [R] to start 'Recovery Console'
When confronted by a prompt asking you for Administrator password - just
press [ENTER]
Once in RC has started - type the following command :
expand x:\i386\hal.dl_ c:\windows\system32\hal.dll
(where [x:] is your cd drive-letter)
*NB If SP3 is installed - then the command you type must be :
copy c:\windows\ServicePackFiles\i386\hal.dll c:\windows\system32
....instead, as the files are of two different revision levels
(versions).
Then reboot.
Oct 28, 2009 | E-Machines T5212 PC Desktop
Hp paviliondv2050us wont start
To complete part one, follow these steps:
  1. Insert the Windows XP startup disk into the floppy disk drive, or insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
    Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted to do so.
  2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
  3. If you have a dual-boot or multiple-boot computer, select the installation that you want to access from the Recovery Console.
  4. When you are prompted to do so, type the Administrator password. If the administrator password is blank, just press ENTER.
  5. At the Recovery Console command prompt, type the following lines, pressing ENTER after you type each line: md tmp
    copy c:\windows\system32\config\system c:\windows\tmp\system.bak
    copy c:\windows\system32\config\software c:\windows\tmp\software.bak
    copy c:\windows\system32\config\sam c:\windows\tmp\sam.bak
    copy c:\windows\system32\config\security c:\windows\tmp\security.bak
    copy c:\windows\system32\config\default c:\windows\tmp\default.bak
    delete c:\windows\system32\config\system
    delete c:\windows\system32\config\software
    delete c:\windows\system32\config\sam
    delete c:\windows\system32\config\security
    delete c:\windows\system32\config\default
    copy c:\windows\repair\system c:\windows\system32\config\system
    copy c:\windows\repair\software c:\windows\system32\config\software
    copy c:\windows\repair\sam c:\windows\system32\config\sam
    copy c:\windows\repair\security c:\windows\system32\config\security
    copy c:\windows\repair\default c:\windows\system32\config\default
  6. Type exit to quit Recovery Console. Your computer will restart.
Note This procedure assumes that Windows XP is installed to the C:\Windows folder. Make sure to change it is a different location.
If you have access to another computer, to save time, you can copy the text in step five, and then create a text file called "Regcopy1.txt" (for example). To use this file, run the following command when you start in Recovery Console: batch regcopy1.txtWith the batch command in Recovery Console, you can process all the commands in a text file sequentially. When you use the batch command, you do not have to manually type as many commands. Part two loadTOCNode(3, 'moreinformation'); To complete the procedure described in this section, you must be logged on as an administrator, or an administrative user (a user who has an account in the Administrators group). If you are using Windows XP Home Edition, you can log on as an administrative user. If you log on as an administrator, you must first start Windows XP Home Edition in Safe mode. To start the Windows XP Home Edition computer in Safe mode, follow these steps.
  1. Click Start, click Shut Down (or click Turn Off Computer), click Restart, and then click OK (or click Restart).
  2. Press the F8 key.
    On a computer that is configured to start to multiple operating systems, you can press F8 when you see the Startup menu.
  3. Use the arrow keys to select the appropriate Safe mode option, and then press ENTER.
  4. If you have a dual-boot or multiple-boot system, use the arrow keys to select the installation that you want to access, and then press ENTER.
In part two, you copy the registry files from their backed up location by using System Restore. This folder is not available in Recovery Console. Before you start this procedure, you must change several settings to make the folder visible:
  1. Start Windows Explorer.
  2. On the Tools menu, click Folder options.
  3. Click the View tab.
  4. Under Hidden files and folders, click to select Show hidden files and folders, and then click to clear the Hide protected operating system files (Recommended) check box.
  5. Click Yes when the dialog box that confirms that you want to display these files appears.
  6. Double-click the drive where you installed Windows XP to display a list of the folders. If is important to click the correct drive.
  7. Open the System Volume Information folder. This folder is unavailable and appears dimmed because it is set as a super-hidden folder.
  8. Open a folder that was not created at the current time. You may have to click Details on the View menu to see when these folders were created. There may be one or more folders starting with "RPx under this folder. These are restore points.
  9. Open one of these folders to locate a Snapshot subfolder. The following path is an example of a folder path to the Snapshot folder: C:\System Volume Information\_restore{D86480E3-73EF-47BC-A0EB-A81BE6EE3ED8}\RP1\Snapshot
  10. From the Snapshot folder, copy the following files to the C:\Windows\Tmp folder:
    • _REGISTRY_USER_.DEFAULT
    • _REGISTRY_MACHINE_SECURITY
    • _REGISTRY_MACHINE_SOFTWARE
    • _REGISTRY_MACHINE_SYSTEM
    • _REGISTRY_MACHINE_SAM
  11. Rename the files in the C:\Windows\Tmp folder as follows:
    • Rename _REGISTRY_USER_.DEFAULT to DEFAULT
    • Rename _REGISTRY_MACHINE_SECURITY to SECURITY
    • Rename _REGISTRY_MACHINE_SOFTWARE to SOFTWARE
    • Rename _REGISTRY_MACHINE_SYSTEM to SYSTEM
    • Rename _REGISTRY_MACHINE_SAM to SAM
These files are the backed up registry files from System Restore. .
Part Three loadTOCNode(3, 'moreinformation'); In part three, you delete the existing registry files, and then copy the System Restore Registry files to the C:\Windows\System32\Config folder:
  1. Start Recovery Console.
  2. At the command prompt, type the following lines, pressing ENTER after you type each line: del c:\windows\system32\config\sam
    del c:\windows\system32\config\security
    del c:\windows\system32\config\software
    del c:\windows\system32\config\default
    del c:\windows\system32\config\system
    copy c:\windows\tmp\software c:\windows\system32\config\software
    copy c:\windows\tmp\system c:\windows\system32\config\system
    copy c:\windows\tmp\sam c:\windows\system32\config\sam
    copy c:\windows\tmp\security c:\windows\system32\config\security
    copy c:\windows\tmp\default c:\windows\system32\config\default
    Note Some of these command lines may be wrapped for readability.
  3. Type exit to quit Recovery Console. Your computer restarts.
If you have access to another computer, to save time, you can copy the text in step two, and then create a text file called "Regcopy2.txt" (for example). To use this file, run the following command when you start in Recovery Console:
batch regcopy2.txt Part Four Click Start, and click All Programs. Click Accessories, click System Tools. Click System Restore, click Restore to a previous RestorePoint.
Jul 21, 2009 | Computers & Internet
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
