Samson note 3 original charger is not working
    Problem Solver:
  • 11 Answers
Go on eBay and search for charger to fit Samsung note 3 charger.
Posted on Nov 30, 2014
I need a phone charger for a Samsung galaxy note 3 can you tell me what will work for my phone! I had one of your brand before! Thank you!
Any micro usb charger , rated at 2.0 amps. You can use a 1 amp charger but will be slow. All usb devices are 5 volt, don't worry about volts, just amps. Note 3 = 2 amp charger
Sep 04, 2015 | Samsung Cell Phones
Why would 3 of your multiple chargers stop working after 5 months? What to do about it? Where to replace of reimburse? Bad Public relations with teens.
Look or ask for authorized repair service as part of warranty.
Now, just a comment: the USB charger or my iPhone 5 got damaged without any reason just after 3 months of use and APPLE rejected my warranty cllaim! There was no apparent damage on the charger, simpy the iPhome asked for "original" charger... and I always used it with the same original charger!
Jun 16, 2015 | Computers & Internet
Why is my Samsung Galaxy Note 10.1" charging very slow.
There are a several reasons why the Galaxy Note 10.1 is not charging as much.
1. Too many application are turned on (check the task manager)
2. Too many notifications icon are turned on ( bluetooth, gps, wifi, etc.)
3. Plugging your charger using a computer
Are you using the original charger and plugging it into a wall charger?
How long did you use the Note 10.1 previous to noticing the damage? and was it extremely hot at the back?
If so, then maybe the battery isn't picking up from the charger. I've watched back to back movies while still using the charger but this can prove very devastating on the charger's outlet which became extremely hot after 4-5 hours or so of charging continuously. It turns out, the galaxy note 10.1 can withstand 8+ hours of ongoing movies but the charger outlet cannot. *If I didn't unplug it after 4-5 hours, the plug what have fried.
In this case, i believe the charger is more likely damaged than the Galaxy Note 10.1, which is more of a better scenario. Especially, since you charged it for over 24 hours, meaning it's charging something, but very slowly. Operating Galaxy Note while charging can prove detrimental in the charger's outlet and can in fact burn out.
I hope this info is helful,
Jason Chan
Jul 01, 2014 | Samsung Galaxy Note 10.1"
My Samson Carbon 49 keyboard controller. Under Device Manager/Sound, video and game controllers - DTMB BDA TV USB Properties General, This device cannot start. (Code 10).
1. Go to devices and printers.
2. Double click SAMSON Carbon49 to open
3. Hardware > properties > General > Change settings > Driver > Uninstall.
4. Turn off the device and turn it back on.
5. Hardware > properties > General > Change settings > Driver > Roll back driver.
Should work now
Jan 16, 2014 | Samson Carbon 49 USB/MIDI Keyboard...
I have a victorlite 1.5 million candle power spotlight lost charger but I have a 12 volt 1000ma- will that work??
If the voltage and tip polarity of your replacement charger matches the charging port on your spotlight, there's no reason why it shouldn't work as a substitute for your original charger. Note, however, that if your original charger was more powerful (say, 1.5 amps instead of the 1-amp charger you have here), it will take noticeably longer to fully charge your spotlight than the original charger took. it's not a problem if the original charger had a lower mA rating than the replacement in your hand--the spotlight will sip an appropriate amount of juice from the charger.
Jul 13, 2011 | Vector 1 Million Rechargeable Spotlight
What is the likely cause of the phantom power of a samson 900 mixer to go bad?
The phantom power is used for condenser mics. MAKE SURE you do not plug in other mics or devices that do NOT have balanced, isolated outputs as they will short out the phantom power to others.
You should find between 15 and 48 volts between BOTH pins 2 and 3 of each mic connector when measured to pin 1 of the connector. There is about 6K ohms impedance from the phantom supply to pins 2 and 3.
IF you have an accident and connected high voltage to pin 2 or 3 it COULD back up and blow the bypass cap for the 48 volts.
Please note: ALWAYS power ANY interconnected equipment from teh SAME receptacle to avoid damage due to ground bounce in the event of a fault in a piece of equipment.
Oct 22, 2010 | Samson Xm910 8Channel Powered Mixer...
Compaq Presario V3000 charger stopped working and now buzzes
Unfortunately there are no perfect cables, and especially in case of a laptop, when you move it around a lot, roll the cable for travel etc. it gets bent a lot, especially in the place where the elastic cable goes into the hard plug or into the charger case. The conductors inside and the inner insulation finally break, giving at first intermittent connection (what you experienced before), and finally short-circuits the cable, resulting in charger damage.
You should be fine just replacing the charger, unless all this wiggling around didn't break the laptop power socket.
When looking for a replacement charger, note the voltage of the original (it should be exactly the same in the new one), the maximum current amperage (this should be same or - better - higher than original), and the size of plug.
Good luck :)
Jan 23, 2010 | HP Compaq Presario v3000z Notebook
Samson c01u vista drivers
No. From their website...
Note: Samson SoftPre is not compatible with Windows Vista however the C01U, C03U and Q1U are all Plug-and-Play compatible with Windows Vista.
Aug 15, 2009 | Samson Audio C01upak C01u Microphone and...
Replacing slip on samson duels
you need the original header pipes for your road star
these are just mufflers slip the originals off and slip the new ones on
Apr 26, 2009 | 2007 Yamaha Road Star
Samson C01U USB mic not working on my PC.
try this;
1.using different usb inputs on your pc desk top
2.update drivers on both your desk top and laptop
3.using a different usb cable
if it works fine on your friends computer most likely its not the mic
Feb 25, 2009 | Samson Audio C01upak C01u Microphone and...
49 people viewed this question
 Grubhead
Grubhead
