How do I repair the plastic base on the bottom side of the projector? Plastic base cracked?
Is the bottom plastic piece replaceable?
    Sergeant:
  • 320 Answers
In many cases you can contact the projector manufacturer for replacement parts, The plastic (also known as the chassis) can sometimes be purchased separate. Although a crack should no effect the projectors operation unless it was dropped hard enough to cause a crack.
Posted on Dec 02, 2014
2 Suggested Answers
heathgr
  • 442 Answers
SOURCE: Is it worth fixing Hi
You have several choices,
[1] issue students with 3D glasses, and explain that the unit has been upgraded to 3D
[2] Is the 3D effect for one colour only or all three primary colours?
[3] pull it apart and check if the optical components are all intact.
chances are that a mirror is misaligned and a simple adjustment may fix it.
[4] tell us what model number it is
[5] failing all that, keep it as a spare for when the other units die and need costly parts for their repair.
Posted on Mar 18, 2011
Hi my glove box bottom surport bar has snaped can this be replaced or repeared
Most likely it is plastic. Get a piece of metal/aluminium to fit the channel. Drill it and rivet it in place. 3 inches (6 inch long piece of metal if you can) on each side of the crack and at least 2 rivets on each side.
Aug 09, 2016 | Cars & Trucks
Tip
Repair ACER Keyboard
Many a times, laptop's keys fell off the keyboard or it gets damaged. Don't fret on buying a whole new keyboard when you can repair the keys yourself.
This is an installation guide to repair keys of Acer’s laptop keyboard.
You should have a key cap and 2 or more retainer clips (plastic pieces), that goes underneath the key cap.
To install the key on your laptop keyboard, start out by observing the metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard. The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Here you can see that it has one large metal hook at the bottom and two metal hooks at the top.
Take the larger plastic piece and observe that it has two holes at the top corners, two sticks at the bottom and two holes in the middle. The top holes are going to go into the top metal hooks on the keyboard. The smooth part of the plastic piece faces away from the keyboard.
Take the smaller plastic piece and observe that it has two holes at the top, two sticks at the middle and a bar with larger hole at the bottom. The sticks in the middle are going to go into the middle holes of the larger plastic piece. The bottom bar is going to click onto the bottom metal hook on the keyboard. The smooth part of the plastic piece faces away from the keyboard.
Place the smaller plastic piece onto the larger plastic piece and insert its sticks to the holes of larger piece. It’s one piece now.
Insert the top plastic sticks into the top metal holes and the bottom bar into the bottom metal hook on the keyboard. Get a thin object or a blade and stretch the plastic pieces downwards to insert completely.
Take your letter key cap, put it in the middle of the plastic pieces and push down evenly from all four sides.
That's all to repair ACER keyboard key.
Source: Acer Key Repair
on Dec 17, 2009 | Computers & Internet
Tip
Replace DELL Laptop Keyboard Key
Sometimes with Dell laptops, the keys on the keyboard gets stuck or damaged or fells off the keyboard. There are many different ways to repair your broken keys. Just put your mind to it and you will be able to repair it yourself.
You can place an order to replace your broken key or you can repair it you have all the parts intact.
You should have a key cap, 2 or more retainer clips (plastic pieces), which goes under the key cap.
Following is the installation guide to replace and repair Dell laptop key.
To install your key on your laptop keyboard, start out by observing your metal plates on the keyboard.
Always be sure to look at the metal keys because they differ in every keyboard.The larger metal hooks can be at the top, bottom, right or left side. The position of the metal hooks determines the position of plastic pieces.
Here you can see that it has one large metal hook at the top and two metal hooks at the bottom.
Take the larger plastic piece and observe that it has two larger sticks at the bottom, two holes at the middle and two shorter sticks at the top. The bottom sticks are going to go into the bottom metal hooks. The smooth part faces away from the keyboard.
Take the smaller plastic piece and observe that it has a small bar at the bottom, two sticks at the top and two sticks at the middle. The sticks in the middle are going to go into the middle holes of the larger piece and the bar is going to click on to the top metal hook. The smooth part faces away from the keyboard.
Place the smaller piece on the larger piece and insert its sticks to the holes of larger piece.
Push it evenly to insert completely. Get a thin object or blade and stretch the plastic pieces upwards so that it clicks together.
Take your letter key, put it in the middle and push down evenly from all four sides.
You’ve just repaired your Dell laptop keyboard.
Source: LaptopKey
on Dec 16, 2009 | Computers & Internet
I removed my run capacitor from my Jenn Air Refrigerator Side by Side Model Number JCD2295KEP and when it was reinstalled a small piece of plastic broke off the Capacitor when I clipped it back to place. ...
If the case is not cracked it should be fine. There is a chemical in the capacitor that could leak out if the case and cause it not to work correctly.
Sep 24, 2014 | Washing Machines
Coolant Resevoir Tank Leak
A repair might buy a little time but you should replace.Either the junk yard or dealer will have this part.it is a coolant resevoir.
Aug 28, 2012 | 2002 Chrysler Sebring
MODEL 760h WILL NO LONGER ADVANCE SLIDES
The KODAK Carousel 760H was manufactured approximately between 1971 & 1981.
The problem you are describing is most likely a broken cycle solenoid "link". This "link" connects the cycle solenoid and the slide change mechanism. Repair parts are still available, but this is a repair best left to a factory-trained technician. Contact an Authorized Repair Dealer.
Jul 25, 2010 | Kodak Carousel 4400 Slide Projector
Is a cracked windshield to dangerous to leave unrepaired ?
just leave it. A windshield is made of 2 pieces of glass with a plastic laminate layer in between the glass. The plastic laminate is what keeps you in the car in an accident. the crack is in the outside layer.
don't worry about it. It is not tempered glass and will not shatter like side and back glass.
Dec 21, 2009 | NRS Car Dash / Windshield Combo Mount...
Cracked screen
If the plastic cover is cracked but the LCD is fine, the fix is very different. In some ways it's actually harder than replacing the LCD, which is simply connected by a ribbon cable. One challenge for you is that, unlike the LCD, which is available as a replacement part (on Ebay - about $25), there is no direct replacement available for the plastic covering. You will need to pick up another 880 that is being sold for parts and then salvage the plastic screen from there. I'm not sure I can actually describe the replacement procedure to you without pictures but here is the general idea:
First, you need to open the remote so that you can work with the top half. To open the remote, do the following: remove the two screws - one in the battery compartment and one at the top of the remote. Then, using your thumbnail (this is really the best, unless you have a thin, rigid piece of plastic. A part of a credit-card may work), force your nail between the two halves of the ****-shell casing near the bottom of the remote on the left or right side. Once you get your nail (or plastic) into the remote, angle it down at about 45 degrees and simply slide your hand up one side. This will release all the locking tabs very nicely without marring the surface of the remote. Then do the same on the other side. Now, take the bottom of the remote that is holding the logic board and put it aside. You will only need to work on the top half of the ****-shell case. Ok, now looking at the face, there are 4 pieces of silver trim that are locking the plastic screen into the case, two on each side; the piece directly above the Mute button and the Prev button (they look like unmarked softkey buttons), and the two thin elongated pieces at the top on either side. To remove these pieces, you need to turn the top half of the casing over so that you are looking at the underneath at the area of these 4 trim pieces. If you look carefully, you can see that there are very tiny posts covered with glue that are holding in these pieces. You need to forcefully, but carefully scrape the glue off and try to push the trim pieces out from the back. Try to do this is carefully as possible, since the surrounding plastic is delicate. Once you pop these pieces off, turn the top half back right-side up. Now the only thing holding the screen down is a kind of rubber cement around the perimeter. To remove your cracked screen, you can pull it off from the bottom without worrying too much. However, be very careful when trying to get your replacement screen off of the salvage remote! The screen must be pried up gently and slowly from the bottom. If you use too much force, you risk cracking the screen as you pry it up. If you wind up scraping some of the black paint on the screen's perimeter, you can use a permenent marker to color it. Back on your good remote, remove as much of the cement as you can and lay down some double-stick tape (a glue stick may work also) and lay the new screen down so it is aligned perfectly in the space. Then attach the trim pieces and use some epoxy on the underside to affix them in place. Re-assemble your remote and it should be as good as new. Good Luck!
Sep 06, 2009 | Logitech Harmony 880 LCD Remote Control
I have a BL1900 and the black plastic wheel on the base cracked and broke into a million pieces. It is the part that the glass liquidizer sits on - the collar from the liquidizer 'locks' onto the this...
You can order this part Black and Decker Blender Base Collar Ring BL5000-11
I also had the ring crack and ordered another one. It cracked after just a couple uses. So, even though you can get the replacement part, I'd suggest tossing the whole thing in the garbage and buying a different brand.
May 26, 2009 | Black & Decker BL1900R Blender
Cracked
I'm afraid that you will have to replace the base unit, part #62577, would sell for around $25. Once it cracks, then it is weak and will affect the brush roll and belt.
Dec 30, 2007 | Eureka 2996AVZ Bagless Upright Vacuum
49 people viewed this question
jasbo
jasbo
