Question about OneTouch Can Opener by One Touch
There is no model number on this One Touch can opener.
Nothing, I haven't rec'd any ans as yetas to how to open this gagit or how it is suppose to relese the lid after it is opened?
Tv wont turn on, no lights are on to indicate power
Hello
There is an intenal fuse with every tV. You haven't given any details about your TV, such as its Brand Name, Model number etc:- Open the set, and locate this fuse at its power supply regualtor board. if found blown up, check the reason. you must have through knoledge in electronics to follow the circuit.OK.
Feb 27, 2012 | Televison & Video
Why won't the Dyson Animal canister open when lever is depressed?
I'm sorry to hear you're having difficulties with your Dyson. Our advice would depend on which model of Animal you own, which you haven't specified in your question. Please get in touch with us directly so we can determine which model you have, and help resolve this issue - you can call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Please have the machine to hand when you call, so we can run through some troubleshooting checks over the phone with you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Feb 11, 2012 | Vacuums
Wiring diagram for garage opener
Wiring diagrams haven't been available for openers in years. If you are having a problem why don't you post it along with the make and model number and we will help you fix it.
Dec 23, 2011 | Sears Craftsman LiftMaster Chamberlain...
Hi, I can't get my upright dyson to empty. There is no response to the leaver that should open the the base. I can't get the base to prise open either. Therefore I cannot use my very full hoover :-(
Sorry to hear you're having a problem with your Dyson. You haven't specified which model you own, but please do get in touch with us free on 08002980298 (UK), or 1866MYDYSON (US), so we can provide the assistance you need.
Kind regards,
Jack
Dyson Customer Service
May 04, 2011 | Dyson Vacuums
Cycle isn't using Jet Dry
Open up the dispenser and there should be numbers inside[use a flashlite] change the setting to a higher number and try that!!
Jun 17, 2010 | Hotpoint 24 in. HDA3400G Built-in...
How to connect vb with ms access
se Adodc OR Even better.. ADODB. for this you need to get MDAC fromMicrosoft free download.(check under project_References- Microsoft DataActiveX objects.. the current no is 2.8. if it is not there download invb directory.
next, you can learn about creating a DSN from control panel, ODBC. onceyou learn this, connection becomes a piece of cake. get some free vbtutoriasl from WWW.
then
you need to use DAO or ADO to connect to the database. better study both but since ADO is current, i am showing that code.
under Menu Project_References, put a check mark on Microsoft ActiveXData Objects latest version (though it works for all, currently 2.8with sp pack 1 ).
at the general declarations:
dim conn as adodb.connection, rec as adodb.recordset, esql as string,esql1 as string
Private Function connect()
Set rec = New ADODB.Recordset
Set conn = New ADODB.Connection
esql = "Provider=Microsoft.Jet.OLEDB.4.0;Data Source=" & "D:VBDesigndhana2.mdb" & ";Persist Security Info=False"
'here you put the correct path of your mdb file. and check if you have jet 4.0
conn.Open (esql), , , 0
End Function
private sub form_Load()
connect
end sub
and for adding records:
say let us say you have 3 fields. then have 3 textboxes and 1 command button on the form.
private command1_click()
esql1="select * from Yourtablename"
rec.open(esql1),conn,, adOpenDynamic, adLockOptimistic
rec.AddNew
rec.Fields(0) = text1.Text
rec.Fields(1) = Text2.text
rec.Fields(2) = text3.text
' you need to check if in your access table design you have Allowed Zero length .. set it to Yes for all text fields.
rec.update
if not rec.eof then rec.movenext
rec.close
conn.close
set conn to nothing
end sub
this will add new records to access table from VB.
' for picture store the full path of the path and the picture file nameint the text field. and in the picturebox of VB form for viewingrecords again you need ADO or ADODC and here you code:picture1.picture=Loadpicture(rec.fields(3) ' depending on where thepicture field is located. you need to make a few trials.
End Function
connect
end sub
and for accessing records:
esql1="select * from Yourtablename where id =" & val(text1) ' for integers
esql1="select * from Yourtablename where name=" & "'" & text1 & "'" ' for string
rec.open(esql1),conn, adOpenstatic, adLockreadonly
label1.caption =rec.Fields(0)
label2.caption= rec.Fields(1)
label3.caption= rec.Fields(2)
rec.close
conn.close
set conn to nothing
end sub
' similarly there are routines to ADD, Delete, Edit, View etc.
Feb 26, 2009 | Computers & Internet
Need code number
I tried a Panasonic 4-unit universal remote (about $8 at Wal-Mart), and the code that works for it (sort of) is 0998. I say "sort of," because on the DVD side, you can only advance forward and backward from one chapter to the next (you can't "scan") and on the VCR side, you can't fast forward or rewind at all. So I'm returning the remote and looking for a "real" Toshiba D-VR610 remote. But I suppose this universal remote could be better than nothing, at least for the DVD functions.
Jan 30, 2009 | Toshiba DVR610 DVD Recorder/VCR
Vb 6.0 ado connection without ado control moving next record
I see 2 problems with your code.
1) Each time you call cmdnext_Click, you're reopening the database. Each time you do that, you start at the beginning of the file. You need to have the database opened once, somewhere else in your program. Be sure that the record set is visible from this sub.
2) In order to use the "Next" function, you need a loop like this
'test for no records
IF REC.BOF and REC.EOF then
msgbox "No Records Found"
exit sub
end if
IF NOT REC.EOF then
REC.MoveNext
(display your fields)
END IF
Again, this will only work if your database is opened outside of the cmdNext_Click routine.
Jul 08, 2008 | Microsoft Computers & Internet
OneTouch Can Opener by One Touch Logo
476 people viewed this question
Top OneTouch Home Experts
Donni Steen
Tom Chichester
Are you an OneTouch Home Expert? Answer questions, earn points and help others
