Question about Dryers
How do you do wire up for a new light in the loft and where do you get connection from
Nobody asked
  • Dryers Master
  • 3,904 Answers
If you have an existing light where you want a new fixture then you can just use those wires. If you do not have power to the loft then you need to connect onto another circuit (wall outlet or a junction box). You need to make sure that the existing circuit that you connect onto can handle another load on it. If you cannot connect in then you need to do a home run to your breaker box. If you do that you need to see if you have an open port for a new circuit breaker. As far as running the conduit and wire that is more than fine to do yourself. As far as the final connections I would not save my money there. Have an electrician come in and do it for you.
Posted on Nov 30, 2014
How do I assemble the twin loft bunk bed with slide?
Contact Coaster and aske them to send you an assembly manual
They have a phone number on Website
Oatesby Coaster
Jun 21, 2015 | Coaster Oates Multicolor Twin Loft Bunk...
I do not know how to instal it.
Hi, You need to have the Sims 3 installed then put the disk for Loft Stuff in your computer and a popup should come up asking if you want to install it.
Aug 29, 2011 | Sims 3 HighEnd Loft Stuff Expansion Pack...
Need to connect my kyocera loft to the computer but it is not registering as a recognized
to connect Kyocera Loft / Torino S2300 on the computer can be done through bloetooth but it must be known to connect at the start of the computer, to phonsel Kyocera Loft / Torino S2300 with a search device and the computer will ask for approval from phonsel. after approval of phonsel will be connected to the computer
Aug 22, 2011 | Kyocera Loft / Torino S2300
My Tristar TV signal booster has a red light illuminated, I think is says 'short' above it. Is the booster working? I have fault on my TV it maybe this. The booster has been working fine up till...
I too have a red "short" light on my Tristar booster. However- I've illiminated the Tristar as I unplugged it and connected my tv directly to the 13amp mains and b) connected the aerial directly to the aerial wall socket which is separately boosted from a distribution amplifier box in the loft. Picture was U/S so the "short" is probably in my cabling in the loft (I've been moving the aerial about lately).Hence I suggest initially to unplug the Tristar and check the fault is not back further up the line ie the cable and booster at top of house. Hope that all makes sense.ps before noticing the red "fault" light, my picture had gone to pot.
Jul 18, 2011 | Televison & Video
How do i wire in a loft light?
Unless the power is fed into the light fixture in the room below, you'll need to pull a wire from an outlet or from the panelboard. If this is all finished space, you may wish to call an licensed electrician to do this work for you. They have specialized tools that they can use to route the new lines with minimal damage to your existing finished walls. It will cost a bit, but will probably save you money in the long run since less finish repair work will be needed.
Mar 28, 2009 | Electric Electrical Supplies
Hunter Fan # 20723 The Westminster - lights delayed when turn on
Here is the answer I received from Hunter Technical Support.
"The light fixtures are manufactured with a limiter that prevents a higher than recommended wattage bulb from working. The limiter causes the slight delay even when the correct bulbs are is in use."
Pretty annoying if you ask me.
Jan 25, 2009 | Hunter 28096 Westminster 52" Ceiling Fan...
Lighting circuits
Can you draw out what you think the wiring looks like? Maybe I can help from there.
Will
Nov 02, 2008 | Kitchen Appliances - Others
Wiring a ceiling pull switch
The pull switch can be wired in line at the required position by removing the outer insulation on the cable sufficiently to allow for the intended live conductor to be cut and one end connected the switch in terminal and the other to the out terminal.
Make sure that the cable is not live or connected to the supply in any way while you are working on Please remember to rate this solution.it.
Oct 26, 2008 | Electrical Supplies
Dryers Logo
47 people viewed this question
Top Dryers Experts
