Question about Behringer 333212INFINIUM Bugera 333-212 Infinium
Where can i find the schematics for Bugera 333-212 Infinium guitar amp?
Where can I get a schematic diagram of the Bugera 6262 Infinium Guitar Combo Amplifier?
Bugera - MUSIC Group
https://www.music-group.com/brand/bugera/home
Notice of Scheduled Maintenance. This is to advise you that our system will be unavailable on Saturday, January 9, 4PM - 6PM, SGT. Please plan accordingly.
Page 44: Bugera Users' Militia (for all things Bugera) @ Ultimate ...
www.ultimate-guitar.com/forum/.../index.php?t...
Ultimate Guitar Archive
Aug 17, 2011 - 100+ posts - ‎68 authors
I really like the cleans on this amp, and I don't consider using the overdrive.. so better tubes will ..... Its a 6262 212 combo ... 6262-212 INFINIUM 10/06/2011 ..... is there aschematic for this mod somewhere floating around? Page 48: Bugera Users' Militia (for all things Bugera ...
100+ posts
Jul 15, 2013
Bugera TriRec - First pricing (US) @ Ultimate ...
100+ posts
Apr 19, 2010
More results from www.ultimate-guitar.com
Rig-Talk • View topic - Bugera Amplifiers
www.rig-talk.com/forum/viewtopic.php?t=138566&p=1605914
Jun 14, 2013 - 50 posts - ‎12 authors
Jan 11, 2016 | Bugera 6262-212 Infinium Guitar Combo...
Why does my lights in the front now work?
A capacitor should not become hot. Perhaps it was a resistor. Those cam become warm, without a problem. Just take the thing you got out (do it again) to a parts shop. don't know if there is still a Radioshack? If it was a capacitor, buy a new one and place it back the way the old one was.
I think that is the safest you can do.
Ever thought of checking if the bulb from the front light could be defect?
Jul 17, 2014 | Bugera 6260-212 Infinium Guitar Combo...
Bugera trirec infinium schematics
Make and model would help somebody find them.
Jul 13, 2014 | Audio Players & Recorders
Powers up but no output
that was smart...take it to the shop before you kill yourself...
Feb 01, 2014 | Behringer 333INFINIUM Bugera 333 Infinium
Blinking standby light no power
When you turn the amp on, does all the tubes light up? please add more info to help you out.
Oct 07, 2013 | Bugera 333XL Infinium 120 w 3 Channel...
Hi , i have a Bugera 1960 and my problem is send-return...when i put my boss ge-7 equalizer in it i can t hear the fx and this is the same thing for my delay pedal...i can hear but realy realy little...
The problem is the BOSS is designed to handle a guitar level at -20Db and the effects level is designed to run at either -10 Db or +4 Db. You will get better match setting the Bugerra effects to the -10 setting on the back and reducing the level... HOWEVER the pedal will want to send -20Db out which is 10 Db under what the effects return wants to see. This is a factor of three roughly in gain so the signal will be low. This is the problem using a guitar pedal in a way it wasn't designed to be used. The effects loops are looking for "line level" NOT guitar levels.
Schematics aren't going to help. The normal thing is to connect your guitar to the pedal and send the output of the pedal to the amp.
Guess what? The same things apply to your delay pedal... they are intended to accept the signal from the guitar OR the guitar like level from another pedal such as the GE7.
Mar 17, 2011 | Behringer Bugera 1960 Classic 150-Watt...
Bugera 1960A - channel 2 has very low volume even when vol2 knob is turned fully UP!
The user manual is located at: http://www.bugera-amps.com/PDF/Downloads/1960_P0671_M_EN.pdf on page 5; When the HIGH 1 and LOW 1 (or HIGH 2 and LOW 2) connectors are used simultaneously, their sensitivity is the same (both LOW). This may be your problem however--- Try swapping input chanels to see if the problem follows ther cable or is in the amp.
Assuming it was working before, you may have a short in the cable or a bad component or tube in the amp. Tubes can be difficult to come by. If the other channel works correctly, It may be one of the small tubes. Hope this helps
Jan 04, 2011 | Behringer Bugera 1960 Classic 150-Watt...
My Bugera 1960 stopped working in the middle of a rehearsal. I was playing at about level 3/4 in the 1st input of the 2nd channel. The amp was connected to a Marshall 4x10 bass cabinet. The connection of...
Wiring harness connector to the power tube section is fried. A common problem with all bugera amps and many other companies also. A cheap fix. You can order the part you need from newark.com or call 1-800-4newark the part number is sku#85c0290 mfr#09-91-0500
Nov 25, 2010 | Behringer Bugera 1960 Classic 150-Watt...
Need Schematices
Try posting on some of the guitar forums. The schematics you are looking for are only available to licensed repair persons but you might get lucky and find someone who will send them to you. Be sure to state what model amplifier you want. If you are a tech try looking at some schematics for a similar amp and tracing the circuit.
Jan 21, 2010 | Music
Behringer 333212INFINIUM Bugera 333-212 Infinium Logo
61 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
