Question about Panasonic DQUHS36K - Wokio Dp-C213 Black Drum Unit 39K Yld
Copy faint at one side
Cleaned the lens and the top glasses with a new drum Change the image roller
    Champion:
    New Friend:
  • 245 Answers
My dear you clean ccd camera
Posted on Dec 24, 2014
2 Suggested Answers
  • 19 Answers
SOURCE: Brush roller lines in feed direction of pages
Maybe the charge roller. Make sure it is very clean. You can also stop a copy before it enters the fuser to rule the fuser rollers out.
Posted on Feb 08, 2008
Very Faint copies.\r\nCleaned Top glass, Mirror & change new drum Still very faint copies, one side very bad
clean the laser unit.as the problem appears to be from it.it gets dusty or dirty by toner then u will have faint copies.developing bias can also be a cause but then u have to call a rep.
Sep 06, 2011 | Canon Office Equipment & Supplies
Our small office purchased a Canon Imagerunner 2000/1600 copier 4 years ago. Since our last service call, when the drum was changed and the machine was cleaned, we then ran less than 2000 copies. The...
When your drum was replaced did they put in a new drum assy or just replace the drum cylinder? I would purchase a new drum because these are one of the chepest to buy, around $ 80.00. They have a 6 month warranty and around 20,000 copies. I would replace the drum to see if that solves the problem. Before doing that, pull off the left side bypass assy. It is easily removed without tools. You should be able to see the drum and see if the drum is clean. If not, then replace the drum unit assy. Are you using only Canon toner, no other kind of brand will work. Generics should work but they are usually not as good a quality. The volume is very low and that should not be an issue. I believe its suppossed to handle 10,000 copies per month. Cleaning the glass top and below may help. The mirrors should also be cleaned as well. Good luck.
Dec 01, 2010 | Canon imageRUNNER 2000 Copier
One side of the finished copy is black, I cleaned the glass, I tried feeding it thru a different way, must be the drum?
first clean the optics(lens, mirrors) clean the chargers, and check if the drum is ok then change the drum cleaning blade
Aug 26, 2010 | Konica Minolta Office Equipment & Supplies
I'am getting black streaks on the side of paper. Cleaned the primary wires and vacumed the transfer and image drum.
Did you cleaned the fixing roller or optics or glass for adf or platen. Check the drum cleaning blade also!Try the image adjustment
Apr 29, 2010 | Canon CLC 1150 Color Copier
I want now what's Common faults in Aficio 2035
THe main problems are toner spill form drom/dev units ..the transfer on the right hand door will have to be emptied every few months. the paper tray paper stops need to be checked as they come out of place and cause paper jams if not set in place..cahrge rollers can be troublesome if not cleaned every coulple of months and may cause dirty image at the sides or lines on copies..dust on laser **** glass can cause faint on sides of copies.. the fuser stripper fingers tat guide the paper need to be checked for toner under the points to stop paper jams in fuser and the lower guide plate entrance to the fuser needs to be cleaned off every now and then to stop crinklin of paper...apart from that good machine
Dec 17, 2009 | Ricoh Aficio 2035 Copier
Magicolor 2400w gives paper jam error at transfer roller, after I cleaned the printer -laser head.
My 2400W was standing a long time without being used, and when I wanted to use it, it made a very faint image and showed "paper jam at transfer roller". Also, the image stayed on the transfer belt, but never got transferred to the paper. I tried a lot of things, nothing worked, but the message from weirdal1968 above pointed me in the right direction.
I eventually scratched / scrubbed / cleaned the copper pad on the left side of the optical imaging drum - this copper pad probably receives the bias voltage for the imaging drum from a springy stainless steel wire. There was some visible darkening of the copper pad where the stainless steel wire touched, this is what I cleaned. And then, presto, problem solved - the image came out great, and no more "paper jam at transfer roller" error message.
Oct 12, 2009 | Minolta magicolor 2400W Laser Printer
Gestetner 3245 dev.bias setting....
Hi how you doing the main problem with changing the dev bias is that the gap between the drum charge and dev bias has been brought closer and so more toner is being put onto the drum for image density.. I take it you have cleaned the optics on the scanner mirrrors and that the laser **** glass has been cleaned as these effect the copy quality too.. if the dev hasnt been changed at the pm intervals it slowly looses its charge holding capabilities.. you should change at least at the 160k marks to keep quality good.. you could also adjust the laser power up so you have a stronger image formation..hope this helps..if you know the machine I would take the laser unit out too and take the cover off to see if there a dust coating in the image mirrors as this can cause faint copies over a long period.. Good Luck A
Jul 01, 2009 | Gestetner Office Equipment & Supplies
A copy with a lighter image of the copy on the page
Do printed pages come out better than copies?
If they are the same, you may try another toner cartridge (especially if it is a remanufactured or compatible toner), otherwise, you need your optics cleaned (mirrors and lens under the contact glass)
Mar 06, 2009 | Canon Office Equipment & Supplies
Gestetner 2722z copier, new drum, new transfer belt, smudges yet
The image is not transferring properly..........
remove and clean all corona wires (thin wires that create the latent image) use a q tip and dip in rubbing alcoholhot
Also make sure the fuser rollers are hot(insert or trick safety switches to determine if the fuser lamps are lighting usually upper and lower
Also check the imaging lamp to be sure it does not have any dark burn marks on it and clean the mirrors and the glass under the coy area
Dec 30, 2008 | Gestetner Office Equipment & Supplies
OKI 4550 fax
try to boot the front cover and clean the glass over the lens
Dec 29, 2008 | OKIFAX 4500 Plain Paper LED Fax
Panasonic DQUHS36K - Wokio Dp-C213 Black Drum Unit 39K Yld Logo
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
