Question about Hardware & Accessories
How to set temperature
Model
    Problem Solver:
  • 15 Answers
You need to provide more info about what make and model timer you are trying to set the temp on
Posted on Nov 30, 2014
Why is the electrolux refrigerator won't hold set temperature? I set it +5 but its turning back to +18. What should i do? Not any of function mode could be set, its always turned to +18.
Hey Beke, thank you for your submission!
Based off the information you have provided your Electrolux refrigerator will not hold the temperature it is set to. When you set the temperature on the refrigerator it may take 24 hours for the temperature to stabilize. I may need your model number in order to further assist you. You can locate your model number on the inside wall of your refrigerator usually on a silver or white tag. With this information I would be able to assist you further. -Matt
Apr 09, 2016 | Electrolux Refrigerators
Model XRSS465BB Refrigerator - what is the correct refrigerator setting to avoid frozen vegetables? Also what is the correct deepfreeze setting?
usually meduim setting is good'
FREEZER /FRIDGE NOT COOLING: Optimum refrigerator temperature at or below40° F(4° C). The freezer temperature should be0° F(-18° C). Check temperatures periodically. Appliance thermometers are the best way of knowing these
Jun 14, 2015 | Amana Refrigerators
How do I set the temperature on a true refrigerator model GDM-26EM?
40 degree is a perfect temperature for produce if its lower that stuff will turn brown. Maybe you thermometer has failed. Go to the food store and get a red stick and put it in there. Then adjust with that temperature indication. Hope this helps and good luck.
May 09, 2014 | True Refrigerators
Where is the reset button on my electrolux fridge?
Good Afternoon Friend, thank you for your post! I see the temperature in your Electrolux refrigerator is too warm and would like to know how to reset it. May I please have your model number? The serial tag, which lists your model number, is typically located inside the cabinet, on the right side wall. With this information I can better address the issue at hand. In the meantime, please double check the temperature control. If the temperature is set too warm, set control to a colder setting and allow 24 hours for temperature to stabilize. Thank you - Z.
Apr 22, 2014 | Electrolux Refrigerators
Model 7905321300 Kenmore stove bake button works can't adjust temperature
I am not going to look up your model. Are there two buttons..one to select bake and another to set temperature?...the latter does not work? If so, you have to replace the temperature setting unit/thermostat.
If the thermostat (sets the temperature) is part of the electronic board, the board has to be changed. You will have to open the top of the control panel to determine this.
Oct 20, 2013 | Kitchen Ranges
I had a white rodgers thermosat system & its digital. I dont what model # it is but I want to know should I have the temperature set low or high if its 80 degrees in the house?
The set temperature is the temperature you want the system to cool the inside of the house.
A lot of digital thermostat will display the current ambient temperature. When you push the set temperature up or down buttons the thermostat will display the set temperature momentarily and will change if you push the up or down button.
Hope this helps.
Sep 04, 2011 | Heating & Cooling
Frigidaire oven model FEB500CEBI TEMPERATURE PROBLEMS
The short and simple answer is yes you do.
Dec 13, 2008 | Ovens
Oven temperature control intermittent
gas oven?? i would replacethe bake ignitor, the most common issue with unit not holding temp.
Nov 22, 2008 | Kitchen Ranges
Problem with Honeywell RTH230B Thermostat
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
May 27, 2008 | Honeywell Programmable Thermostat Heater
Hardware & Accessories Logo
52 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
