Question about Woods Hardware & Accessories
Woods 59730 6 plug outdoor timer. Hour arrow is stuck and rotates with the outer dial. How can I fix it. Thanks.
  • Woods Master
  • 5,245 Answers
Spray WD40?
If the timer still works, then the loose part should not be a problem.
The time-now arrow points at about the 1:30 position.
You can rotate dial until current time lines up with approximately 1:30 position.
http://waterheatertimer.org/images/GE15107-004-8.jpg
Gene
Water Heater Timers Save Money
Posted on Dec 02, 2014
3 Suggested Answers
SOURCE: woods industries outdoor mechanical timer 59730, I
I found a manual for this yard stake:
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
There is a switch located on inner dial.
Move switch to TIMER
Posted on Dec 10, 2010
SOURCE: how do I set the
Woods 59730 is24-hour 6-outlet yard stake with dial located on top
This timer is identical to GE15107 yard stake
Manual.
If this is not your timer, look at following page to identify your timer
http://waterheatertimer.org/Woods-timers-and-manuals.html
Add a comment any time
Timer instructions.
Set current time by rotating dial until time lines up with arrowhead located on inner dial
There are segments located around dial.
Look at inner dial > segments are located just outside the inner dial.
Timer comes with segments pushed inward.
To set timer to turn ON, pull segments outward for hours you want timer ON.
All 6 outlets are controlled by timer.
Last step:
There is override switch located on inner dial.
Move switch to TIMER for timer to operate.
My time arrow sticks on my woods 59730 relocatable outdoor timer. How can I fix it. Thanks.
Does timer still work?
Time now is just a locator so dial lines up correctly with current time
Line up current time with 1:30 position on dial.
Gene
Nov 29, 2014 | Woods Hardware & Accessories
We can't figure out how to set our timer. Where and what are the segmented pins. Nothing is labeled. There is no diagram with the timer. Thank-you. Joy and Fred.
Hi Joy and Fred.
You posted under Woods outdoor timer, but don't give specific brand or model
Open following links for detailed information and illustrations:
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
http://waterheatertimer.org/Woods-timers-and-manuals.html#59383
Segments are usually on outer edge of dial.
Some timers the segments lift up, some push down, some pull up and out, etc.
Use a fingernail or small tool and fiddle around with it.
Some timers have pins located on dial face that click inward or outward. Use small tool and move them in and out.
Some timers have trippers that you attach to outer edge of dial.
If you are confused, open links above for illustrations.
After moving some segments-pins. Plug lamp into timer.
Turn lamp on. Plug timer into outlet.
Manually rotate timer dial and watch how lamp turns on-off.
Move timer switch both directions and manually rotate dial to see lamp turn on-off.
These tests will show you how to set pin-segments-trippers and switch for your specific timer.
The timer dial rotates as time passes. The dial is a simple clock that rotates because of a clock motor.
The dial causes segments-pins move small lever that turns lamp on-off.
Just like any clock, the correct time has to be set. To do this: rotate dial until current time lines up with arrowhead located on inner dial.
For more information, add a comment with in-focus photo of your timer.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 29, 2011 | Woods Outdoor 24 Hour Mechanical Heavy...
Brand new Woods Timer (Model 59730) turns on/off correctly, but completely stops during "off" hours every day. When I reset the current time, it runs for about 8-10 hours, then stops. Returned...
It seems odd that you'd get two defective timers.
I bought one of these timers from Home Depot under the GE brand and the dial rotates correctly as time passes.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59730
Woods 59730/ GE 15107 timer is a mechanical timer, so circuit problems should not affect clock motor.
On electronic timers, if circuit is not clean (circuit has ground fault), then timers don't last long and do peculiar things.
My suggestion is to try timer on indoor plug, on a different circuit breaker, for 1 day and see if it keeps running.
This will tell you if outdoor plug might have a loose wire, and that electricity is getting cut off.
Add a comment and tell me what you discover, or add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 22, 2011 | Hardware & Accessories
Model 59204EV Outdoor Mechanical timer - How do I set it - The pins do not move on my timer - where are the pins located?
Different Woods timers have same model number, depending on who packaged and sold product.
Manuals are sometimes generic. They say pins when they mean segments or tabs.
Segments are small plastic divisions located around outer edge of dial.
They divide 24-hour day into 15 minute or 30 minute periods.
Link below shows sample pins and tabs.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
With the 15204, I believe these segments pull out or push inward; but they could also pull upward or downward.
Move a couple segments, plug in the timer and lamp, and then manually rotate dial to watch how lamp turns on-off.
Lamp must be turned ON and bulb working.
Some 15204s have a switch on face of timer, or somewhere on timer. Some do not have a switch, and some have a dial. Move switch to TIMER, or to AUTO. Or rotate dial to ON.
Add a comment for more free help.
For a price, fixya expert speaks with you over phone while you work on timer, any do-it-yourself project.
Jan 13, 2011 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
How do I set the woods outdoor timer model #59730
Manual.
Timer instructions.
Last step:
Dec 09, 2010 | Woods Outdoor Lighting Timer
Please e mail the intermatic timer instruction model# 59419 rosecthimote@aol.com
59419 is the Woods 2 pack plug in 24-hour dial timer with 2-prong outlet.
If this is not your timer, add a comment.
http://www.amazon.com/59419-Appliance-2-Prong-Outlet-24-Hour/dp/B002Y1KZHQ
See all Woods timers and manuals:
Manual for Woods 59419:
http://waterheatertimer.org/pdf/Woods-59419.pdf
Instructions:
Rotate dial until current time lines up with arrowhead located on inner dial
When plugged in, dial rotates
24 segments located around outer edge of dial; each segment is 1 hour
You have to pull these segments up using fingernail or small screwdriver
Segment pulled up = lights OFF
Segment down = lights ON
Override switch located top of timer, move switch to TIMER
Make sure lamp is turned ON
Plug timer into wall
Dec 04, 2010 | Woods Hardware & Accessories
LOST MY INSTRUCTIONS ..... HOW DO I SET THE TIMER?
You posted under Woods 59204 outdoor timer.
manual for Woods 59204 timer
http://waterheatertimer.org/pdf/Woods-59204.pdf
Instructions:
Rotate dial until current time lines up with arrow.
48 segments (or pins) located around edge of dial > each segment is 1/2 hour
Set ON-off times by pushing pins in or out
Pins pushed out = timer ON
Pins pushed inward = timer OFF
Plug in timer.
Maximum 1250 Watts.
50 mini-bulb strand of Christmas lights is 25 Watts.
Timer will operate 50 strands of 50 mini-bulbs.
Long-winded guide for Christmas light wattage:
http://www.christmaslightsetc.com/pages/how-much-power.htm
Nov 29, 2010 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
Can't get the timer to turn on
Woods timers:
You posted under Woods 59383.
Plug timer into wall after setting timer.
Maximum load 500 watts, used for indoor or outdoor
Set current time, rotate dial until current time lines up with black triangle.
Around outer edge of dial are segments.
Pull up all segments for times you want timer OFF
Leave segments down for times you want timer ON
Locate switch on timer.
Push switch so the V shape is down.
Plug into wall outlet, plug Christmas lights into timer
Drink ale and eat turkey legs.
Add a comment if this is not your timer, or if you need more help.
Nov 23, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
Whwere are the pins to set the tomer on the 59204 model? Thanks
Woods 59204 is a plug-in timer rated for 1250Watts incandescent
The pins are 48 'segments' located around outer edge of dial;
Segments pushed toward center of dial = timer OFF for that 1/2 hour
Segments pushed out = timer ON for that 1/2 hour
Nov 18, 2010 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
Hardware & Accessories Logo
91 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
jdthefixer
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
