Question about Jenn-Air PRG3010 (NP) Gas Kitchen Range
How do I Put the door back on
Can't get door back on
    Top Expert:
  • Jenn-Air Master
  • 51,191 Answers
The hinges have to be partly open like you were letting the oven cool then just slide the door back down on the hinges .
Posted on Feb 20, 2015
Dryer door switch assembly. how do I put it back together
All the terminals should be different in size with the big terminal wire being common which goes in the middle the other 2 wires make the light come on and make the motor go so if you get em backwards she will run with the door open and the light will come on with the door closed..
Aug 29, 2012 | Maytag Dryers
FIXING DOOR (DOOR IS COMING OUT)
The large oven door pull's off , and can also be pused back on the same way , if holding the door about 12" from closing pulled towards you to remove or push down to put back on if you pull it off the hinges it may take two to put it back on again
Jun 08, 2011 | AEG B2100-4 Electric Single Oven
How do you change the direction of the door opening.
(THIS IS A TWO PERSON JOB)(be sure u unload the door first)At the top of the door u have a bracket with three screws or bolts in it, take out the screws while the other person holds the door once this is done take off top bracket the door should lift off of the bottom bracket,now take the bracket off the bottom of the refrigerator,On the other side of the fridge there should be some small white plastic plugs pull them out ,this is were u will put the bottom bracket ,u will also have some plugs on the top of the fridge too..be sure u put the plugs back in the holes that u just took the screws out of.Put the bottom bracket on first,do not over tighten screws,then take ur door place the bottom of door on bottom bracket,put bracket for top of door in the top and screw back down now ur door should be good make sure it closes correctly,and of course put the stuff back in the fridge
Mar 31, 2011 | Refrigerators
I removed a bedroom door and when I put it back the door won't close
When you put the door back on was the door closed? If not that is what you need to do to put it back in line.
Mar 19, 2011 | Garden
How do I remove old pins and bushings in a 99 chevy silerado
put a jack under door to hold up take a big screw driver pull spring out the use screw driver to drive both pins out thenpull door away from truck replace bushings then put door back put pins back in hinges
Jan 21, 2011 | 1999 Chevrolet Silverado 1500
Door fell off. Can't put it back on.
Hello sir; on the door there have two pieces magnet when you close the door it will stick on the metal on the machine check it and find out these two magnet is there/
Jun 04, 2010 | Toshiba Office Equipment & Supplies
Had paper jam- opened back door and it came off - how put back on?
6f4b08e.jpgI know its hard to put it back i already experienced that problem before., You are using ESP5 printer is that correct? Make sure to remember th e position of the rear access door or backdoor., Noy if you want to put it back, make sure you will put first the left side of the door there should be a two tab ont he left side put that first make sure it will be insert into the two socket inside the printer., Now if its already in follow the right side of the door or the rear access door you should hear a mclick sounds it means thats its already lock.
I inserted a picture for you to able to pictureout the right position of the rear access door.
Nov 17, 2009 | Kodak ESP 5 Printer
My Beaumark Stove is from about 1964. The hinge on the oven door popped out while i was moving it. Now both hinges are out and I see no way to put them back.
there is a lock for each hinge
lay the door down with hinges facing up.take a towel pull long piece
of hinge toward you(BE CAREFUL) take other piece up and lock them together do the same to the other hinge it should then go on easy next time lock before taking off .These are the instruction on how to remove and replace the door, be sure you locate the removal pins to being able to put it back
This [link] http://tinyurl.com/kogjg3 should help you out.[link] http://tinyurl.com/mzgjtq is added to the hold the hinge in place on the self clean doors. The screw and bracket have to be removed to remove the door and hinges. The metal clip bracket has to be reinstalled once the door is put back on. To reinstall the [link] http://tinyurl.com/mszglp just do the opposite, start the hinge blade in the receiver, lift slightly on the door and with your knees push the door and hinges back into place. One thing most people forget about these hinges is that there is a clip that must be moved to hold the upper (A) and lower (B) parts of the hinge together. Once the door is put back on, the clip must be put back in the rest position. To reinstall the door, put the door at a 80degree angle to the range front, push in the larger upper hinge parts first and then lower in the smaller hinge parts, push the clips forward into the rest position and close the door.
On this [link] http://tinyurl.com/lg76wg one common problem is the hinge will sometimes "pop" forward against the range instead of staying still while you reinstall the door onto the hinges. If this happens, use a screw driver at the marked spot to help hold the [Link] http://tinyurl.com/kren2c so you can start the door onto the hinge, them remove the screwdriver to finish installing the door.
I hope it helped.
Jun 06, 2009 | Kitchen Ranges
How do I get my fridge level to put the doors back on
On my Refrigerator Doors, there are Screws either on the top or bottom of the DOOR that besides holding the door on, also move it up and down to put it into alignment.
Hope this helps.
Oct 15, 2008 | Maytag MZD2669KE Side by Side Refrigerator
Can't put door back
This may help:
http://www.whirlpool.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%203196278.pdf?PIPELINE_SESSION_ID=62e5768ec0a8503448ca0e04446c0ca5
Oct 27, 2007 | Whirlpool RBS245PDS Electric Single Oven
Jenn-Air PRG3010 (NP) Gas Kitchen Range Logo
91 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
