Question about Heavy Machinery
New kohler 6.5 hp engine on 27 ton log splitter won't start? Switch on, throttle 1/3 open gas on, has gas. Choke on, which direction?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 484 Answers
After attempting to start, pull the plug quickly and see if it is wet from gasoline. If not, it could be a fuel delivery problem. Start with the hose connection at the carb from the gas tank. Pull it off. Gas? Good. No Gas? Something is plugging up flow out of tank or shut off valve.
Some fuels with alcohol in them cause moisture/
condensation/ oxidation within the aluminum bodies of some small carbuetors inhibiting the flow of gas through the jets. There is a chance the carb needs removed and thorougly cleaned if no gas is passing through the carb to the intake.
Also inspect plug for fouling. Fouling is carbon build up shorting the electrode to ground. Clean thoroughly or replace the plug. Before reinstalling, set the spark gap properly with a feeler gage and then ground the metallic threads on the side of the head and pull the rope start. Watch closely for blu spark jumping the gap. DO NOT touch the plug while doing this, it could SHOCK your SOCKS off !!!! If you have a bright spark, that's good. Install plug and tug the rope and see what happens. If you have no spark, you have an ignition problem.
Are you using summer blend or winter blend gasoline in the engine and what is the outdoor temperature. Gasolines are formulated differently nowadays and a summer blend mixture will wreak havoc on a small engine in the winter time as well as winter blend will do the same in the middle of the summer. We now have oxygenated fuels designed for the high performance engines in the automobiles today and some small engines run extremely 'lean' and as a result some starting issues are created as well.
Posted on Nov 30, 2014
  • 202 Answers
SOURCE: Have Exmark 52 LazerZ with Kohler ch25 engine.
try looking for a broken wire or a wireing harness shorted to ground, the fuse blowing in the harness will lead you to it if you are able to see where the wire goes. you have a short somewhere may be the fuel pump, too
Posted on Jul 16, 2009
mickey813
  • 472 Answers
SOURCE: small engines
YOU NEED A CARB KIT IN THE CARB IT NEEDS TO BE CLEAND OUT
Posted on Oct 02, 2009
  • 15483 Answers
SOURCE: 17 hp kohler that is dumping gas out the muffler
carb float sticking open dumping gas into cylinders
Posted on Oct 19, 2009
  • 33 Answers
SOURCE: My craftsman mower with a 26 hp kohler dies when choke is in
carb dirty, jets partially plugged, float sticking. Not so uncommon problem and is caused by the fuel left in the carb over the winter gumming up (going bad). You can attempt to clean this on your own if you are somewhat mechanically inclined. Search small engine repair and it will give you a generic breakdown of the parts in a small engine carb. If not the, to have someone overhaul a small engine carb will run you about $120 including parts (at least around VA).
Posted on Apr 05, 2010
SOURCE: craftsman riding mower will not start
Same thing happened to me with my 26 horse kohler craftsman. Replaced EVERYTHING (spark plug, fuel filter, oil filter, and degunked the carborator), and still was flooding. It ended up being the flywheel key. Cheap part, quick fix. I guess it can happen when you hit something hard with the deck, or it can just happen without reason... I hit a snowbank hard with my snowblower attachment, but I didn't even realize it until afterwards because it kept running fine. Supposedly, even after the strain to the engine, it won't always stall out. It will keep running (but maybe rougher) until you shut it off. Then when you go to start it again, you will have no luck because all the timing is out of whack. It cost me $80 to have a repair company fix it. I think the part was only $5.
Posted on May 21, 2010
Cub cadet 27 ton log splitter 6 hp runs high rpm all the time moving throttle doesn't help adj. governor no help.help
There's a very good chance the governor broke inside the crank case... outside adjustments won't help at this point... remove the motor and remove bottom portion of housing and you will find the problem.
Jul 02, 2017 | Cub Cadet Garden
Runs fine for few minutes then dies like running out of gas then choke it it starts runs then does it again over and over
You have a feeling issue..
By choking the engine, you restrict the airflow, thus reduce the amount of fuel being drawn through the carb, meaning it's burning a sufficient amount of fuel and air.
When the choke is off, it's getting too much air for what can be drawn through the carb, meaning you have a furlong issue.
Mar 31, 2016 | Cub Cadet LS27CCHP - 27-Ton Horizontal /...
Log splitter blows fuses
It now has a bad dead short in the wiring and that is why the fuse keeps blowing.. Check for bad wiring
Mar 07, 2014 | Cars & Trucks
Hard to start lawn tractor
I have 2009 lawn tractor that will not start (from day 1) unless I use a small squirt
of start fluid into the air cleaner area. Nothing else seems to work. The battery will run down before it starts. Once engine is warm it starts great. Love the tractor,
hate the starting problem. Elevation is not a problem in michigan.
Jan 11, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Robin engine for 27 ton log splitter..starting problems
remove the float bowl from the carburator and clean it out. Either the float is stuck of the needle valve is gummed up. Both the float and needle valve together regulate the fuel allowed into the bowl, if they dont allow fuel in or allow it in fast enough, the engine dies. Also check for a fuel Screen in the fuel tank, it may be plugged up.
Oct 01, 2009 | Garden
Kohler small engine problem
1989 Kohler 20 backfires through the exhaust. What are the possible causes?
Jun 02, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Stihl KM 55 won't start
1. 1st change the spark plug to NGK BPMR 7A.
2. Set the kill switch to on position (I)
3. lock the throttle interlock on
4. Do not prime the fuel bulb...this may cause flooding.
5. set the choke to full choke.
6. pull the cord gently until the piston resists then pull hard
7. repeat pull a second time
8. open choke all the way
9. pull cord again hard.
engine should start within 2-3 pulls, release throttle and feather the throttle until stable
Apr 04, 2009 | Hand Tools
Swisher 22-Ton 7 HP Log Splitter #LS722
For all swisher log splitter problems go to swisherinc.com.
Dec 10, 2008 | Garden
Heavy Machinery Logo
856 people viewed this question
Top Heavy Machinery Experts
Tom Chichester
Daryl Gleaton
Bill Boyd
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
