Question about Electrical Supplies
<!-- from fixya rte -->Need a rebuld kit for carb model 05528 - Electrical Supplies
2 Suggested Answers
  • 2309 Answers
SOURCE: where is the number that i will need to get the
rebuild what???
Posted on Nov 16, 2009
Engine starts but dies
clogged carb need to rebuld it maybe needle and seat bad
Jul 24, 2014 | Briggs & Stratton Garden
I have a 1990 cbr 600 just cleaned the carbs and when i started the bike it dies when i give it throttle please help also idileing high 2k -3k
sounds like a fuel restriction or flooding.. check the fuel filter or kinked fuel line.clogged pitcock....you could have not put he jets in right and your flooding out the motor..check throttle return spring.. set the floats correctly?...you must use the measuring gauge in the carb rebuild kit to measure the correct float hight after rebulding the carb and replacing the floats...
Jan 05, 2011 | 1995 Honda CBR 600 F(3)S
I tried to start my troy vac/blower and it takes for ever to start and when i used the vacuum it runs slower and finally stalls and wont start backup
Your machine probably needs: 1. the carburetor adjusted 2. The carburetor cleaned 3. A gasket and diaghram kit installed in the carb
1. To adjust: http://www.zamacarb.com/tipspage.html
2. To clean: Remove, disassemble and clean. Here are the carb parts: (Only clean the metal parts)
http://tech.flygsw.org/walbro_tuneup.htm
3. Gasket and diaghragm Kit: You will need to know the carb model (probably a Zama)
Find the model of your repair kit here: http://www.zamacarb.com/pdfs/QuickKit_CR2010.pdf
An RB kit is a complete rebuild kit (contains all the parts in the G & D kit)
A G & D kit is a gasket and diaghragm kit and will cure most of the carbs ills.
Many online vendors sell these and there are an abundance of them on Ebay.
Nov 12, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
What's the specs to rebuld a carb on an 06 virago 250
u need a clymer manual-plus the whole bike is explained
Oct 22, 2010 | Yamaha Xv 250 Virago S Motorcycles
How do u rebuld a carb.on 2003 suzuki inturder vs800gl /also it sceems like it is useing a little oil its not smokeing or leakeing
Well you only need to rebuild your carb if you change your pipe, if its the same pipe then tune up is fine.
May 25, 2010 | 2003 Suzuki VS 800 Intruder
THE AIR IS PASSING THROUGH THE GUN OUT THE TOP
you have a bad seal and need a rebuld get a kit from your local supplier
Oct 07, 2009 | Stanley Bostitch 28 Industrial Framing...
Thottle will no stay in one position. There is a black spacer that slides over the throttle shaft between the shaft an the leaver. Will a new leaver come with that black spacer. Blower model wt200
Three (3) possible carbs were available on your machine.
If you have:
Walbro model WT-606 carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071726 and choke lever kit part #530071725.
If you have:
ZAMA model C1Q-W11 carb, the choke AND throttle levers are BOTH a part of the carb itself. (Would need a whole carb to get your part.) Complete carb part #530071465.
If you have:
ZAMA model C1Q-W11C carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071715 and choke lever kit part #530071716.
Hope this helps.
Oct 04, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
94 300 dies like vaperlock but vents and screens are clean
you might have trash in carb.need flush it out might rebuld carb
Jul 18, 2009 | Polaris ATV
Gas floods out engine,if I pinch the line (regulate the flow) I can get saw to run.XL360 homelite
I sounds like there is some dirt under the needle valve in the carb. Change the fuel filter first, if it is falling apart then it is very likely a piece of it got in the carb. Try spraying some carb cleaner directly into the fuel inlet to see if you can flush it out first, If not then your going to have to pull the side closest to where the gas goes in off the carb take out the little screw and clean under the needle valve.
Mar 19, 2009 | Homelite Garden
Electrical Supplies Logo
22 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
