My ipod touch won't connect to my hi-fi.
I have just purchased a ipod touch 5th gen and I have got a lightning adapter so I can connect it to my old hi-fi dock and it says nothing is connected.
    Problem Solver:
  • 15 Answers
It's most likely that the power rating from your hifi dock is not enough for the 5g and that it is not supported on this hifi.
Posted on Nov 30, 2014
IPOD TOUCH WONT TURN ON
Marclla, Check the attached links,instruction and guides to get IPOD up and running, Good luck.
I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info.
My iPod Touch 5th generation won turn on
If your iPhone iPad or iPod touch doesn respond or won turn on
Fix iPod won turn on problem Quick Fix
http://ccm.net/forum/affich-786664-5th-generation-ipod-won-t-turn-on
Apr 01, 2016 | Apple iPod touch
What gigabyte is my iPod
iPod touch (5th Gen, 16 GB, 2014) 1.0 GHz* Apple A5* Intro. June 26, 2014* Disc. July 15, 2015 Order MGG82LL/A* Model A1421 (EMC 2600*) Family 5th Gen ID iPod5,1 RAM 512 MB* VRAM None Storage 16 GB* Optical None Complete iPod touch (5th Gen, 16 GB, 2014) Specs
Nov 20, 2015 | Apple iPod touch
I have a Technics SC-HDA710, I have a ipod touch 4th gen is there any way I can connect it to this system or is there anything I can purchase that will be compatible or add to my system so I can play the...
For just listening, anything with a headphone/earbud output can be connected to any available analog Line Level input (except PHONO) with a simple adapter. They don't tell you that in the manual because they want you to purchase expensive accessories like docking stations.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
Read the article (it's short). Don't buy into the hype about better cables. IPOD's don't stack up as hi-fi to begin with and cables are cables are cables....
http://www.dummies.com/how-to/content/connecting-your-ipod-to-a-home-stereo.html
Jan 20, 2011 | Technics Audio Players & Recorders
They dont charge my 5th gen ipod wats going on?
Is your AC adapter plugged into the speaker? Your iPod won't charge unless the AC adapter is connected to the speaker and an outlet; the batteries alone will only let you play your iPod.
Sep 08, 2010 | Memorex Travel Speaker with iPod Dock...
Charging
Some Pure-Fi's has a problem charging 2nd Gen Touch iPod, even when proper supplied adapter is used. You can try pressing the iPod further into the connector and see if it stays charging. If not, you can tilt the Touch slightly forward to make proper charging contact with Pure-Fi's iPod connector.
If you only charge your 2nd Gen Touch in your Pure-Fi, or other devices less thick than the Touch, like iPod Nanos, then you can stick a spacer on the Pure-Fi behind the Touch to always properly tilt it slightly forward. Only space it slightly forward just enough to cause it to charge so as not to stress the connector.
Stick-on chair/furniture protectors work good for this. If they are too thin, stick one on top the other till you get the thickness you need. Do not use any thicker a spacer than needed so as not to stress the connector any more than needed to make charging contact Use thinner stick-ons, like double sided foam tape, to get the final spacing you need.
The added advantage to a proper spacing between an iPod and Pure-Fi, is it relieves connector stress when plugging in and using an iPod while plugged in, since the taller Touch iPod cannot tilt backward. If you place your spacer at the very top of the Pure-if back panel, then iPods thicker, but shorter, than the height of your space can also be used.
Hope this helps everyone with this irritating Pure-Fi design problem.
To view the charging/not charging status on the 2nd Gen's screen, turn off the 2nd Gen and the Charging Icon will show when contact is being made.
May 24, 2010 | Logitech Pure-Fi Express Plus...
How can I use JVC AVX810 with Iphone? Currently IPOD works fine with the USB cable but IPHONE is not recognised. Maybe there is an adaptor that can solve it?
JVC KS-PD100 iPod Interface Adapter (257KSPD100, sold separately). This optional iPod Interface Adapter supports audio playback for the following iPod models - iPod click-wheel (3rd gen), iPod photo (4th gen), iPod mini (1st/2nd gen), iPod nano (1st/2nd/3rd/4th gen), iPod video (5th gen), and iPod classic (80/120/160GB). The KS-PD100 is not compatible with the iPod touch (1st/2nd/3rd gen), iPod nano (5th gen), or iPhone (2G/3G/3GS). This iPod interface will also not charge the iPod nano (4th generation). *Apple firmware updates may change functionality results.
There u go.....
Jan 29, 2010 | JVC KW-AVX810 Car DVD Player
IPOD won't connect to receiver.
The Apple iPhone 3G, iPod Nano 4th Gen, iPod Touch 2nd Gen, and any other newly released iPods can be controlled using the iPod adapter above; however, charging will not be possible unless you purchase the Scosche IFWA PassPORT charging adapter.
May 30, 2009 | Dual Car Audio & Video
No wi fi for itouch
Usually, all iPods have a WiFi chip imbedded in the device so you have to pay nothing except for your currently active Wireless internet connection. Try checking your modem and making sure it's working for starters. If it is, then go on the iPod and go to settings, then internet connections. Select a valid internet connection and it should automatically connect, given a good signal strength.
If this helped/didn't help, let me know.
Sep 25, 2008 | Apple iPod touch
352 people viewed this question
 Grubhead
Grubhead
