Sound strength frequently fluctuates from weak to strong. How do I fix it?
I changed the speaker wires, checked it with different inputs.
  • Jeremy Zollinger Dec 01, 2014
    Thank you, Nick. The receiver is a Kenwood KR V6070. How do I check the line lever signal for the inputs? For all the inputs, the volume will fluctuate between a strong sound and a weak sound with seemingly no cause - it just happens, over and over.
  • Nick Verdelet
    Nick Verdelet Dec 01, 2014
    maybe its a volume encoder fault , does it do it on radio too ?
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 166 Answers
Line lever signal should be the same though all inputs accept phono
Posted on Dec 01, 2014
Testimonial: "Thank you, Nick. The receiver is a Kenwood KR V6070. How do I check the line lever signal for the inputs? The volume fluctuates for all the inputs from a weak sound to a normal strong sound, over and over again."
  • 1 more comment
  • Nick Verdelet
    is this happening on all inputs ??
  • Jeremy Zollinger Dec 06, 2014
    It happens only with the tuner, Video 1, and Video 2. In Video 1 or 2, if I unplug one of the speakers, the receiver gives full sound strength to the other speaker. When both are plugged in, both are weak.
4 Suggested Answers
ohms
  • 1879 Answers
SOURCE: No Sound
Greetings,
Good decision.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Posted on Jun 29, 2008
SOURCE: left channel not working
Thanks, yesterday i tried changing the speakers from right to left, the problem still remained on the speaker getting connected to the right channel. Later i pulled out the speaker wires from the reciver's end for the right channel, cut them and pulled out new strings from the insulation, twisted them and inserted, the speaker is working fine, though not 100% but close to left channel. I guess the problem was old strings in the wire which had got over twisted and were not parallel to each other.
regards
Swamy
Posted on Oct 01, 2008
  • 256 Answers
SOURCE: Right side no sound to speakers
The output transisters for that side are probally blowin,
Posted on Dec 06, 2012
Amplifier signal does not reach both speakers equally strong
Check the balance (L/R) settings. IT is very unusual for something like this to happen. The problem usually is a total failure of one amp. If this is not the case then it might need to be adjusted and that would take special equipment.
Mar 15, 2014 | Onkyo Audio Players & Recorders
Sound comes in strong and weak at different times
It could be that or a loose wire to one side of the speakers in the set. If it does it often enough locate where the actual sound for each side of the set is located---when it does it get close and listen---if one side is low or distorted you know it is either a connection or speaker on that side OR since most sets have a left and right channel for sound--the issue is in one side.(circuit problem)
Dec 05, 2012 | Vizio VF550M 55 in. LCD HDTV
No input 2 signal
The connections bad.... try rewiring the one for signal 2 or if its making a good connection... look for a weak spot in wire... that helped me when i couldn't figure out wiring
Aug 28, 2012 | Cars & Trucks
When viewing TV with DTV, the sound will occasionally mute right after the clipping in a program. Just like the function that protects the speakers from loud sounds. (This function is OFF) The sound comes...
Just try connecting the input to another TV and check whether the same problem comes. If it does, the problem is with the input. If not, the signal strength is not good enough to the microcontroller IC to switch off the mute. Normally when the signal is missing or weak, audio mute gets operated.
Jul 12, 2012 | LG 42le5300
The volume goes up by itself - SABA M5115GT
This is due to the signal reception. Some channels are broad casted with strong signal strength. Therefor you will find the audio is louder than other channels. Also, if there is voltage fluctuation/surges/spikes that is also responsible for suddenly increasing the volume. Best is to put a voltage stablizer
Jan 22, 2010 | Televison & Video
Weak signal 60 feet away at neigbhoor's
Some routers just don't put out strong signals. The problems could be wiring in/around/at your house or neighbors....causing weak signal. Are the signal strengths strong in your house?
We have super signal strength on ours upstairs (we have a bi-level house) but downstairs the signal is very low. All the wiring in the house and anything electronic or otherwise can block it.
Hope this helps at least some. Good luck!
Jul 30, 2009 | D-Link DIR-625 (790069292637) Wireless...
Intermittent sound/picture freeze when recording
this fault could be due to electrical interference ie freezer cutting in/out .just because your signal is strong dose not mean its interference free .check you analogue picture get it as good as you can with no ghosting. i also live in the southwest cornwall infact .aerials in lofts are not a good idea .i would mount it outside. by the way i am told that when the old analog channels are turned off the digital signal strength will be increased. good luck .farr64 [camborne cornwall]
Apr 29, 2009 | Televison & Video
Wireless signal is very weak
Signal strength is varies depend on your position,
Hardware type, wireless provider line-of-sight (how
many obstacles that blocking the signal), and other
factors.
Make sure you connect to the same wireless spot.
Or at least go to places with wireless spots and compare
signal strength.
If you never have a strong signal from at least 5 different spots
(make sure you check it's the top 5 best spots you find,
ask others who connect to the spot also to make sure)
then you go to your repair shop and ask them why.
But, if you at least have 1 strong signal then
your spot just having a weak transmission.
Dec 26, 2008 | Dell Inspiron 2200 Notebook
Sound volume fluctuates
gah im having same problem with my creative 5.1s... took it apart and used contact cleaner on every bit of soldering i could see, and checked the wire... still no luck
Sep 27, 2008 | Logitech X-540 Computer Speakers
Sound 'changes' when using different input sources
try to check the auidio setting on the dvd itself. make sure it is set to 6.1. I think it is set for 2.1..change the setting and you will be just fine. good luck
Jan 02, 2007 | Pioneer HTP-2500 System
47 people viewed this question
 Grubhead
Grubhead
