Question about Sony ST-SA50ES 2 Channels Tuner
Sony "Protect" message
My Sony receiver/tuner worked yesterday. Today, when I put a cd in, it plays for a second or two and then stops and a "Protect" message come up. Any clues?
  • djhanseninsf Aug 17, 2008
    When playing a dvd, if sound ges too loud I get the same "protect" message and it shuts down the sound
SOURCE: "Protect" flashing on STR-D665 Receiver
Check if you connect corectly the speakers wiresnand if they are right connected the audio amplifier Ic are damaged
Posted on Nov 28, 2008
SOURCE: Getting a "Protect" message in the display which then shuts down
The speaker wires were al little frayed, so I cut and stripped new 3/8" leads and when re-inserted the receiver worked fine. The problem was a short from the frayed wires touching either the back of the receiver or some other metal near the terminal.
Posted on Dec 08, 2008
  • 4234 Answers
SOURCE: Receiver keeps flashing "PROTECT"
The protect message indicates that a problem was detected in the last stage of the amplifier and that it has shutdown to prevent further damage. Usually this indicates that the output transistors have failed. Any shop that works on audio should be able to repair this. Expect a part cost in the $20-$40 range. Add in the local labor rate for the total repair cost.
Posted on Dec 17, 2008
SOURCE: My Harman Kardon receiver (
I used the live chat and the problem was resolved.
Usually the problem are strands of speaker wires which cause shorting and protection shuts off the receiver in order to prevent damage. There was one speaker that I repositioned recently which was causing shorting. I twisted the wires and tightened them in place and my receiver has been working w/o a glitch. I was lucky that I did not have to check all the wire strands on the receiver and all the speakers.
Problem solved and I learned valuable lesson.
Posted on Dec 28, 2008
  • 98 Answers
This generally means you've got a short somewhere, and the received is trying to protect itself.
My suggestion is to disconnect all of your speakers at both ends, and reconnect them.
Most times this happens because a speaker wire is lose, and the positive and negative connections are touching each other, causing it to short out.
Posted on Mar 25, 2009
MESSAGE READS "NO DEVICE"...Yesterday musice stopped playing for all 5 discs
Have you tried disconecting it from the power completely leaving it for five minutes and plugging it in again?
Aug 02, 2014 | Sony CDPCE500 cdp-ce500 5-disc cd changer
I have a sony explode cd player. It is an older one and has been sitting in a garage for about 3 years. We hooked it up today and my subs will not play when a cd is playing but the subs will play in...
It sounds like you are using the blue wire (power antenna remote turn on) instead of the blue/white wire ( amplifier remote turn on) to turn your amp on. The power antenna remote turns off when leaving tuner mode.
May 02, 2011 | Sony XPlod CD Player w/MP3 Playback...
When I play CD only the right speaker is play but
first- is the tuner set to mono or stereo? if stereo, stop using the analog rca jacks and use an optical (toslink) cable to transfer your audio to your receiver. almost all cd players have this output and the same with the receiver. better still, if you are using a late model cd or bluray, and your receiver has hdmi inputs use those as they will transfer both audio and video with one cable.
Oct 29, 2009 | Sony STR-DE575 Receiver
Have you tried cleaning the unit with a "Laser Lens Cleaner?" one that uses fluid? Mp3 is a fickle format and your deck may be having issues reading it. Try running a cleaner thru it. Secondly, when you burn discs, make sure you finalize it by making it "compatable for all player types" Hope this helps
Jun 25, 2009 | Sony CDX-F7500 CD Player
Bose Wave Music System - CD Says "Not Playable"
I turned mine upside down pressed play and it started working.
Turned it back over and it's working fine.
Dec 22, 2008 | Bose & Wave& Music System
No sound in DVD mode
when i turn on sony receiver it will not play it just says protect on the screan
Dec 21, 2008 | Sony STR-DE445 Receiver
Dec 06, 2008 | Sony STR-DE185 Receiver
Cannot hear DVD through the DVD receiver port
I had to turn on the TV first then the receiver and DVD player to see the video of the DVD.
Jul 31, 2008 | Onkyo TX-SR803 Receiver
Overload protection circuit kicked in. Check all your wires (speakers,input,output cables), There is a short somewhere and lets hope it's not In the receiver.
Jul 12, 2007 | Sony STR-DE197 Receiver
Amp goes to protect mode only on cd play
Do you get adequate bass on the radio, or is it a bit quiet on the low-end?
Apr 15, 2007 | Sony CDX-SW200 AM/FM Compact Disc...
Sony ST-SA50ES 2 Channels Tuner Logo
908 people viewed this question
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
