Question about Roland Boss Micro BR Multi Track Recorder
I am hearing a buzz when i turn on the mic. What's the solution, can you let me know please?
  • Roland Master
  • 3,904 Answers
Buzz is almost always a grounding. Check the soldering. If you are not comfortable with that get a known working mic and cord and try that out.
Posted on Nov 30, 2014
Behringer Xenyx 502 Mic buzzing...PLEASE HELP
Get yourself anti-static spray and spray over the connector before inserting into the jack, most times its dust or static buildup which causes that buzzing sound and in other times replace your mic
Mar 02, 2012 | Behringer Xenyx 502 Audio Live Music Mixer...
I turn on the power and get just a buzzing noise. The keyboard does not work at all. The power light is on but no sound from the keyboard other than a buzzing sound.
normally a buzzing sound means a grounding problem, or a component has failed, unless you have the proper equipment to check these items,, your going to have to take it to a shop that does, sorry I know thats not what you wanted to hear,, but heres a hint, Ive found that a shop that deals in instruments and sound devices charges a lot, I have found a TV repair shop in my town, that can check my band equipment,, and its much cheaper, and I usually get the stuff back much quicker too
Sep 01, 2011 | Akai Music
I just received my RSQ-echo 2000 karaoke machine. When I plug a mic into the front 2 mic inputs, they both have echo, even tho I turned off the echo volume in the back. I assumed that by turning it all...
The control supposedly controls the mix of the echo... this is a reverb type sound. Please note that room acoustics AND if the mic's "hear" the speaker in this, it may create an echo that is NOT under control of the adjustment. Make sure the mic's cannot "hear" the speaker or a reflection off a wall.
Aug 17, 2011 | RSQ NK 2000U
I turn it on and at the volume set @ U or straight up(midway) nothing comes out. if you turn it all the way up of course you get alot of buzz and barely get any sound from a mic or mixer signal,etc. could...
Make sure you are using BALANCED line to this... XLR connections boyh ends. Make sure ALL interconnected devices are powered from the same receptacle or power conditioner. Test your cables... they do go bad. This unit REQUIRES line level input. Do NOT expect a mic to drive it directely. Make sure your mixer uses the XLR outputs and is powered from the same receptacle, even if you have to run an extension cord to it. This is a bi-amped speaker so there are independent amps for high and lows. With nothing out and known good in there is very little electronics before the signal is split to the separate amps. At line level, your volume control should probably be about 2 o'clock with the EQ's straight up flat.
Apr 25, 2011 | Mackie TH-15A Active DJ Powered THUMP...
Have only had it for just little under a year and I can't get the mic to sound I have a CD player hook to it its player but mic will not
Without knoowing what type mic you have and where it is connected we can't help you. Normally a mic is connected via an XLR to XLR cable to one of the input XLR jacks. Then you turn up the top white knob... start at about 3 o'clock. This is the input trim control. Set the grey pan control in that same line of knobs to 12 o'clock. Move the slider up for that column AND move the MAIN slider up.
The speaker should be in the A/B mode for stereo. With these settings you should get mic output.
Please view videos on YouTube about "mixer setup". MOST mixers are about the smae and what you learn about any of them will apply to your unit. One other thing is IF you are using a CONDENSER type mic, you will need to turn on the PHANTOM power switch. Note condenser mics are so sensitive that they must be used in a studio as if they can hear the speakers at all, feedback will occur. Also be careful if your speaker plugs are 1/4 inch, do NOT lett the sleeve of channel A touch ground as the sleeve, not the tip is hot.
Apr 16, 2011 | Behringer Europower Pmp5000 Powered Mixer...
Hi im using the carlsbro gd 4000 in a 3 piece rock and roll band we are using an oldmike shure c606 and we cant get any volume out of the mike and its distorting the vocals we dont know whether the p.a.s...
Proper placement of mics versus the speakers of a PAS is important to avoid feedback. Your speakers need to be toward the audience from where the mic is. If the mic can "hear" the speakers you will likely have feedback. The mic should work even though it is a consumer grade mic.
WORD OF CAUTION: There are a LOT of fake SM58 microphones being sold... even on Ebay... SOME are fairly high quality and others are not.
Mar 31, 2011 | Music
Pls, i will like to know how i can get a pro sound with my beringer b2pro mic with my xenyx 1204usb mixer. i mean mic settings
The mic will give very good sound assuming you put it in a studio environment and have no speakers being driven by it that the mic can "hear" or it will feedback instantly.
Your studio should have proper sound deadening on the walls ceiling and floor. There is a lot of information on the web about setting up a studio. Search for it with google. The more studio-like the environment, the more like pro sound you will get. You will NOT get pro-sound in a bare garage or a room in a house without handling the sound reflections in the room. These mics hear EVERYTHING... they are a high quality mic.
Feb 25, 2011 | Behringer B2PRO Gold-Sputtered Large...
Hi I have a marantz pmd661 with a buzz on record when set to ext mic/line with no i/p regards
If you let the input "float" with no connection it very well may buzz. The input needs to be tied down with a driving source.
Feb 15, 2011 | Marantz Pmd661 Portable Field Flash...
How many rca wires do i need what kind of mic and will it work off a soundblaster external soundcard and if possible i'd like to have a drawing to show what goes where
We have no way to enter drawings on FIXYA.
Figure 3.1 in your user manual has everything you need to know.
You would need 4 cables with RCA plugs at the 1202 end and whatever your soundblaster interface takes at its end to handle STEREO signals to and from the unit.
Almost any type of mic will work, and the choice of mic depends on what you are using it for and how much you have budgeted for. If you are in a studio without monitor, then one typically uses condenser mics AND for those you turn on the "phantom" power on this mixer. If you have speakers tied to this or where the mic can "hear" the speakers you likely cannot use condenser mics as they will cause feedback.
Sep 22, 2010 | Behringer Rx 1202fx 12 Channel Line and...
Cannot hear myself when mic is plugged in
make shure the cable youre using between the the itch ( great little controller ) and the receiver is not balanced. here are the two options that will work. from your sure unit. xlr-to 1/4ts or 1/4ts to 1/4ts. there are two kinds of 1/4 inch connectors. these you know look like the standard guitar plug or some people call them phono plug. on the end of the prong you will see one or two rings. one ring means its tip and sleeve . two rings means your cable is tip , ring, and sleeve.
how is that software compared to the normal SL software?
i use, tech 1200s and a rane ttm54. but i dont use serato. i use torq. i love it.
Feb 24, 2009 | Vestax Music
Roland Boss Micro BR Multi Track Recorder Logo
Top Roland Music Experts
Vito Vacirca Jr.
Rabbit Brains
Rabbit Brains
Matthew Spark
Matthew Spark
Are you a Roland Music Expert? Answer questions, earn points and help others
