Question about Frigidaire Refrigerators
My frigidaire model jsi-26 refrigerator's fan on the refrigerator side is clicking and i'm having trouble taking it apart. How does the fan come out once i get the cover off?
    Sergeant:
  • 304 Answers
Missing your whole model number can't pull up the whole diagram to help you
Posted on Dec 02, 2014
HVACRH20
  • 237 Answers
SOURCE: Frigidaire side by side
The compressor sounds like the start device went bad. When that happens there is the "click" during trying to start, but since it can't the compressor overheats in time and then the thermal overload opens to protect it from overheating. Take the back lower panel off the refer and see if the compressor is really hot to the touch. If you have a little white colored box on the left side of the compressor pull it off and shake it... if it rattles and debris falls out you know it's bad. There is a kit that replaces it and it's real easy to install yourself. If you have a compressor that has a little blue indian head symbol on it however... your compressor is toast. Once they overheat they're done. If you have any other brand name you should be OK with a simple start device change out.
Posted on Jan 06, 2007
Master_Tech
  • 770 Answers
SOURCE: The refrigerator side is warm
is there a heavy frost build up on the back wall of the freezer?? is the fan in the freezer working??
Posted on Feb 17, 2008
SOURCE: Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Posted on Feb 05, 2009
  • 16 Answers
SOURCE: Kenmore refrigerator 26' side-by-side Model 596.52673200
on the amana rifg pull both knobs off
on the right side of control panel remove a 1/4 in screw
remove plastic panel now u can get too the part
Posted on May 13, 2009
  • 220 Answers
SOURCE: Where can I download an owners manual for a
http://www.frigidaire.com/manuals.aspx
Posted on Sep 13, 2009
How do I tighten door handle on frigidaire model jsi-26
Good Morning Chris, thank you for your inquiry!
From my understanding you need to tighten the door handles on your Frigidaire refrigerator. I was unable to locate any information on your model JSI-26. Without the model number I would be unable to provide you with proper instructions on how to tighten your door handle. Could you please provide me with your model number? You can locate your serial tag (which lists your model number) on the right hand wall of your refrigerator. With that information I would be able to assist you further. -Matt
Aug 01, 2015 | Frigidaire Refrigerators
Frigidaire JSI-26 refrigerator side does not keep cold. Freezer works fine...
they share the same compressor so either the fridge air demand switch is faulty or more likely you have faulty thermistors.
Jan 06, 2013 | Frigidaire FRS23KF7AB Side by Side...
Side by side....noise coming from back wall of freezer. Sounds like a loud hmm with clicking at times.
Here is a tip that I wrote about refrigerators and the fan noise that they develop sometimes...
Refrigerator Fan Noise
heatman101
Apr 22, 2011 | Frigidaire Side By Side Refrigerator 26...
Frigidaire JSI-26 does not keep cold
It could be the thermostat, if its a mechanical one its easy to replace but if its electronic then its a cicuit board repair, theres two transistors which control the switching on and off when the censor triggers them. It could also be the compression system. There is a recharge kit which puts a special fluid into the system which regenerates it.
Mar 26, 2010 | Frigidaire FRS23KF7AB Side by Side...
Ice maker and water not working. refrig. seems to be colder and the bottom than the top
Looks to me like your definately looking at a shortage of water supply or Refrigerant, my money would be on the latter. It makes enven more sense when you say there is partially cooled sections The bottom staying colder.
Get an engineer in to put some guages on the unit and a service is probably well overdue, your condersor fan running ok? is your condersor clean and clear?
Steve.
May 14, 2009 | Frigidaire FRS23R4A Side by Side...
Problems with Frigidaire FRS6R4E Side by Side Refrigerator?
The refrig side does not have a fan. only the freezer. Is that fan working??? you will hear it when the unit is running (and not in defrost) The clicking you hear is the Damper (a motorized door allowing more or less air to the refrig) opening or closing. Is there frost buildup on the back wall of the freezer??
Nov 23, 2007 | Frigidaire Side by Side Refrigerator 26...
Refrigerators Logo
96 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
