AEG L12700ViT Front Load All-in-One Washer / Dryer
Problem for AEG L12700ViT Front Load All-in-One Washer / Dryer
Underwire stuck in the drum!
By susanmcmurch on Jul 06, 2009
When machine is on there is an awful noise and I suspect there is an underwire stuck in the drum. Can see it sitting at the bottom through the holes when looking inside with a torch but dont know how to get into the drum to remove it. Do you remove the front door seal (cause this seems to be secured really well) or do you get into the drum by taking off the rear panel? Last time this happened I paid £30 for a repair man to remove it from the filter and would rather fix it myself if possible.
The machine is a hotpoint ultima 6kg.
Comments:
Jul 06, 2009
- Thank you very much!!! Thanks to you I have now removed the underwire and machine seems to be in working order again! Cheers!
Best Solution
posted on Jul 06, 2009
Very Helpful)
venexcsd
Rank: Guru
Rating: 88%, 409 votes
Switch the power off
Drain off the water by putting the rear drain hose into a bucket
Take off any clips which secure it to the back panel to make sure you get as much water out as possible.
Tip the machine back and rest it on a couple of cushions look underneath and you will see a large black hose coming from the bottom of the drum to the pump.
If the hose is on the front of the drum then tip the machine forward so that the wire is more inclined to fall to the front of the machine
Remove the clip from the hose and pull the hose off
You should then be able to reach the wire
Make sure that when you put the hose back on that it is fully up against the drum and that the clip is secure
Comments:
Jul 07, 2009
- Another uplifting experience!!
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for AEG L12700ViT Front Load
Questions and Unsolved Problems for AEG L12700ViT Front Load
Do you recommend AEG L12700ViT Front Load All-in-One Washer / Dryer?
Answer
Answer
started a clicking sound during a heavy load...also a smell like when the belt burns off the vacuum... (More)
Answer
The washing machine is working fine but when you set the the dryer on it goes through the motions... (More)
Answer
when shut door to start wash, press start, a clicking noise occurs and error message comes up
Answer
Cant get machine to work, shut door and select wash program, nothing happens, all the lights come on... (More)
Answer
When I try to use the drying function I get an E320 error just bas the drying cyle begins (when the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For AEG L12700ViT Front Load...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14852
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
