Question about Cycling
My 49cc hensim is getting no power just on the red wire, what could this be
We bought a wire tester and it is showing only power was direct power what could be the problem?
    Master:
  • 706 Answers
You have a bad ground connection
Posted on Dec 04, 2014
Show me how to wire a starter to a 49cc scooter motor how to wire a starter to a 49cc scooter motor
Hi, Mike sorry you can't find the first and best tool you ever bought for your scooter despair not for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
49cc scooter starter wiring diagram Google Search
WIRING DIAGRAMS INSTRUCTION
My Wiring Diagrams 49ccScoot com Scooter Forums
http://www.49ccscoot.com/manuals/Kymco_Agility_50_Service_Manual.pdf
Apr 02, 2016 | Motorcycles
How do I wire a 49cc starter to the motor how do I wire a starter how do I wire the starter to a 49cc scooter
Hi, Mike sorry you can't find the first and best tool you ever bought for your scooter despair not for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
I have a reading of 120 volts accross red and black leads but I am also getting 23 volts from either red or black to ground terminal. when I plug in a wiring tester it shows voltage on ground. What co
you need to tie into the 220 voltage at you breaker panel... 5000 watts will barely power your heater. you will not be able to power it direct as it needs low voltage for the control... but I am not an expert
Dec 26, 2013 | Honda Mmd 5000 Watt Generator W/ Engine...
I am trying to replace an old spring loaded attic fan timer. The old time simply had a black line in and a black line out. There was both a white and red line capped off in the box along with a bare...
The timer is wired differently than the old spring-loaded timer.
This is because the timer has an electronic clock instead of a spring.
The electronic clock needs power just like an alarm clock.
The white wire powers the clock.
Here's the wiring.
Black-timer wire connects to Hot-wire-from-breaker
Red-timer connects to Load (attic fan)
White-timer connects to white Neutral
In absence of a Neutral, connect white-timer to bare ground.
If you have your black-timer and red-timer wires reversed, it might cause the symptoms you describe.
Simply reverse the black-timer and red-timer.
If you want to test your wires to make certain:
Remove timer.
Separate wires for testing.
Turn on power.
Use ordinary tester.
Tape tester leads to wood sticks to keep hands away.
Power is ON.
Test each wire to bare ground wire.
When tester lights up, that is hot-wire-from-breaker.
Now test hot-wire to each of the other wires (except ground)
When tester lights up, that is Neutral
Not every switch box will has a Neutral
In that case white-timer connects to ground
Nov 08, 2010 | GE 60minute Automatic ShutOff Timer Switch...
R&R and dimmer wire color? VRCD400-SDU
Dimmer wire for your car should be RED wire in wire harness, illumination is RED/BLACK. check to see which wire works with a light tester. you should never use the dimmer wire with an aftermarket radio, only the illumination wire. Dimmer wire has fluctuating voltage when you move the dimmer up and down. Illumination wire is a contant voltage of +12V and aftermarket radios use this set up.
Aug 26, 2009 | Car Audio & Video
03 suburban yellow wire won't give power and speakers don't work
Your fuses are most likely out. The thing is, is that if any of those wires touch you can blow out some fuses, that may mess with the odometer, gas, oil and temp readings. More than likely your fuses have busted when you were changing out or even when you ran that wire directly from the battery.
Rixtarick
Hope that i could help you out. If worst came to worst, you would probably just need a continuity tester to see what wires were giving power, after you changed those blown out fuses.
Mar 29, 2009 | Corvette Chevy Malibu 90-04 Car Radio...
Cycling Logo
61 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
