Question about Dishwashers
Is the lower spray arm supposed to be loose and rock back and forth when rotating it by hand?
  • 69 Answers
Yes
Posted on Dec 01, 2014
IFIXALL
  • 868 Answers
SOURCE: Spray arm has come loose on my Whirlpool DU600PWKQ0
They are probably still attached to the power drive
Posted on May 22, 2008
  • 297 Answers
SOURCE: Lower Spray Arm doesn't Rotate on Siemens SE55A560 Dishwater
upper and lower connection should be same type of setup
missing part thus?
This sometimes is also caused by not driving in right the rack (closing properly) mating the connections tight. My old Bauknecht had this little problem.
Unfortunately I have no manual with parts drawings.
Still warranty?
Parts shop nearby?
Upper connection does have rubber ring or is a conical seal?
And when you fill the basket, no teaspones or such dropping too far down? My error many times.........
Posted on Apr 14, 2009
  • 81 Answers
SOURCE: removed lower spray arm:ge gld5500 dishwasher. Can reinstall.
Yes!
Posted on Apr 24, 2009
  • 423 Answers
SOURCE: LG LDS5811WW Low pressure out of spray arms
On the LG LDF xxxx dishwasher family, the Vario feature uses a motor/check valve to switch between "full power" cleaning from _either_ the lower or the upper spray arms, never at the same time. So, not seeing the upper arm spin during the lower arm spinning is standard operating procedure.
But back to your problem. Step one would be to remove the filter assembly again and make certain that there is nothing (debris, broken glass) blocking the white areas where the check valve rotates to switch between upper/lower spray arms. A blockage there ~could~ cause impotent spraying/cleaning.
If there is no blockage and the impeller remains in good shape, suspect a failing wash pump motor. Try to isolate the noise to that motor.
Watch for error codes on the display and report back what you find, OK?
Good Luck!
Posted on May 14, 2009
  • 2501 Answers
SOURCE: lower spray arm siemens aquastop dishwasher doesn't rotate
Sprayers require water to pass through the jets to provide motion to the arms.
Suggestion;
Remove the sprayer from the machine and look for blockages. (Removal should be easy, at it is expected that the user will need to clean the jets occasionally; If you have any problems removing it, consult your manual).
Posted on Dec 14, 2009
Testimonial: "Thanks for a speedy and v helpful reply. Sounded obvious, but I hadn't checked the water inlet(which was calcified)just the jets on the arm itself! "
Why are the items on bottom rack not being cleaned properly
If is clean dishes in the upper basket, I conclude that the pump produces enough pressure what means that the lower spray arm for some reason does not rotate and because that washing result is bad. Before washing I would check the lower spray arm rotates freely and after that open the door during washing and check if the lower spray arm rotates. Sometimes, the holes in the spray arm clog and disable turning which leads to poor washing results in the lower basket.
Dado
Aug 17, 2014 | Indesit Dishwashers
When driving frequently the vehicle will start swinging back and forth like you are moving the steering wheel back and forth you let off the gas and it quits for awhile been aligned and checked why?
was the suspenssion checked out before the alignment was done?? something is loose/worn out. i would be looking at the lower control arms/bushings on lower control arms.something tells me that who ever did the alignment didnt check out the suspenssion the right way or at all. you can not do alignment if stuff is loose.
Sep 17, 2012 | 1988 Nissan Pathfinder
Upper and lower spray arms are not spinning
Check that the arms spin freely when spun by hand, then check the outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
May 06, 2011 | Microwave Ovens
Siemans dishwasher model SE55A560GB/42. Upper rotating spray bar not turning but botton spray bar is rotating. Dishes are left with a gritty feel to them.
Check that the arm rotates freely when spun by hand, then check that the arm outlet jets at the trailing end of the arms are not blocked with food particles and other solid matter. This often happens and the arm is unable to turn because the water jet that is supposed to drive the arm does not have the force to rotate it with the result is that the upper dishes do not get enough water and chemicals. It may also cause water to continue dripping onto dried dishes after the the drying cycle has stopped.
Apr 13, 2011 | Dishwashers
2003 chevy suburban 1500 i replace my tensioner pulley and belt for my a/c compressor and now my tensioner is rocking back and forth and the truck idels hard when the a/c or heat is on
The tensioner is not set or aligned properly.
Rocked back and forth  this means the pivot bushing has worn down.
Tensioner Arm Misalignment
This may appear as metal-to-metal contact between
the arm and spring housing, and will be indicated by
shiny, smooth streaks or gouges in the metal.
Misalignment also is likely if the arm can be vertically
rocked back and forth. This means the pivot
Idler Bearing Wear
With the engine off and the belt removed, manually
rotate the tensioner pulley. Noise or resistance
when turning the pulley could indicate bearing
failure. Check for play in the bearing by rocking the
pulley. It should only pitch very slightly. If noise,
resistance or excessive play is found, replace the
pulley.
Excessive Tensioner Arm Movement
With the engine running, observe the back and forth
sway of the tensioner arm. If it exceeds 1/2” of
movement, or moves continually, the damping
system has failed. This movement can reduce the
life of the tensioner, belt and component bearings.
The tensioner should be replaced.
Improper Belt Tracking
With the engine running, inspect the belt and tensioner pulley. If the belt
is not properly tracking in the center of the pulley, the tensioner could be misaligned. This also can be a sign of a bent bracket or misaligned components. Check the drive components and repair if necessary.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 07, 2010 | Heating & Cooling
I feel and hear a knocking in my steering wheel when turning or going over bumps
It sounds like you have either a loose ball joint or something loose in your steering. watch the steering while someone turns in back and forth. Look for any play. The idler arm is the notorious part on GM trucks. If you have to replace any steering part other than the idler arm or the pitman arm, you will have to have the front end aligned. If the steering all looks good, jack it up one side at a time with the jack under the lower control arm and try to rock the tire with your hands at 12 and 6 o'clock. Next, use a prybar to try to "lift" the tire. This checks the ball joints. If there is any play rocking it, they are bad. If there is more than a little (1/4" or less) play with the prybar, they are bad. Of course, use caution jacking and be sure to place a jackstand so it will catch the truck if it should slip off of the jack or the jack fail. Good luck.
Apr 26, 2010 | 2002 Chevrolet Silverado 1500
Play in steering wheel replaced upper and lower ball joints and out and inner tie rod ends. what next?
raise the truck and have some one rock the steering wheel back and forth while you look for excessive movement at the idler arm - also check is the input shaft on the steering gear box rotating more than the output(pitman arm side) i've seen more steering box failure in the last several years especially true with big tires or boggy road driving, a rebuilt box can be bought at a local parts store- o'reillys, advance, napa etc.
Nov 23, 2009 | 2001 Chevrolet Silverado 2500HD
Good Luck!
May 14, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
Kenmore Elite Ultra Wash Dishwasher - top rack arm not spinning
Hi: I just posted a similar problem, but found a solution. After taking the arm, etc. apart (and verifying no blockages), I thought maybe the lack of water pressure was being caused by the fact that there are TWO holes for the top spray arm (higher and lower rack setting) on my model. ie. that water was being forced out of both holes, causing a drop in water pressure, which was causing the top spray arm to stop spinning. I plugged the unused hole with a wine bottle cork (to keep the water from spraying out the unused hole), and voila, it now works.
I wish all appliance fixes were this easy...!
S
Jan 17, 2009 | Dishwashers
Dishwashers Logo
Top Dishwashers Experts
