Question about Woods Hardware & Accessories
My time arrow sticks on my woods 59730 relocatable outdoor timer. How can I fix it. Thanks.
Cleaned rotating mechanism with electronic cleaner
  • Woods Master
  • 5,089 Answers
Does timer still work?
Time now is just a locator so dial lines up correctly with current time
Line up current time with 1:30 position on dial.
http://waterheatertimer.org/images/GE15107-004-8.jpg
Gene
Water Heater Timers Save Money
Posted on Dec 02, 2014
3 Suggested Answers
SOURCE: woods industries outdoor mechanical timer 59730, I
I found a manual for this yard stake:
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
There is a switch located on inner dial.
Move switch to TIMER
Posted on Dec 10, 2010
SOURCE: how do I set the
Woods 59730 is24-hour 6-outlet yard stake with dial located on top
This timer is identical to GE15107 yard stake
Manual.
If this is not your timer, look at following page to identify your timer
http://waterheatertimer.org/Woods-timers-and-manuals.html
Add a comment any time
Timer instructions.
Set current time by rotating dial until time lines up with arrowhead located on inner dial
There are segments located around dial.
Look at inner dial > segments are located just outside the inner dial.
Timer comes with segments pushed inward.
To set timer to turn ON, pull segments outward for hours you want timer ON.
All 6 outlets are controlled by timer.
Last step:
There is override switch located on inner dial.
Move switch to TIMER for timer to operate.
Woods 59730 6 plug outdoor timer. Hour arrow is stuck and rotates with the outer dial. How can I fix it. Thanks.
Spray WD40?
If the timer still works, then the loose part should not be a problem.
The time-now arrow points at about the 1:30 position.
You can rotate dial until current time lines up with approximately 1:30 position.
Gene
Nov 29, 2014 | Woods Hardware & Accessories
Brand new Woods Timer (Model 59730) turns on/off correctly, but completely stops during "off" hours every day. When I reset the current time, it runs for about 8-10 hours, then stops. Returned...
It seems odd that you'd get two defective timers.
I bought one of these timers from Home Depot under the GE brand and the dial rotates correctly as time passes.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59730
Woods 59730/ GE 15107 timer is a mechanical timer, so circuit problems should not affect clock motor.
On electronic timers, if circuit is not clean (circuit has ground fault), then timers don't last long and do peculiar things.
My suggestion is to try timer on indoor plug, on a different circuit breaker, for 1 day and see if it keeps running.
This will tell you if outdoor plug might have a loose wire, and that electricity is getting cut off.
Add a comment and tell me what you discover, or add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 22, 2011 | Hardware & Accessories
Wood timer 59108. We do not have manual and don't know how it works.
I don't have 59108 timer listed for Woods.
1) Woods makes 59018 White-colored in-wall digital 7-day timer
http://waterheatertimer.org/pdf/Woods-59018-59028.pdf
2) Photo that you posted question with is Woods outdoor 59204 or Woods outdoor 49109
These timers have a dial on face of timer.
Rotate dial until current time lines up with arrowhead.
Segments located around edge of dial are used to set times.
Move segments up-down (49109) or in-out (59204) to set on-off times
Move override dial (49109) or override switch (59204) to Timer, or timer ON so timer will follow programming
If above is not your timer, link below shows all Woods timers and manuals to help identify your timer
Dec 10, 2010 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
How do I set the woods outdoor timer model #59730
Manual.
Timer instructions.
Last step:
Dec 09, 2010 | Woods Outdoor Lighting Timer
Lost direction on how to set the timer
You posted under Woods 59383
Manual for 59383:
http://waterheatertimer.org/pdf/Woods-59383.pdf
If you have different model Woods timer, see link below, or add a comment.
To set Woods 59383:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Segments located around dial control on-off times.
Pull segments UP for OFF times.
Leave segments DOWN for ON times
Set manual override switch to arrow-down position
Switch unit to ON position.
Plug in timer.
Plug lights into timer.
If lights have switch, switch must be ON.
Max load 500 watts
50-mini-bulb string of Christmas lights is 25 watts
Dec 01, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
LOST MY INSTRUCTIONS ..... HOW DO I SET THE TIMER?
You posted under Woods 59204 outdoor timer.
If this is not your timer, add a comment.
manual for Woods 59204 timer
http://waterheatertimer.org/pdf/Woods-59204.pdf
Instructions:
Rotate dial until current time lines up with arrow.
48 segments (or pins) located around edge of dial > each segment is 1/2 hour
Set ON-off times by pushing pins in or out
Pins pushed out = timer ON
Pins pushed inward = timer OFF
Plug in timer.
Maximum 1250 Watts.
50 mini-bulb strand of Christmas lights is 25 Watts.
Timer will operate 50 strands of 50 mini-bulbs.
Long-winded guide for Christmas light wattage:
http://www.christmaslightsetc.com/pages/how-much-power.htm
Nov 29, 2010 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
I need instructions on how to use my outdoor timer for the model59733 the other number is 23uld/3ao
59733 appears to be Woods timer number, but Coleman Cable CCI does not have 59733 manual.
Internet search turns up no Woods 59733 number.
There is a Woods 59730 outdoor timer stake, but I can't find manual for 59730 either.
http://www.acehardware.com/product/index.jsp?productId=4433644&CAWELAID=604875525
I do not have 59733 timer photo or manual.
But some Woods timers go by more than 1 number.
Check if your timer appears on following page:
Woods also has promotional line of timers sold in retail stores, and many of these timers carry Woods name but nobody has on-line information.
If I find manual or more information I will post on this thread.
I can't find the pins that the instructions refer to.
Woods timers:
1) You posted question under Woods 59383 which has segments located around edge of dial.
These segments are pulled up to set OFF times.
Segments are left in down position for ON times.
2) Other Woods timers have tiny pins that stick up on the dial.
Pins are located on part of dial that rotates.
Get your glasses.
Run your finger across the dial and you can feel tiny metal pins that stick up.
Dial has 48 pins. Each represents 1/2 hour.
Use fingernail to move pins outward from center of dial.
Pins out = timer ON
Pins inward = timer OFF
Below are 2 EXAMPLES of Woods timer showing pins and segments
Nov 23, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
Hardware & Accessories Logo
128 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
