Question about Home Security
How do I program the arm and disarm code of my HomeSafe HA-125A Infared Motion Detector with Security Alarm
I forgot the code and do not have the instructions
SOURCE: problem arming all sensors on ge simon security
I have yet to test it but I think I've figured it out... I spoke to the place I bought the alarm from and he stated that for both the door/windows & motion to arm, you have to leave the house (or activate an exit door) or the alarm thinks you are still in the house. Since the motion is instant on, this prevents you from accidentally setting off the alarm if you armed it and never left.
So what if you want to arm both and stay inside? There is an option called Unvacted premises (in the Timers menu). It's on by default and makes the alarm behave as described above. Set this option to off and you should be able to set both and not leave the house.
James
Posted on Feb 10, 2009
robmcd27
  • 423 Answers
SOURCE: how do I get into the program mode to activate motion detector
Remove the mounting plate (on the back) and press the button, or trip the tamper.
Posted on Feb 11, 2009
  • 43 Answers
SOURCE: I cant disarm my alarm
Get inside the car, turn the key to the on position, the alarm is going to sound so do not panic when the alarm sounds press the valet button one time and the alarm should stop. To place the alarm in valet mode cycle the key with the door open on then off then press the valet button one time and the alarm should go into valet mode meaning the alarm light will be on steady.
Posted on Apr 01, 2009
  • 3 Answers
SOURCE: Motion sensor disarms itself
the system is set up to bypass the motion if a door hasnt been opened during the exit delay. you can either open and close a door everytime you arm the system or if you have access to the installer you can delete option 52 and that will fix your problem
Posted on Sep 28, 2009
  • 16 Answers
SOURCE: Paradox 525D Motion Detector wiring up
nc c + - Y G Tmp Tmp
nc and c is relay output normally closed
+ and _ is 12vdc input
Y and G is bus connection
Tmp is tamper output also normally closed
Posted on Apr 13, 2010
To turn the beep sound off when system is set to armed
Troubleshooting FAQs - Solve Problems Quickly by ...
www.adt.com/help/faq/troubleshooting
The ADT CorporationHow do I silence low battery beeping? ... Why is my ADT Pulse security systemreceiving an unavailable message? ... How do I fix a disconnected camera? ... by a motion detector while the system is armed, the burglary alarm will sound. ... Some common events that may cause a motion detector to set off a false alarm ...
Five Steps: How to Stop a Beeping Security System
https://www.vectorsecurity.com/.../Five-Steps-How-to-Sto...
Vector SecurityFeb 9, 2015 - The shrilling sound of a continuously beeping security system is enough to drive anyone crazy. A power outage, faulty wiring or bad batteries ...
The Top 15 Questions about ADT Home Security Systems ...
zionssecurity.com/...security/the-top-15-questions-about-adt-home-securi...
Oct 10, 2012 - How do I turn off the voice descriptions but keep the chime sound on?... If your time on the Lynx system is not set all you need to do is push your user code + # + 63. ..... When our security alarm is not armed it beeps every few seconds ....Reasons to Install Security Cameras in your Home ยท Small Business ...
Jan 03, 2016 | Home Security
Tip
How to Operate a Home Security System Without a Contract
Many homes have alarm security system installed, even though the current tenants may not have been the ones who paid for it. Some did pay for it but just can't afford the high monthly cost of alarm monitoring. Many people don't realize that once the alarm security system is installed only the monthly monitoring fee stands in the way of free home security. The alarm system still works without monitoring, and it is easy to configure on your own.
  • Install the dial capable motion detectors in place of the entryway motion detectors. The mounting directions and hardware will be included in the motion detectors' packaging. Often the old motion detector's hardware will mount the new one.
  • Connect phone lines to the new motion detectors as instructed by the manufacturer. Usually the lines connect from the new motion detectors to a phone or third-party dialer.
  • Program the dialer or the dial-capable motion detectors to dial the phones of your choice. Your cell phone is usually the most important phone number to program into the dialer to alert you quickly if there is an intruder.
  • Arm the alarm as you normally would. If there is an intruder, the new motion detectors will sense the movement and will dial your phone to alert you.
  • Tips & Warnings
    • Consider replacing the motion detectors that cover the windows and alternate entry and exit points, especially if you have a large home or one with several different entry doors.
    • If the dialer-enabled motion detector is capable, program a second and third phone number into the dialer to maximize effectiveness. Dialing your cell and your neighbor's home phone, for example, would be more effective when you are away from the area.
http://www.securityalarmchina.com/
on Mar 29, 2016 | Home Security
When arming doors/windows and motion, after the time delay and actually arms, the motions light goes off.. why only doors/windows arm and not motion too?
Is this alarm part of the original car or an add on? Some alarms have different zones that can be activated or deactivated depending on the preference of the owner. If it is aftermarket you will need the manual to execute a sequence to arm or unarm the motion detector zone. The motion detector could be faulty and the alarm is isolating that zone. Need more information to help you
Jul 06, 2015 | Cars & Trucks
How to ARM and Disarm a self contained ALARM system
An alarm that only sounds for a couple or three minutes, easily defeatable by way of crowbar on plastic? come on.
Nov 30, 2014 | Cars & Trucks
False alarm
If it's showing alarm and the number 06, this means the panel believes zone 6 went into alarm. What's on zone 6, motion, door, panic button?
Nov 27, 2013 | Honeywell V15P-WLS - Ademco Vista15P...
We replaced defective 5828V which had burned out, though we had 1 year with it without any problems. This is on an Ademco 2100 wireless security system. The first replacement we received would randomly...
See if the 'disarmed ready to arm' status announcement on the 5828V only happens when you walk in front of a motion detector. If so - replace the motion detector with a new one as older motion detectors could cause this to occur on an intermittent basis.
Jul 23, 2011 | Honeywell 5828V - Ademco Wireless Talking...
I need to re-program the remotes to my alarm. It is a prestige aps255a. Just to lock and unlock all the doors. To arm and unarm is already programmed.
Huh? Pressing the lock button arms the alarm AND locks the doors. Pressing the unlock button disarms the alarm AND unlocks the doors. If this is not happening either there is an issue with the wiring from the alarm to the car or, with the vehicle's door locks.
Apr 20, 2011 | Audiovox APS255A Car 2 Prestige Platinum...
GE/ADT DIY system will not accept master code./beeps twice/2 hour
Press the system status button on the top right and the system should announce the error message that is keeping it from accepting the code.
Feb 17, 2010 | GE Security Simon 3 Wireless Home Security...
Ford factory alarm arm output and disarm output
I don't show this truck as having a factory alarm, is there maybe an aftermarket alarm in it
Dec 28, 2009 | Code-Alarm Code Alarm Transponder
Telko s002 manual
Nesecito manual programming! s008b of Telkes. Thank you now!
Sep 12, 2007 | RCA 25110RE3 Phone
Home Security Logo
104 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
