Question about Steel City Saws
REPLACEMENT BLADE INSERT FOR 35670
IT IS 11 YEARS OLD & STILL RUNS LIKE NEW. I USE IT ALOT AND THE INSERT HAS A PIECE BROKEN OFF OF IT AND IT IS ALSO WARPED. JUST LOOKING TO REPLACE IT AND THE SCREW THAT HOLDS IT DOWN
SOURCE: Jar blender blade bottom screw on piece
villaware 1-866-484-5529
Posted on Nov 20, 2007
SOURCE: Wolf Gang Puck 620 Food Processor - Broken Blade - Need replacement
You guys with the Wolfgang Puck processor, need to go to this website, they have what you need but not what I need, I need the spindel, the blade is $9.99 www.wpcookware.com
Posted on Oct 22, 2008
SOURCE: Need replacement part - S Blade/Chopper Blade
You can call Hamilton Beach Customer Service at 1-800-851-8900 from 8am to 6pm ET to order the S Blade. I called to get a price for my S Blade that broke on my 702R model food processor. They quoted me $15.99 plus tax. Now I am looking on the Internet for a cheaper price. Hope this helps.
Posted on Feb 24, 2009
breddi2
  • 126 Answers
SOURCE: Concrete counterbalance broken (Frigidaire FWT449GFS1)
Check with a company online called sundberg appliance parts, the counterbalance isn't hard to install and will definately be cheaper than new one.
Posted on Apr 23, 2009
  • 156 Answers
SOURCE: Makita 10 inch slide miter saw problem
Is this it? If not, go to Makita site & download image of your saw. Hope this helps:http://www.makita.com/en-us/Assets/images/Products/_PartsBreakdowns/PB_LS1214FL.pdf
Posted on Jul 06, 2009
How do you install new blades on a DW7332?
unplug the saw/remove battery
press the button on the side near the blade
pull old blade out. push new blade in, release button to lock new blade in place.
Jun 06, 2014 | Saws
How do I attach the replacement blade on my B&D jigsaw model 7504? I have the replacement blade but don't know how to attach it....
Locate the small hole with the screw inside it directly above the handle, which usually is in line with the blade. Loosen the screw with a flathead screwdriver. Once the screw is loose, gently pull the blade out from the unit .. this works with older Jigsaws for newer ones ,,Locate the release button just above the portal where the blade enters the body of the unit. Depress the button and gently pull the blade out from the unit.
Insert the new blade into the same portal that the old blade was removed from while depressing the release button. Ensure that the new blade is facing the same direction that the old blade faced. Once the blade is fully inserted into the portal, let go of the release button.
May 13, 2011 | Black & Decker Vacuums
How do I change the blade on a GBC AccuCut A400pro paper trimmer?
You have to pop/pry the blue plastic cover off with a screwdriver blade or something similar. The you unscrew the silver colored piece, then there is a piece of plastic, usually gray, which has a magnet on it, land clinging to the magnet will be your old blade. Remove old blade--watch your fingers, and you can use the magnet to get the new blades out of its plastic case. Align blade and gray magnet--there is notch at the top, put the screw back on and pop back the blue pastil cap. Voila I ran into the same problem until I realized the directions were on the cardboard backing of my replacement blades. DUH!
Oct 11, 2010 | Office Equipment & Supplies
Blade keeps falling out when jig saw is started?
ther could be an old peice of a broken blade stuck in the collar were you insert new blade
Oct 07, 2010 | Ridgid 26638 Saw R3121 Orbital Jigsaw
Dehumidifier runs but doesn't produce water
Your dehumidifier has a circulating fan that draws the room air over the coils. If there's no air movement out the front or back of the unit, the fan motor may be burned out or stuck, or the fan blade may be broken. If so, you need to replace the fan motor or the fan blade.
Sep 04, 2009 | Kenmore 5230 Dehumidifier
I need to buy a blade tool to remove and to tighten the blade in my Jack Lalanne juicer. Where can I get a replacement?
Just find a big wire bend it and insert both ends on the blade holes. Use leather gloves or cover the sharp blade with a piece of cloth.
Mar 15, 2009 | Jack Lalanne Power Juicer 250 Watts
Looking for Metal blade in Black and Decker -BL12475G
If it is 2 yrs old,Just call the customer service,they will give you the parts for blender for lesser price or else go for new one.
Apr 27, 2008 | Blenders
Need replacement motor for Ventamatic Attic Fan
common motor. get from butler ventamatic or Johnstone Supply if you have an account. Hint, buy a whole new fan for $60; cheaper then buying piece by piece, then you get a new blade,motor and tstat for a little more then motor alone costs.
Apr 26, 2008 | Ventamatic Gable Mount Power Attic...
Acme Juicer
Are both of the metal parts that you twist the top onto still sturdy? One of mine is broken, and I have to find a replacement part.
Jan 18, 2008 | Acme 5001 Supreme Juicerator Juice...
Saws Logo
48 people viewed this question
Top Steel City Saws Experts
raysaw
ray gallant
Tom Chichester
Are you a Steel City Saw Expert? Answer questions, earn points and help others
