Question about Lionel Polar Express Train Set - G-Gauge
Polar express g gauge will not run. Replaced batteries, cleaned wheels on engine, but still no go. Sometimes doesn't pull at all, even with just the coal tender (no passenger cars). Sometimes goes
Polar express g gauge will not run. Replaced batteries, cleaned wheels on engine, but still no go. Sometimes doesn't pull at all, even with just the coal tender (no passenger cars). Sometimes goes a few feet around the track before shutting down. Any ideas?
  • 3,904 Answers
Sounds like a track connection not completely together. Put a meter on various points on the track to find where it is not completing the circuit.
Posted on Nov 30, 2014
Testimonial: "Hi Jerry, thanks for the response, but this particular train is battery operated. The tracks aren't wired. The coal tender holds 6 c batteries and then plugs into the engine unit to power the engine. I did some tinkering and figured the batteries might be fitting too loose. So I inserted a couple pennies to firm up the connections. Also taped the plug to the engine firmly with electrical tape. Not as much power as it used to have, but is now working a lot better."
Only runs in reverse, why?
Polar Express only runs in reverse ' O Gauge Railroading ...
ogrforum.ogaugerr.com/topic/polar-express-only-runs-in-reverse
Dec 7, 2011 - Polar Express only runs in reverse ... At this time of the year all Polar Express trains are programmed to run North only. ... This would not be so bad on the Strasburg set because half the time, the prototype runs in reverse.
both trains only go backward - Classic Toy Trains Magazine
cs.trains.com > ... > Forums > Toy train operating and collecting
... trains that i set up around Christmas. The first train, according to the box, is a k-line 0/027 gauge dual motor mp-15. For a long time it has only run backwards.
no forward only reverse - Model Train Forum - the complete model ...
www.modeltrainforum.com > Scale Specific Model Train Forum > O Scale
Oct 18, 2009 - 10 posts - ‎3 authors
There are two switches under the cab; they have no effect on forward motion. This setis 2 or 3 years old and has been run maybe 1 hour total. New Athearn HO Locomotive won't go in reverse ...
Mar 5, 2015
Lionel Rio Grande 8213 only runs in reverse - Model ...
Nov 18, 2013
More results from www.modeltrainforum.com
Jan 01, 2016 | Crafts & Hobbies
Led blinks when train put on track
I am assuming you are using the Lionel CW80 power source. If so, the blinking light might indicate a partial short or a problem with the motor. The reason I believe that is that the CW80 has an internal fuse, which will blow for near shorts/shorts. A stalled motor i.e stuck drive gear, can cause excessive power drain although not enough to blow the internal fuse and also cause the engine not to move. Also, If the engine has the neoprene belt on one of the drive wheels it might have come off and is jamming the running gear or wheel. I believe the Polar Express only has one neoprene belt.
Feb 10, 2015 | Lionel The Polar Express Train Set
Battery operated polar express engine does not work
these are all basically at the same time in sequence,
1. test batteries, need at least 75-80% power for train to operate at all. will be very weak but should operate. or use known good batteries.
2. next are the battery contacts. a lot of time the positive contact gets bent so far it either makes no or very weak contact, simply bend it back out very carefully to make better contact and clean it with a little rubbing alcohol of nail polish remover and a q-tip.
3. next would be the switch for continuity and then loose or broken wire.
after that you can email me for further help.
billybats10@yahoo.com
Apr 18, 2014 | Lionel G Battery Operated Polar Express...
Engine runs slowly or not at all
CLEAN wheels, roller pickups & track.
Mar 13, 2014 | Lionel The Polar Express Train Set
Lionel o guage polar express set transformer has a bell button but don,t work no sound
IfIam correct, the basic Polar Express came with just a whistle. There is an optional coal tender that has a better sound system in it...Whistle bell and steam sound also try reversing the power wires at the transformer or track
Mar 11, 2014 | Lionel Trains The Polar Express O Gauge...
Take wheels off polar express
You will have to solder them using a pencil soldering iron.
Feb 13, 2012 | Lionel The Polar Express Train Set
There is electricity coming from the tender of the Polar Express O gauge but the engine does not run. Is there somewhere to send it for repair?
Check with the store you purchased it from. If they don't repair trains they should be able to direct to one that does. You're not the first person to need repairs so they will know.
Jan 25, 2011 | Lionel The Polar Express Train Set
How do i get battery out of polar express train
There is a screw down deep inside the chimney. Unscrew it and it slides off.
Aug 29, 2009 | Brio Polar Express Battery Engine
Guages when crazy. Now won't even try to start.
You likely have it repaired by now but it sounds like a classic case of oxidized battery or cable connection (sometimes mis-diagnosed as bad battery but cured with new (clean) battery)
Feb 25, 2009 | 2002 Jeep Grand Cherokee
Lionel Polar Express Train Set - G-Gauge Logo
103 people viewed this question
Top Lionel Video Game Consoles & Games Experts
James Wishart
Are you a Lionel Video Game Console and Game Expert? Answer questions, earn points and help others
