Question about GE GTWN7450DWW 28" 4.6 cu. ft. Capacity Top Load Washer With
How do I reset GTWN7450DWWwasher after code H2O supply comes on?
Clean out the screens on the hoses
  • GE Master
  • 5,102 Answers
If the water supply valves are open, turn off the valves and disconnect the hoses. Replace the hoses. (You may have flood-prevention hoses. When these fail, the hose actually restricts water flow to avoid flooding.) If you want to test this, try placing a bucket under the inlet hoses and opening each valve in turn. Check how fast the water fills your bucket. Make sure that you cleaned the filters at the washer inlets and at the supply valves.
If the valves were closed, try running the washer with the valves open.
If that doesn't help, the flow meter valve has possibly failed or another part in that system has failed. This is part 805 on the tub and lid diagram here: https://www.geapplianceparts.com/store/parts/assembly/GTWN7450D0WW .
To purchase the part from GE, go to https://www.geapplianceparts.com/store/parts/spec/WH13X10057 . It is available at other appliance parts suppliers. The price is similar at the vendors that I consider using.
I hope this helps.
Posted on Nov 30, 2014
H2O supply and Tub will not fill in Ge Washer
First make sure someone didn't turn off the supply valves where the washer hoses are attached to. If both are on, then try to fill machine and switch between hot and cold water. If one of the 2 temps works, the other half of the fill valve is bad. The fill valve is the part where the hoses attach to the back of the machine. It is a 2 part electric valve with 2 electric coils on the valve. Could be one coil is bad or possibly the filter screen is blocked on one side. Screens can be checked and looked at by removing hoses and looking inside end of valve. If coil is bad, complete valve needs replaced. Easy exchange, a few screws, 4 wires, and a small hose leading to inside of machine.
Feb 22, 2015 | GE Washing Machines
I have code fh
Hey Lukec,
The FH error code on your Kenmore Elite washer indicats that there is a problem with in-coming water flow. When the water feeding the washer is less than what it should be, the FH code will trigger and the washer will shut down.
You can check a couple of common problems that can manifest this error code after resetting the machine. Steps for reset and diagnostics can be found below.
  1. Using the "Pause/Cancel" button on the washer control panel (this button will be below the digital time clock, to the lower right of the wash cycle selector) by pressing the "Pause/Cancel" button twice to cancel the wash cycle.
  2. Next, unplug the washer from the wall socket (this will reset the error code).
  3. Several things you can do to troubleshoot the follow issue are these:
    Check for kinks in the water supply hose.
    Turn off the water supply (hot and cold) and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  4. Reconnect the water supply hoses to the washer and turn on the water supply.
  5. Plug the washer cord back into the wall outlet.Select the wash cycle and press the "Start" button.
If the error code returns, you will likely have internal water flow issues due to the pump or other internal problems which may require a service technician.
Hope this helps.
Oct 03, 2014 | Kenmore Washing Machines
I was getting the F H error code on my washer. I hit cancel twice to clear the code to see of a cycle restart would remedy. Now the wash cycle is stuck on 45 min. remaining & the cancel button is no...
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code.
  • 1 Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3 Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
  • Apr 29, 2013 | Washing Machines
    Mah 6700 is stopping after 1 minute with a reading of NF
    Did you check the screens in the watervalve when you removed the supply hoses? They can crud up over time and restrict the flow. Clean them in-place with a toothbrush and spray bottle. Reconnect hoses and test. While testing move temp switch from HOT to COLD to WARM settings and observe flow of water and temp of water in each position. Cold may flow a little faster than HOT but should be close to same flow rate. WARM however should have twice the flow rate of hot and cold temps seperately. Let me know what you find.
    Jan 21, 2013 | Maytag Neptune Washing Machines
    I have a Epic Z Model # mhwz600tw00. When I select a wash cycle and press "start" it shuts off. It will complete a "spin" cycle without any issue. I checked the supply hoses and...
    Hello Jeff,
    Does the machine just shut off or do ya have a error code when it shuts off?? Typically when it will not fill with water for what ever reason their is FH error code. In addation to that since the cold water was clogged,very likely what ever caused it to clog up also has clogged the filter screen on the water inlet valve where the hoses attach to,to check/clean the screen remove the hoses and usea small screwdriver to pop out the screen and check/clean it. If ya find that the screen is clean ya may very well need to replace the water valve.
    Be sure to get back to me and let me know about what error codes come up and i could help ya to better narrow down the trouble with your washer.
    Thanks for using Fixya,
    Gene
    Feb 29, 2012 | Maytag EPIC MFW9700S Front Load Washer
    Washing machine takes a long time to fill and normal wash cycle takes 2 - 3 hours
    take off the hoses off the back there should be filter screens in the bibs(the hose attachments) take these out and clean them. You have a h2o restriction somewhere
    Aug 10, 2011 | Fisher and Paykel Washing Machines
    FH appears
  • 2
  • 3
  • 4
  • 5
  • If the error code come back you will probably have to change the water inlet valves. No hard to do and you can fdo this yourself
  • Dec 14, 2010 | Whirlpool Washing Machines
    Frigidaire Affinity ATF6000Es1 washer- Keep getting an alarm and an E10 code and have to restart the washer each time the code comes up.
    E10 code indicates there is no water supply.This can be confirmed by :
    1. Shut off the faucet to stop water supply to the washer.
    2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
      • Opening the faucet and watch for running water
    E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
    Oct 18, 2009 | Frigidaire Affinity ATF6000F Front Load...
    Error code e10 and ef0
    Aug 12, 2008 | Frigidaire Washing Machines
    Frigidaire Affinity Front load washer, Starts to Fill, then Flashes E10, Was wondering what this code is referring to
    May 19, 2008 | Frigidaire ATF6000ES Front Load Washer
    GE GTWN7450DWW 28" 4.6 cu. ft. Capacity Top Load Washer With Logo
    695 people viewed this question
    Top GE Washing Machines Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Are you a GE Washing Machine Expert? Answer questions, earn points and help others
