Question about Air Tools & Compressors
Can u put air in a tire with this type of compressor - the husky easy air air compressor 1.5 gallon y1000
    Sergeant:
    Champion:
  • 214 Answers
Yes, you will need a tire chuck to add air in the tire. And don't over fill the tire, okay?
Posted on Nov 29, 2014
RCtech
  • 55 Answers
SOURCE: manual for husky air compressor ''easy to go''
For what it's worth Compressors are intended to be turned on and forgot (except for the noise). just for grins lets assume you have the stapler and air hose. you need to hook up the air hose to the compressor there usually is one or to either couplers or npt fittings (threaded). attach the hose to the compressor and using a quick coupler (prefered because it allows the gun to swivel) connect the gun to the hose. turn on the compressor and wait for it to build up pressure and *******. at this point you will need to locate the regulator on the compressor. it will be a knob next to one or two dial gages. crank the regulator a quarter turn either direction while watching the gages. It (one of them) moved either up or down . now you know how the regulator works and your almost a contractor. on to the stapler, load it and find a bit of scrap (what your working on would be best.) now shoot a staple into something and see if it goes in far enough or to far. adjust the regulator to compensate. do this until one of three things happens A you find the right staple depth B the compressor kicks on again, wait for it to turn off C you run out of nails, beer or intrest in the project. once you have found the correct pressure for your needs. you may fire at will you don't need to wait for the compressor to cycle while running the stapler just during set up. now your a contractor go have a beer.
just a last tip if you find you don't have the correct couplers home depot, harbor freight or amazon (online) are great sources for parts.
good luck and mind your fingers
Rob
Posted on Dec 10, 2008
  • 47 Answers
SOURCE: Husky 1.5 HP 6 gallon compressor motor runs but
Your manual pressure release valve might be stuck open or blocked open by some debree. It should have a steel pull ring on the end of it. Exercise it and try running it again. Also the pressure regulator adjustment might have been backed off to zero. Crank it clockwise and see if this helps. Check the air output lines from the compressor to the tank for leaks.
Posted on Jun 22, 2009
digritz
  • 530 Answers
SOURCE: husky air compressor/1.5 hp
Compressors pull a lot of juice that is why they come with a large power cord. If you use a small extension cord with it it will easily pop a breaker. So first check all your breakers. Second thing is check your manual to see if you have a reset switch on you compressor, as most do. It should be a small, red switch (rocker or push button type), located between the pump motor and compressor switch. The third is a long shot, check to see if the bleeder valve is functioning correctly. It will be the small copper tube running from the pump to the switch. Just make sure the small lever is free to move.
If this fails to resolve the problem then it is probably the main switch itself. That is a warranty issue. If it's out of warranty then your going to have to either repair or replace the switch yourself. Please feel free to ask for help if you need it in latter case.
Posted on Jul 29, 2009
protek480
  • 1723 Answers
SOURCE: husky 25 gallon air compressor turns on and off Y6020-WK
Pressure switch setting is off. Readjust to Mfg. spec. (on @ 60/off @ 8o...)
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 03, 2009
  • 5 Answers
SOURCE: I need a new belt for my Husky air compressor but I don't know
You may be able to find the belt you need on ebay. There is a seller named "Footballcardcellar" who lists these often and they are alot cheaper than buying the kit from Husky. Just search "Air compressor belt husky"
Posted on Mar 28, 2010
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
    Free Husky Air Compressor User Manuals ' ManualsOnline ...
    powertool.manualsonline.com > ... > Husky > Power Tools Husky
    Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
    Sep 04, 2015 | Air Tools & Compressors
    How to adjust cut in pressure on husky 60 gallon
    what is the pressure switch model number, most of them have a nut with a spring under them, just turn the nut to adjust the pressure
    Oct 21, 2012 | Husky Electric Air Compressor: 60-Gallon...
    Husky 60 gallon compressor switch from 220 to 110
    Try here, very good for asking problems http://www.about-air-compressors.com/husky-air-compressors.html
    Jul 28, 2012 | Air Tools & Compressors
    Husky Manual for TF291201AJ
    Go to http://www.chpower.com/manualsearch/ (its the Campbell-Hausfeld website) and put TF2912 in the 'Find Model' search box and you'll get the operating instructions, parts lists and other information on your compressor.
    Oct 16, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
    Im trying to find brushes for my electric motor in my husky air compressor mod# 417-270
    I have not been able to find brushes for your type of compressor. I find a close match on ebay and shave/sand to size. Measure your brushes. Search ebay for "carbon brushes" looking for best price and size needed. Make sure that the armature is still good because the brushes will wear very fast if arm. is bad. Good luck
    Feb 13, 2011 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
    Husky 25 gallon air compressor turns on and off Y6020-WK
    Sep 03, 2009 | Air Tools & Compressors
    Piston snaped on my husky 1.7 hp 32 gallon
    I have had sad service with Campbell Hausfeld. You can go to their website, type in the model number, then ask for recalls on that model. My guess is there is no recall.
    If not, you might consider buying a replacement compressor motor to mount on that tank.. The tank is too good to throw away. Try Northerntools.com.
    May 07, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
    Air Tools & Compressors Logo
    Top Air Tools & Compressors Experts
    John Trevino
    JOHN LAPIER
    Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
