Question about Sears Kenmore Elite Electric Dryer 69278
How do I know the door switch is bad
I got power but the it won't start and is the light suppose to stay on even if the door is shut?
    Habit-Forming:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 75 Answers
If light stays on when fully closed, door switch needs replacement, easily removed. Short term fix, disconnect the switch and tape the two spades together. Warning! Dryer will run even with door open.
Posted on Dec 02, 2014
  • 34 Answers
No light is suppose to go off
Most likely switch is bad
Try to play with switch by tapping it in a rapped motion, this might temporary fix as the connections are bad Should replace
Posted on Nov 30, 2014
Dome light and key in ignition tone won't quit.
Yes, I would lean toward a stuck drivers door latch. Your door open switch is located in the latch itself and the ding is a reminder your key is in the ignition so you don't lock them in the vehicle when you lock the door. even though your door is shut, the truck still thinks it is open. sometimes spraying the latch with some WD-40 will get it freed up and working again, but a new latch might be in your future.
Apr 21, 2013 | 1997 GMC Jimmy
My parents bought a Haier HBF655TEME washing machine last year december. Last week it stopped working. The door light stays on continuously when clothes are put in and the door is shut and it doesn't...
It is possible that the door switch has failed as the bulb is ON even when the door is shut . This indicates that the SWITCH is not cutt off and so the program controller will not allow the module to go forward or work. It is needed that you start from this point to use a multimeter to check the switch/ poles contact to confirm.
Jul 01, 2011 | Washing Machines
Wont start are do nothing wont come on but light inside stay on all the time even when door close
Sounds like your door switch needs to be replaced. When the door is closed it is supposed to shut off power to your light, and send a signal to the timer that the dryer is ready to start. If your light is on with the door shut, then it won't start. Pretty simple replacement that you should be able to do yourself. Good Luck, Appliance Specialists
Dec 08, 2010 | Dryers
2005 Ford super duty 6 liter when I shut the truck off and pull the keys the radio power stays on along with the gagues and the check gauges light comes on. Even when I open the door everything stays on
It's suposed to stay on till you open the door even the power windows should work even with the key off and pulled the problem can be the door switch is bad unplugged or the wire to it where it goes thought the door hinge area can be broken. do any of the other door oopen and close functions work? Interior light work like it's supposed to? If not the switch may be bad but if any fuction of the switch works then it and it's wire are good. Is the check engine light on with the engine running? if it is this needs to checked out. The best way to find the problem is with a dianostic scanner in the body dianostic mode but eliminate the door switch first as they fail alot and it'll make it do it. In dianostic mode you can see all the door switches and there's one for every door and they all have to ge right and good or the system wo'nt reset corectly. The thing that can be bad and a scanner will find it is the GEM ( general electronic module ) sounds expensive? Most are less than $60 but some are bumping 200 it's find plug and play but sometimes with the scanner in acutor mode you can find a door lock motor or switch not responding and fix it and the system will then reset and it'll go back to normal. now rember I said any door switch not working, so agood reset involves window down doors closed and the hood open disconnect the battery and then lock all the doors close them good, All of them! Now conect the battery unlock the driver door with the key and then unlock it again the other door should unlock then too, if it doesn't this is on your list to fix too. The lock motors have to work or the systems door locked or unlocked switch won't know that it's still locked and the system fault will not let it work corectly. The GEM seldom fails and many are replaced and not fix the car so don't jump at it. Make the doors pass every thing first. Turn the key in the lock both sides if you have a passenger lock it has an unlock switch too, and it has to work as it reports if the door is locked or not. The remote unlocker need not work but it's nice if it does but it won't throw the system off.
Jun 08, 2010 | 2005 Ford F 250 Super Duty
Toyota Camry 1991 door light stays on
You need to readjust the switch on your trunk door, or replace. To check it locate it, tape it down with duct tape and see if the light goes off. If not it's bad. If it does it means it isn't sticking out far enough to be turned off when the trunk is closed. The adjusment should be fairly obvious. If not you can simply unplug it which has the same result as turning it off.
May 11, 2009 | 1991 Toyota Celica
Start button doesnt start the dryer
Sure sounds like a door switch to me. Is anyone slamming the dryer door? Was there a rubber bumper on the door that is now gone?
Mar 27, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Headlights staying On
You probably have a faulty sentinel switch. It's supposed to shut off, has a bult in elctronic timer. Does it even have the sentinel switch?
Mar 03, 2009 | 2002 Ford Explorer
2005 f150 "Door Ajar Light Always On.. Even with all doors shut..
What happens when you remove both switches, and wires? What happens when you use a jumper wire acros both wires, on both doors?
Feb 25, 2009 | 2005 Ford F-150
Sears Kenmore Elite Electric Dryer 69278 Logo
79 people viewed this question
Top Sears Dryers Experts
Dan Webster
Dan Webster
Big Texx
Big Texx
Level 1 Expert
Are you a Sears Dryer Expert? Answer questions, earn points and help others
