Question about Vehicle Parts & Accessories
It was a cheap battery.would you info on a better battery?
  • Brad Brown Nov 29, 2014
    Hi william r banks, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Habit-Forming:
    Scholar:
  • 83 Answers
The best thing to do is research the battery for your vehicle..just go into any battery site and type your vehicle type,year and model..Also depending on what climate you live the colder the higher COLD CRANKING AMPS..look for the CCA on the battery very good ones are in the 800+ range for colder areas,,warmer climate can be lessor..but many times the cost is little difference..so go for the highest CCA then Check best warranty ..Good luck
Posted on Oct 20, 2015
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Kindle Reader 5th generation. The screen reads :Needs Repair after I changed the battery.
did you buy an original battery or a cheap copy battery. as some cheap batteries don't have the info of the battery, and the kindle uses this to state the batteries voltage and its model number. if this does not have a info on the battery it thinks there is no battery installed..... also have you tried removing the new battery and checked the battery conditions on the board and the battery as the board can become damaged removing the old battery if not done properly
Jan 26, 2017 | Tablets & eReaders
What colour is the wire for the alternator warning light on the cluster
Why not buy a cheap volt gauge? It will come with instructions and give much better info than the dash light.
Jun 23, 2016 | Cars & Trucks
Is the roshan tv a good brand. want to buy a roshan 24inch led tv but I'm sceptical because I've never heared about the brand please help
Given the apparent lack of available info about that make and the likely relatively small price difference at that size, (guessing it's cheap?) my gut feeling would be to avoid and go for a better supported brand.
Nov 17, 2014 | Televison & Video
My tablet only stays charged for 5minutes
Check battery, battery plus should have it and can check it
Jul 18, 2014 | Tablets & eReaders
Low batter warning
Hi Kathy,
Wakie talkies are low powered, cheap toys for kiddies to play with.
Having said that, the problem is that you need to try using rechargeable batteries or lithium batteries.
These radios eat batteries, so the better the battery type, (more expense), the longer they last. I would advise that use be restricted to short periods at a time and to remove the batteries when not in use. Better still pay for a real CB radio and not have these problems.
CB radios can be obtained on ebay (Brand New), from as little as $125.00, the units come with lithium rechargeable battery packs and charger.
Cheers,
Peter
Feb 25, 2013 | Radio Shack Walkie Talkies 21-1864 Purple...
Haynes manual is ragged need better wiring diagram
Fixya has no wiring diagrams of any kind, sorry. You can buy the original factory wiring diagram booklet very cheap HERE I have no affiliation with this company just passing on the info to you to assist..
Jul 25, 2012 | Cars & Trucks
My laptop is Hp Pavilion and my battery doesn't charge though it shows that the power is plugged in.It's at 38% and when power is disconnect ,the laptop goes off.What do i do?
Sadly it seems you have a dead battery on your hands. If it's still under warranty i would advise to activate it and get a new one. If not, you can find cheap batteries on your local dealer (compatible ones may be cheaper but may void your warranty. If possible always use original parts).
Hope i was of any help.
Pcsimples
Mar 14, 2011 | HP Pavilion dv5-1138nr Notebook
What happened to the word FREE!
It's still out there
Autozone, advance and other parts stores do alot for FREE - change your wipers, test and reset your fault lights and they have tons of free info.
Better than a cheap cup of coffee..
Jan 04, 2011 | Ford Windstar Cars & Trucks
Hi, sinds a few days, the battery of my acer travelmate 6292 does not work well. The battery could last more than 3hours and sinds last week it is down after 40 minutes. What's happening ?
well they are 2 problems u have
first like everything if u use ur pc all the time on battery it will wear out,,,,like any other rechargeable battery ,,,,,and if u not charge the battery every night.....u will have not enough power left
also if u did not use the battery on the start when u got ur pc it will wear out..........as it not get used and not get recharged....sounds silly but i had the problem with mine......with not using battery power.....
if the battery not get better u better look for a replacment......not cheap......
Jul 03, 2009 | Computers & Internet
Vehicle Parts & Accessories Logo
46 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
