Question about Tamiya America ELECTRONIC F. AUFLIEGER (Tamiya America)
I bought new globes and checked the fuse , the fuse is ok as well as globes, butstill the reverse light doesdoesn't work, so u have menmentioned abt switches and modules where are situated in an audi
Reverse light problem, doesn't work, I bought new globes and checked fuse nothing help
  • 739 Answers
Check the 'reverse sensor' switch on the transmission or near the gear selector lever
Posted on Nov 29, 2014
I have 2015 the driver side headlight doesn't work changed the bulb and check the fuse no lights at all
I gather that the passenger side is still working? If so, I would check the connections to the Drivers side and also the earth connection to the body. Check the globe you fitted is ok by fitting it into the known working passenger side. If it doesn't light, you have found your problem, a new dud globe (Happens sometimes). Use a clean cloth whilst handling the globe, especially with halogen globes. They will blow pretty quickly if there is any moisture or residue on them from your hands.
Mar 22, 2017 | Cars & Trucks
What causes the reverse light not to light when im reversing my car
Hi .
Reverse light works on a switch that's is located on your transmission . so the problem is with the switch or fuse or maybe even globes are blown ? good luck.
Nov 27, 2014 | Audi A4 Cars & Trucks
Reverse lights only work sometimes on isuzu wizzard
Manual gearbox: check on right hand side of gearbox. There's an electrical switch(looks like large nut nut) with 2 wires coming out of it These wires have connectors toward the top of the gearbox, diconnect them.
The wires that this switch was connected to, conect them to each other. ie the reverse light switch has been bypassed. Put the vehicle in reverse. Turn on the ignition. DO NOT START. Check the reverse lights. If on the switch is faulty and needs to be replaced. If not measure the voltage across each of the wires and a good earth point. (Gearbox casing will do fine. ) One of the wires should read < 12V.
If 12V then
  • Globes are faulty(Replace)
  • wiring to the globes are faulty - unlikely -(This can be repaired by simply running a new wire to the globes)
If no 12V then the wiring to the fusebox is faulty. A quick fix is to run a new wire from the fusebox to the switch(Connect to fuse C-3, indicated as "turn, back")
May 31, 2010 | 1998 Isuzu Trooper
1999 Lantra - which fuse is for the reverse lights
may not have one because it could be hooked up to your ignition,so i would suggest that you check for power on the switch it self,if you got power both sides then remove your light globe and check if any power is there,if so replcae globes,if not check wiring from switch to lights.
Jun 18, 2009 | Hyundai Motor 1994 Elantra
Reverse lights not working on Hyandai Accent GS
On the side of your transmission will be a switch with several wires coming out of it. This is your reverse switch that turns on your reverse lights and most likely needs to be replaced
Mar 14, 2009 | 2000 Hyundai Accent
Reverse Lights
look for a reverse switch on the transmission
it might not be giving power to the lights
Sep 30, 2008 | 2003 Volvo S40
1997 mazda protoge 1.8 engine
check the actual globe is not blown
Jun 30, 2008 | 1997 Mazda Protege
Tamiya America ELECTRONIC F. AUFLIEGER (Tamiya America) Logo
85 people viewed this question
Top Tamiya America Toys Experts
ray gallant
Are you a Tamiya America Toy Expert? Answer questions, earn points and help others
