Question about Miele Washing Machines
Technical fault f53
Miele honeycomb care W722
5 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: need manual for Miele Honeycomb
You can get the manual on the link below.
http://www.miele.com.au/au/domestic/service/aftersales_operatinginstructions.aspx?product_type=W%203831%20WPS
Good Luck please rate 4 thumbs up and please leave a testimonial
Posted on Oct 24, 2010
ercupa190
  • 12223 Answers
SOURCE: miele honeycomb care w 1712 drain fault comes on every wash
see this possibles causes:
God bless you
attached diagrams
t spins, but doesn't pump
see line clogged and fix it.
It doesn't spin or pump
frozen pulley
It pumps, but the water returns
improve the drain laundry, if drain hose reaches more 4 inch cut off the excess
Posted on May 16, 2012
SOURCE: How do I fix a F53 fault ona Miele W1712 Washing
A call with the Miele tech helpdesk got me an answer: The tacho unit (coil) should have about 500 Ohm resistance, so they told me. My unit only had about 78 Ohm's, so I ordered a new brush unit (which includes the tacho). The new unit actually measures 250 Ohm, but since it was a new one I did fit it. It works like a charm again. No F53 fault code anymore.
The part no. is 6799642 - Module BSTV Mrt40 RK473. It cost me about 70 euro's including shipping. My machine is a type W3821, but the motor and brush unit with tacho is used on a variaty of models.
Cheers!
Posted on Oct 27, 2012
  • 76 Answers
SOURCE: Miele W1712 honeycomb care front loader the door
Try unplugging the washer's electrical connection, wait for about 20 seconds then plug back in. See if that resets your cycle to Start mode from an unfinished mode. If not, see if you start another cycle, such as a spin to complete any draining of water. It might have blockage that is keeping the water from draining thus thinking the cycle is not over - or- a bad sensor not telling the computer that the cycle is over and it's OK to release the door lock.
Posted on Nov 24, 2014
How do I fix F53
This is a speed sensor fault. Could be caused either by the motor itself (built-in speed sensor) or by an electronic fault.
What is most likely depends on your model. See Miele goedkoop repareren cheap repair preiswerte Reparature
Mar 03, 2015 | Miele Washing Machines
Technical fault
What is the problem you faces with this machine? Provide more details; please. http://electronicshelponline.blogspot.com/
Nov 29, 2014 | Washing Machines
Miele honeycomb care w 1712 drain fault comes on every wash
God bless you
attached diagrams
frozen pulley
May 16, 2012 | Miele Washing Machines
I have fault of f53 what does this mean
Hi, Below is a post by a previous fault to you washer, I hope this helps you. taurustech
  • Rank: Guru miele.gif
  • Rating: 92%, 159 Votes
i,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
All the credit goes to taurustech
Jul 15, 2011 | Washing Machines
What the meaning of f53 ptoblem?
Error code F53 on Miele is a speed sensor fault.
It has detected the drum speed to be wrong at some point and has indicated the problem to you.
Have you tried unplugging it. That will reset the computer.
If it's not coming up again after unplugging it, I'd not worry about it.
If it is coming up every time you use it, then you have either a faulty sensor, motor or pcb.
Miele are extremely secretive with information on their appliances and this makes it hard to diagnose accurately faults on them.
May 16, 2011 | Miele Novotronic W1930 Top Load Washer
How do I fix a F53 fault ona Miele W1712 Washing Machine
Cheers!
May 01, 2011 | Miele W1926A Front Load Washer
Need manual for Miele Honeycomb care w3831
Oct 24, 2010 | Washing Machines
Miele front loader washing machine W3275- error code F53- what does this mean?
hi,
May 21, 2010 | Miele W865 Front Load Washer
Washing Machines Logo
49 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
