Question about Moultrie Cameras
My Moultrie M880 game camera is set to take 3 pictures, so once I place the SD card in turn on and I have in a area with no moving grass or limbs the camera will take pictures non stop. I will check i
I've tried everything I can think of, resetting, going over menu set by step, but this is a new model and the setting are different for my other cameras so I'm just not sure if I'm missing something in the setup menu.
    Master:
  • 149 Answers
Post subject: Re: M880 problem Solved .... My Moultrie M880 game camera is set to take 3 pict - icon_post_target.gifPosted: Tue May 27, 2014 3:48 pm icon_user_offline.gif
First of all, ONLY USE THE STANDARD SPEED SD CARD THAT MOULTRIE ADVISES.
Second, DO NOT TAKE THE CARD OUT & USE A READER WHILE LEAVING THE CAMERA MOUNTED (this will lock up the camera).
Third when using a brand new standard speed sd card, DO NOT FORMAT THE SD CARD IN ANYTHING OTHER THAN THE CAMERA.
One could clear the camera by reseating the battery (take the battery out & put it back in). The reset button (up inside) is not always necessary for this.
You probably got a different speed card to somehow work & the camera malfunctioned. Bear in mind the aforementioned advice.
Posted on Nov 29, 2014
Testimonial: "Thanks, I'm using SanDisk 8GB Class 4 SDHC Cards. I will try what you listed. I think you hit it with the formatting the SD Card with the Camera because I did notice a few Cards are already set up with what I named a couple Cameras and those Cards will not work in other Cameras but then the two problem cameras will work fine sometimes and I bet it's when I place those Cards in. I need to go set up SD Card per Camera by Formatting each to each Camera. I'll let you know how it works. Thank for you help!"
SOURCE: Movie shoot time and size of SD card
Movies on this camera are limited to 2 GB size.
Posted on Sep 11, 2008
  • 374 Answers
SOURCE: Problem with taking picture with SD card
The only thing I can recommend is using the brands of memory cards that Casio recommends. They are Panasonic, San Disc, Toshiba. Make sure the card is formatted with the camera before use.
Posted on Dec 01, 2008
digitalriver
  • 3 Answers
SOURCE: Pictures won't record on SD card
maybe you are saving pictures to your camera internal memory,if so try to change it in settings for SD card,or it could be that your camera does not accept the type of sd you are using,try any other card and see
Posted on Feb 27, 2009
  • 296 Answers
SOURCE: Camera won't record on SD card
SD cards have become the industry standard....but beware...there are SD cards NOT backward compatible...i.e.,some cams won't take 2GB or larger; then there is SDHC; SDHC(HD); RUNS FROM 512G thru 32GB HC/HD; ECT...check your cams manual for SD card compatibility.
Posted on Feb 17, 2010
  • 296 Answers
SOURCE: Stops taking pictures after approx. 128-130
Hi, Sue,
Not really sure on this, but if where he bought cam will take it back,try it...
However, it may not be the cam, but different resolution settings on the two different cams. Digital cams by different manufacturers format SD cards using different means; some allow more memory space on card for formatting than others..and if the game cam is set at a higher resolution than the other cam, then the 2nd cam might use space 1st cam left avail.i.e., say cam "sets aside 4mb of memory to format card, but only uses 2mb of this space. Now, the game cam is set for high resolution and take 130 pics @ 15mb each..15x130=1950mb,+ 2mb left by game cam=1952mb(1.952gb), or about 50mb of space left on card...put it into cam set for lower res. and might get several more pics before card was really full...be sure all is equal...both cams, and card,ect. 128-130 pics @ high resolution ain't bad....on a 4gb SDHC card with my I-40's set for High Res., I can get 1000 pics;@ enhanced and I get only about 300. Set at low res., and # goes way up.Hope you understand all this.
ron
Posted on Feb 19, 2010
Menu screen nothing but lines.
Turn camera off, remove battery's and sd card. With everything out turn it to the on position for about 2-3. After 2-3 minutes put batterys back in while on the on position. Once he says no card or no memory turn the camera off put sd card back in and test the camera.
Mar 02, 2014 | Moultrie Game Spy D555i Trail Camera
Constant pictures taken
If you are using a Micro sd card you will need a Sandisk sd card that says sdhc nothing higher the class 4 sd card which is the speed of the card. If still need help call Moultrie with equipment to troubleshoot the number to call 8006533334 option 1 and 1 live person
Jan 03, 2014 | Moultrie A-5 Game Camera
Camera shuts down after 1-2mins an does not take pics
Just to let you I had Moultire m-80 when I used a pny sd card it ruined my camera. They were kind enough to replace it for me. I just use what they recommended do not have any more problems. I only delete pic on my computer and not digital camera. Try doing a hard reset take everything out turn to the on position for about 2-3 minutes after 3 min put brand new battery's in it while on the on position should say no card at this time. If doesn't turn camera off put sandisk sdhc card in it. Test camera again if still not working Moultire will help you I have talked them great customer service.
Nov 26, 2013 | Moultrie Game Spy M-880
IR Flash not working
Have you tried a hard reset? If not turn camera off and take out sd card. With everything out turn it to the on position for about 2-3 minutes. Then put battery's back while on the on position it should say no card once it says that turn off camera. Put Sandisk sdhc card not micro SD card then turn it on test camera in the dark and view them on a windows or a Moultire viewer 4.3.
Nov 24, 2013 | Moultrie Game Spy D-333 Game Camera
Resetting the Moultrie A-5 Game Camera
HARD RESET TAKE OUT BATTERIES SD CARD PUSH THE ON OFF BUTTON FOR ABOUT 5 SECONDS LEFT EVERYTHING OUT FOR 2-5 MINUTES. THEN PUT THE BATTERY BACK IN TURN THE CAMERA ON IT SHOULD SAY NO CARD. THEN TURN IT OFF THEN PUT THE SD CARD BACK AND TRY IT IN THE DARK AREA TO SEE IF THE FLASH WILL GO OFF. IF THAT DOESN'T WORK WILL NEED TO SEND IT IN FOR REPAIRS.
Nov 07, 2013 | Moultrie A-5 Game Camera
My pictures at night are nothing but a black picture
HARD RESET TAKE OUT BATTERIES AND SD CARD, TURN IT TO THE ON POSITION FOR ABOUT 2-3 MINUTES WITH NOTHING IN IT. AFTER 2-3 MIN PUT BATTERIES BACK IN WHILE WITH THE ON POSITION IT SHOULD SAY NO CARD. ONCE IT SAYS THAT TURN OFF THE CAMERA PUT THE SD CARD BACK IN TURN THE CAMERA BACK ON AND TEST IN THE DARK. IF THAT DOESN'T WORK SEND IT IN FOR REPAIRS TO MOULTRIE.
Nov 07, 2013 | Moultrie Game Spy D-333 Game Camera
Day pictures are now white and will take1good night pict then 5-8 are black. Camra is almost a year old. Was taking great Picts.
Do you have the camera set east or west? If you do you need to move to North or South if still not working do a hard reset turn off camera take out battery's and sd card push the button on/off button for about 5 seconds. Then put battery's back in leave the sd card out turn the camera on it should say no card. Once it says that turn camera off then put sandisk sdhc nothing higher than a class 4 speed of the card not the size. Then test camera again if still having the issue call Moultire 8006533334 option 1 and 1 for a live person.
Oct 30, 2013 | Moultrie Feeders Lx30ir Game Spy Camera
THE IMAGES CAPTURED AT NIGHT ARE SO DARK THAT WE ARE UNABLE TO VIEW THEM. WE CAN SEE SHADOWS IF DEER BUT CANNOT FIGURE OUT HOW TO GET AN ADEQUATE PICTURE AT NIGHT.
Turn camera off take out battery's and sd card. Once everything is out put it to the on postion for about 2-3 min. Then put battery's back in with the camera being on still leave sd card out. Once it says no card turn camera off then put sd card back test in dark. If still not working call Moultire 8006533334 option 1 and 1 for a live person.
Sep 30, 2013 | Moultrie Game Spy C-90I 10.0Mp Scouting...
My moultrie trail game camera d-40 will not store pictures on memory card. I have tried multiple memory cards. The card I have been using is not very old and has worked fine until now. Camera is showing...
Is the small switch on the side of the SD card pushed up toward contacts? Has the card been formatted by a PC(A NO-NO)?
Remove card;turn camera on..go to setup; press up arrow once to get "DELETE ALL IMAGES NO?";press select button to get flashing "NO"; press up or down button once to change flashing NO to flashing YES; press select once...should get "DONE";press select until back in "SETUP...Turn camera off insert SD card and try again...may need new SD card.
Oct 24, 2011 | Moultrie GameSpy 4.0 Digital Camera Deluxe
My camera MFH-I-40 is giving me a message that says, "internal memory full. Memory needs to be erased". I do not have my manual. How do I erase the internal memory?
Solution 1
Go to options and look for format.
Solution 2
Move all your pictures to a memory card and free all your internal memory space.
Jun 09, 2011 | Moultrie Game Spy M45 Digital Trail Camera
Cameras Logo
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
