Question about Hunter Dryers
Purchased Hunter ceiling fan. Purchased separate remote control. Is it possible to install the fan remote so you can pull the chains to operate in case remote battery is dead?
  • Hunter Master
  • 16,210 Answers
No, the remote control interrupts the current flow.
Posted on Nov 29, 2014
  • 51 Answers
SOURCE: Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Posted on Jul 25, 2007
SOURCE: ceiling fan
hi you have a problem with your fan do you have the remot book how to operate the fan remote we lost the booklet for the instruction maybe you can send me a copy of your booklet instruction for the fan is your fan is from the compagny home collection and the brend or model tampa thank you
Posted on Nov 25, 2007
  • 3 Answers
SOURCE: Hunter ceiling fan remote problem
You will most likely need to replace the receiver with a new one from hunter. The receiver is actually a complete controller and contains the receiver, relays (which you hear clicking) and starting condensors(large capacitors which hold a charge that is "dumped" over the windings to get the motor to start from a dead stop). These appear to be pretty tightly assembled unless you have a desire to start replacing parts "off the board."
Posted on Sep 07, 2009
SOURCE: Hunter Douglas Ceiling Fan Does Not Work
Try Cheyenne Lamps 2000 E. 17th Street Little Rock AR
501-374-2829
Posted on Dec 24, 2009
SOURCE: Hunter ceiling fan remote 85095-01 stopped working
it also could be one of the the jumpers fell out of the remote
they are located just above the battery. you will need to match the placement of the jumpers with the receiver mounted in the fan.
Posted on Mar 09, 2010
Is there a way to take remote controll off of a fan mine stoped working after kids pulled fan or light pull
My ceiling fan loses remote control every time there is a power outage. The first thing to do is turn off power to the fan at the circuit breaker. Take the battery out of the remote and push all the buttons to eliminate a stuck button as a possible cause. Reinstall the battery. Turn on power to the fan. Check operation. You may have to pull a chain to "reeducate" the remote but you should be back up and running soon.
Dec 31, 2012 | Hunter 52" Ceiling Fan With Light And...
How to sync the remote with the fan?The remote was operating the fan, but someone must have pulled the chain on the fan.
I have a ceiling fan that fails to operate under remote control whenever a power outage occurs. The solution is to pull the chain to guess which is an ON position, then operate the remote to select fan speed or off. Same routine for the light, if there is one.
Sep 04, 2012 | Hunter Fan Company 20184 H 52" Antique...
I have a hunter fan model 20754 i need to know how i can control the light and fan separately with a two wire switch
there should be a pull chain somewhere that you can turn off the light with. There is no way except a remote unit that a 2 wire switch can control 2 different functions(fan & light)
Mar 10, 2012 | Dryers
My hunter remote control ceiling fan doesn't go real fast. the highest speed is what a normal fan would do on medium. is there a fix?
if you have pull chain switches in addition to the remote control, your pull chain switch may be set to Medium, which would make the fan run on a maximum of medium speed.
May 16, 2010 | Hunter 52" Ceiling Fan With Light And...
I have a Hunter fan with remote. The fan or the light comes on by itself with no one around
See my post below: (Sorry, we're in the same boat)
Hunter ceiling fan with remote, have 5, 4 are seriously impaired! Lights dim to half strengh after variable time 10 seconds-30 minutes. And lights or fan turns on randomly (come home & fan on full blast), and one in which the lights won't dim (just blinks when try to dim)! Hunter "kinda" admits there is serious problem with remote but doesn't have a solution. Tells people to try changing to different code due to possible interference (pain in **** to change code on ceiling base!), was totally ineffective. Then replaced receiver in ceiling base (another total pain) in 3 fans with new ones sent Hunter, still totally useless. Hunter's suggestion, don't use the remote, just use the pull chain. If I had wanted a pull chain fan, I'd have bought a pull chain fan. TOTALLY USELESS! Moral of story: If you want a remote ceiling fan (my friend found out that all their remotes are made by the same company in Taiwan), don't buy Hunter!!!!! P.S. I found a "Kinda"- fix for the lights dimming to half strenth. After turning on the lights, wait 1 second, then dim lights slightly, they will then stay on the strength that you dim them to. - P.P.S. When I changed the receiver in the one where the lights won't dim, it "solved" that problem...Now it has the same problem as the others, lights or fan turn on randomly!
Apr 02, 2010 | Hunter 52" Ceiling Fan With Light And...
Pull chain for fan difficult to operate
All Hunter ceiling fans are "remote control" adaptable. Consider a remote control for it.
There are Nylon pull strings fitted with a ball clasps on the ends. Consider that, too.
Both at Lowe's or Home Depot...
Oct 01, 2009 | Hunter 22451 The Brookline Brushed Nickel...
Hunter ceiling fan
Jun 16, 2007 | Hunter Ceiling Fan Control Switch
Dryers Logo
70 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
