Question about Stanley Air Tools & Compressors
My compressor will not cut out when up to pressure what can the fault be?
  • 1,388 Answers
You have a pressure regulator somewhere on the unit that is adjustable for low pressure kick in and high pressure cutout. Turn the high side out after pressure is where you want it to cut off and it will do so. Low pressure cut in should stay where it is.
Posted on Nov 29, 2014
Where can I get a new pressure switch for my puma 6060 air compressor
Replace the pressure switch with generic switch available on ebay. You only need the port sizes and pressure cut in/out. If your switch cut out at 150psi or higher, you might consider replacing it with one that cuts out at 125psi to increase the life of the compressor (assuming that you can get by with pressure range of 90 - 125). Good luck
Feb 26, 2015 | Puma Air Air Compressors Puma Air PK6060V...
Where is the ac relay located on a 1994 ram van 3500?
It maybe a low gas pressure fault as low pressure will not allow compressor to drive.
May 26, 2014 | 1994 Dodge B Series Cargo
I have a craftsman air compressor model # 921.16472S. When it got to cut off pressure the bleed valve started blowing. I changed the pressure switch and bleed valve then lowered the cut off pressure. When...
Either the pressure switch is not shutting off when reaching the desired pressure or the pop off is either the wrong one or it is bad. Some blow off at lower pressures for single stage air compressors while others blow off higher for 2 stage air compressors.
Feb 11, 2014 | Craftsman Air Tools & Compressors
My ac is blowing hot air. I've checked the gas and it's full. The compressor seems to cut on and off about every 10-15 sec. Do I need a new compressor or do I have some sort of fault switch? Any...
Hello, You need to check how much Low end pressure you have. The Low pressure cutoff switch will disconnect the compressor if the pressure is too low. The high end pressure switch will do the same thing for extreme pressure.
Sometimes the Low pressure switch will get weak and cut off the system too early. Just change this switch which will come out with only a slight puff of Freon being lost. You can jump the connector with a U shaped wire and bypass the Low pressure cutoff switch. If the compressor works better and does not cut out, it can still be low on Freon or have a bad Low pressure switch.
However, if the compressor cuts out a Second time with the Low pressure switch bypassed, the system is probably overcharged and the HIGH pressure switch is cutting off the compressor. You need to purge some Freon out of the system if High pressure is indicated.
Where it gets tricky is the Compressor will compress both Freon and Atmospheric air. Your efficency drops when the Freon is displaced by Atmospheric air. You will need to find the leak in the system which is allowing Freon to leak and outside air to enter the system. You will get a pressure reading with any gas in the lines.
There are Leak detectors and sealers for the system. I hope you just have a bad low pressure switch which is the easiest solution.
Jun 25, 2011 | Ford F-150 Cars & Trucks
I HAVE A CRAFTSMAN 1 HP 12 GAL AIR COMPRESSOR THAT WILL ONLY BUILD 20 PSI THE COMPRESSOR ONLY HAS 1.5 HRS RUN TIME ANY SUGESTIONS
hi there, if the compressor built up a 20 psig and run at 1.5 hrs.then stop.check the pressure switch the differential pressure cut in and cut out limit.adjust the cut out to the corresponding cut out pressure you want but not exceed to the designed pressure tank..this will be done on adjusting cut out pressure screw mounted inside the pressure switch.follow the instruction on the manuals adjusting pressure switch.the run time correspond to the cut out limit of the pressure switch. rate my fix if your satisfied thank a lot.
Apr 20, 2010 | Air Tools & Compressors
How to test a pressure sensor switch on a air compressor
Hi, W/D here.
To accurately test a switch, it has to be removed from the compressor and tested by raising the pressure and lowering it with air supplied from a known, good regulator. The trip pressures are then noted and adjusted.
The quick and dirty way of "getting close enough" is a little different. Start the compressor, and when it gets to your desired cutoff pressure, pull the plug. Adjust the HP spring untill the contacts trip out. Now, with the compressor still unplugged, drain the pressure off of the tank until you reach your desired cut in pressure, and close the valve. Adjust either the LP cut in or the differential pressure adjustment to set the cut in pressure. The contacts will pull in. If you adjust the cut in pressure with the diff pressure setting, the cut out pressure has to be challenged and set again. Whichever method you follow, you always need to check the upper and lower settings after each adjustment.
Best regards, --W/D--
Aug 13, 2009 | Dewalt D55153R Reconditioned 1.1 HP...
DeWalt emglo compressor does not start
hello,
well,you have to release the pressure,the cut out pressure at 120 psig.reached,and the cut in pressure maybe at 40 psig.so after realeasing pressure at cut in the compressor will run.if the compressor not run at cut in or after releasing check your power supply if still have,swicth off power breaker,by pass pressure switch,by disconnecting the line on terminals of pressure swtich,connect the line w/out pressure switch
the wire line should supply the the compressor,
open the service valve of compressor,switch on
observe if compressor run and develop pressure or air is coming out to nozzle,if that so switch off again and replace pressur switch.you have defective pressure switch,regards rate me,thanks
May 02, 2009 | Heating & Cooling
When shutting down the compressor, oil comes out intake filter
hi there,
well,if your air compressor was shut off this due to pressure switch w/c auto switch off your compressor,the pressure switch acquired already the cut off pressure.if the pressure goes down the cut in set up reached it will start your compressor
to run.
regarding oil spillage when shutting down check the oil level on the sight glass of crankcase
a red line indicate oil should not exceed on that level line,if the oil exceed try to drain oil.,on the side bottom of engine there is a drain plug.until on limit level .,besure that machine is shut off/breaker is off.have a nice day don't forget to rate me,thank's
Apr 28, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
High/low pressure spring settings
Generally, the pressure switch is not adjusted more than once or twice in the life of the compressor since the discharge pressure can be adjusted with pressure regulator. However the life of the compressor can be increased if lower pressure settings are maintained. Your pressure switch was set at the factory to a setting of about 120 - 150. If your cutout pressure is higher than 150 surely lower.
STEP 1: Turn Main Calibration Screw ( center screw with large spring) clockwise to increase pressure and turn counter-clockwise to decrease pressure.
STEP 2: Turn Differential Pressure Screw (small spring) clockwise to decrease cut-in pressure and
turn counter-clockwise to increase cut-in pressure.
Differential Pressure is defined as the difference between cut-out and cut-in pressure. There should be about 7 to 12 psi difference between cut-out and cut-in.
In our shop we rarely adjust more than a couple of turns because these switches are sensitive.
Good Luck and please post again if you have other concerns about your compressor.
Jan 21, 2009 | Campbell Hausfeld 26 - Gallon Air...
Air Tools & Compressors Logo
94 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
