Re ZL202 - Why do the instructions say "do not install if there is not at least 30 feet between the electrical outlet and the electrical service panel"?
    Top Expert:
  • Televison & ... Master
  • 74,211 Answers
It is for nothing; but for security. If the wire length is much more than normal, it might cause some personal injury; electric shock and such. Electro help
Posted on Nov 29, 2014
How to replace oil; cooler on this year
  • Service and Repair
Oil Cooler Replacement
Removal Procedure
  1. Raise and support the vehicle. Refer to Vehicle Lifting.
  2. Drain the engine oil and remove the oil filter housing.
89116492
  1. Loosen the oil cooler outlet (1) and the inlet (2) lines from the engine block.
  2. Lower the vehicle.
  3. Remove the intake plenum.
  4. Remove the intake manifold.
89116493
  1. Disconnect the following electrical connectors from the water crossover:
    • The engine coolant temperature sender (2)
    • The engine coolant temperature sensor (4)
84936658
  1. Remove the water crossover bolts (1).
  2. Remove the water crossover upper and lower seals (2).
84942881
  1. Loosen the upper heat shield bolts on the left side of the exhaust manifold.
89116496
  1. Remove the oil cooler outlet line from the engine oil cooler.
  2. Remove the oil cooler inlet line from the engine oil cooler.
84942883
  1. Note the positioning of the 4 seals.
84972057
  1. Position the oil feed and return,lines out of the way and secure with mechanic wire.
  2. Remove the engine oil cooler, inlet and outlet nuts (1).
  3. Remove the engine oil cooler cover bolts (2).
84942883
  1. Remove the engine oil cooler cover.
  2. Remove the engine oil cooler.
  3. Clean all sealing surfaces.
Installation Procedure
84972056
  1. Install the engine oil cooler.
  2. Apply a 2 mm (0.08 inch) bead of RTV silicone sealant, GM P/N 12346240, in the groove around the engine oil cooler cover.
  3. Install the engine oil cooler cover.
Notice: Refer to Fastener Notice in Service Precautions.
84972057
  1. Install the engine oil cooler cover bolts (2). Tighten the engine oil cooler cover bolts to 30 Nm (22 ft. lbs.).
  2. Install the engine oil cooler inlet and outlet nuts (1). Tighten the engine oil cooler inlet and outlet nuts to 20 Nm (15 ft. lbs.).
  3. Reposition the oil feed and return lines.
84942883
  1. Install the oil cooler outlet and install the oil cooler inlet lines to the engine oil cooler. Use 4 new seals.
Tighten the oil feed and return lines to 30 Nm (22 ft. lbs.).
84936658
  1. Install the water crossover:
    • Position the crossover.
    • Install the upper and lower seals (2).
    • Install the water crossover bolts (1). Tighten
Tighten the water crossover bolts to 30 Nm (22 ft. lbs.).
  1. Connect the electrical connectors at the following locations:
  1. Install the intake manifold.
  2. Install the intake plenum.
  3. Raise the vehicle.
89116492
  1. Install the oil cooler outlet (1) line to the engine block. Tighten the oil cooler outlet (1) line to 30 Nm (22 ft. lbs.).
  2. Install the oil cooler inlet (2) line to the engine block. Tighten the oil cooler inlet (2) line to 30 Nm (22 ft. lbs.).
  3. Install the oil filter housing to the engine block. Tighten the oil filter housing to 45 Nm (33 ft. lbs.).
  4. Lower the vehicle.
Dec 22, 2014 | 2001 Cadillac Catera
Light keeps blinking
http://www.searspartsdirect.com/partsdirect/user-manuals/uh30010com-hoover-parts-vacuum-manual
WARNING: TO REDUCE RISK OF PERSONAL INJURY - UNPLUG CLEANER BEFORE SERVICING
PROBLEM POSSIBLE REASON POSSIBLE SOLUTION
2. Blown fuse or tripped breaker.
4. Thermal protector activated. (power
light is flashing)
1. Disposable bag is full. ("Check Bag"
indicator illumJnated red)
1. Disposable bag not installed correctly.
3. Brushroll is worn out.
2. Check fuse or breaker in home. Replace fuse/reset breaker.
4. Turn the cleaner off and disconnect it from the electrical
outlet. Then allow cleaner to cool for 30 minutes. If the
thermal protector continues to activate see Needs Service
solution #5.
1. Replace disposable bag - Pg. 9.
1. Review disposable bag removal and replacement - Pg. 9.
3. Replace brushroll - Pg. 10.
Mar 11, 2014 | Hoover UH30010COM Bagged Vacuum
Wiring outdoor motion lights (with 14/2) to a nearby outlet (possibly 12/2)that has power. After wiring into outlet and turn on breaker, I lose power, but don't trip the breaker?
First take a cord and hook it to the motion lite and make shure it works .Remember that it only will work at night or dark area and you have to have lights in the fixture to make the contact.and make shure the plug is not on a dimmer or the wires are flipped. WHT. To the common side and black to the darker side and it has to be grounded .exspeacily if it is a led fixture.
Apr 01, 2017 | Cooper Wiring Devices Motion Sensing...
Unlock Sony DVP NS725p
Ensure the child lock feature is disabled. Attempt to open the disc tray. If the issue is not resolved, turn off the DVD player. Unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet. Attempt to open the disc tray. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons or the RETURN + ENTER+ POWER buttons. If the issue is still unresolved, service may be required. The Sony eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Jul 24, 2010 | Sony DVP-NS725P DVD Player
I need the installation Instructions for a Kenmore 500 Dryer
While this manual is not for your specific Kenmore dryer, the Kenmoreinstall directions for the model in the manual will be the same. Start on page 5
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0502231.pdf
Nov 21, 2009 | Kenmore 500 6952 Dryer
Electric service requirements
Number 6 wire and a 40-50 amp breaker. Anything smaller will overheat and become a fire hazard, especially at 139 feet.
May 11, 2009 | Whirlpool Kitchen Ranges
We need to replace the adjustable feet and kernel drawer on our Nostalgia Electrics CCP-509 Popcorn Maker but cannot find an outlet to assist >
We are under new management.
Please call us at 1-920-347-9122 and we can help or you can visit our website at www.nostalgiaelectrics.com
We are more than happy to help you with the parts that you need.
Mar 12, 2009 | Nostalgia Electrics CCP-509 Popcorn Maker
How do you remove cover on sx270 optiplex to upgrade memory?
Opening the Computer Cover Dell™ OptiPlex™ GX260 Systems User's Guide
caution.gif CAUTION: Before you begin any of the procedures in this section, follow the steps in "CAUTION: Safety Instructions." caution.gif CAUTION: To guard against electrical shock, always unplug your computer from the electrical outlet before opening the cover.
  1. Perform an orderly computer shutdown using the operating system menu.
notice.gif NOTICE: To disconnect a network cable, first unplug the cable from your computer, and then unplug it from the network wall jack.
  1. Turn off any attached devices and disconnect them from their electrical outlets.
  2. Disconnect the computer power cable from the wall outlet, and then press the power button to ground the system board.
  3. Remove the computer stand, if it is attached.
  4. If you have installed a padlock through the padlock ring on the back panel, remove the padlock.
notice.gif NOTICE: Ensure that there is sufficient space to support the open cover—at least 30 cm (1 ft) of desktop space.
  1. Locate the two release buttons shown in the illustration, then press the two release buttons as you lift the cover.
notice.gif NOTICE: Open the cover slowly to ensure that you do not damage any cables. Raise the back of the cover, and pivot it toward the front of the computer
Jul 18, 2008 | Computers & Internet
Installing a whirlpool wall oven
You could call whirlpool and they can email you the instructions. Or your can go on whirlpool.com and enter your model number under the upper customer support tab.
Oct 23, 2007 | Whirlpool RBS305PDS Electric Single Oven
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
