Question about Shark Navigator Lift-Away Professional Vacuum Cleaner Model NV356 NV
Ihavea shark nv lift-away pro the brush dont spin an the light dont light up it caught a floor vent wean this started . is ther a reseat if so ware is it
  • Shark Master
  • 3,904 Answers
Sounds like you broke the brush belt. Easy to replace and most come with a replacement attached somewhere on the vacuum. The light is probably just burned out from the impact
Posted on Nov 30, 2014
Testimonial: "thanks for the input but the belt is fine."
2 Suggested Answers
small6363
  • 18402 Answers
SOURCE: instruction manual for shark model 3901k lift away steam pocket mop
click on the link below for the manual
http://www.sharkclean.com/manual/S3901K_N_11_IB_E_120410_3.pdf
Posted on Aug 20, 2012
How do I register my Shark vacuum Model # NV 752 31
usually have to go to their website to register products . that information will be with the unit when purchased new .
Jan 17, 2016 | Shark Rotator Professional Lift-Away...
The brush roll works for a second than red light goes on and it stops. No obstructions to stop the rotation
First make sure that there is no threads wrapped around the roller brush at each end. Next place a couple drops of motor oil in the crack at each end of the roller brush to lubricate the bearings. Do not over oil or you will get oil on your carpet. Now try starting the vacuum on the kitchen floor.. If it still shuts off, then the motor windings are shorted out, meaning the motor is defective and needs replaced. If the vacuum cleaner costs about $ 100.00 , you would be better off buying a brand new vacuum cleaner, rather than replacing the motor.
Oct 12, 2015 | Shark Rotator Professional Lift-Away...
The power head has a device to hold the power head together what does it look like?
Shark NAVIGATOR LIFT-AWAY PRO NV355 Owner's Manual
www.manualslib.com/manual/.../Shark-Navigator-Lift-Away-Pro-Nv355...NAVIGATOR LIFT-AWAY PRO NV355 Vacuum Cleaner pdf manual download. ...Shark ® Getting Started Navigator ™ Mode 1: Upright Vac Lift-Away ® Mode 2: ...Important Safety Instructions - ‎Table Of Contents - ‎Ordering Parts - ‎Maintenance
Sep 22, 2015 | Shark Navigator Lift-Away Professional...
My Shark vacuum is making a weird noise how to fix it
HI, it's Jim from Crucial Vacuum!
If your Shark Navigator Lift-Away Vacuum is making a loud noise while it's on then there's definitely a clog somewhere. Here' s a few places you should check prior to plugging in the vacuum and turning it on.
The first place to check would be the brush roll and belt. If you notice visible debris, like strands of hairs, or long carpet fibers this could be catching on the brush roll and causing it not to turn fully. Be sure to clear this debris from the brush roll and manually spin the brush roll a few times after you do so to help unearth and any other clogs. This may be the reason for the noise and its crucial that this part of your vacuum is clog free.
Another part of your vacuum to check would be your hose. Detach the hose and stretch it out as much as you can to see if any debris or clumps of dust are stuck inside. Using a broom handle can help if you see a clog, but it won't come out after you've stretched out the hose.
Another big factor would be a dirty filter in your vacuum. Most manufacturers recommend you change your filter on average every 3-6 months. However, it is recommended to change your filter even earlier depending on usage and allergy care. The cleaner your filters the less debris will get stuck in your vacuum, causing less clogs and overall less odd noises while vacuuming.
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=nv355
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jim Thompson
Crucial Vacuum Customer Care
Nov 23, 2014 | Shark Navigator Lift-Away Professional...
How do I installa new hose to the mortorized brush head on my shark lift waway
Hi, it's Allie from Crucial Vacuum!
Replacing your Shark Floor Nozzle Hose is very easy. Start by unplugging your unit to avoid any safety hazards. The floor nozzle hose's side that attached to the floor base of your Navigator can easily be pulled away. The other side of the floor nozzle hose has two tabs that can be pushed in while pulling it away from the base.
When installing, connect the floor nozzle hose to the canister first by pressing both side tabs while placing it until it click in its place. Then connect the hose to the floor base.
You can purchase direct your replacement hose and filters from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=NV352
Alejandra (Allie) Sepulveda-Rivera
Sep 10, 2014 | Shark Vacuum. Navigator Lift-Away Bagless...
Why is my Shark nv500 vaccum carpet brush is not spinning?
I am having the same issue. The brush won't even move when I turn it with my hand. I just posted this same question.
Aug 01, 2014 | Shark Rotator Professional Lift-Away...
Shark Navigator Lift-Away Professional Vacuum Cleaner Model NV356 NV Logo
606 people viewed this question
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
