Question about Dishwashers
How to fix door spring on kitchenair dishwasher
The door is very heavy now. I think the springs are broken.
  • 937 Answers
Here is a video on that repair:
https://www.youtube.com/watch?v=rtl4zG-6U9E
good luck!
Posted on Nov 29, 2014
  • 277 Answers
SOURCE: Broken Door Spring
hi you can do it if you have good hands open the cover side of the broken arm with the spirngs understand how the Mechanism works (in\out) and what went worng and hopefuly fix it or replace the springs that died good luck
Posted on Mar 26, 2006
RescueTech
  • 145 Answers
SOURCE: broken door spring?
Either a spring or a door cable. On newer Kitchenaids and Whirlpools, it is usually a "cable" made of rope and plastic that breaks, not the spring itself. Get me the complete model number and I will look it up for you...
Posted on Dec 14, 2008
SOURCE: Dishwasher soap container spring is broken
I too thought my soap container spring was broken- I filled the dispenser with soap but then couldn't slide the circle back shut.
But then - EUREKA- I set the dishwasher control back into "off" position and lo and behold, I could now close the little round door! Make sure you verify that BEFORE you spend $$$ on new parts or a repairman!
Posted on Oct 14, 2009
rickead1
  • 1998 Answers
SOURCE: Broken door spring on Kitchenaid dishwasher
you have to pull the unit totally out so you can access both sides of the machine you can order the parts from either marcone or allbrands applaince they mail the parts directly to you when you have the unit out you will be able to see its an easy fix of just replacing springs and cord if im remebering correctly theres only two 1/4 screws to loosen one on each side you will be replacing the glide rollers also in the kit they send you with the cord are the glide rollers
Posted on May 01, 2010
SOURCE: Repair door springs - LG dishwasher - LD-2040WH.
my lg door keeps on falling done something wrong with door springs ; how do i repair it.
Posted on Jan 13, 2011
The dishwasher door spring has snapped, the door is heavy, can I fix it myself?
Yes, you can repair the unit yourself. It will require removing the dishwasher out of the cabinetry to get to the spring cable. The spring is not the problem but the connector between the door hinge and the spring is broken.
The part you need is 4933DD3001B. You will need 2 of them.
Hope this helps.
Oct 29, 2011 | LG LDF6810ST Stainless Steel Built-in...
Door falls open
The side spring springs could have unhooked. Some springs connect to a nylon rope that slides over a plastic guide. The rope could also have snaped or slipped off the guide. You need to open the sides (normaly the back first) to check. This is easy to fix if you have the right tools...
May 11, 2010 | Bosch 24 in. SHU66C05 Stainless Steel...
Cannot open the door of the dishwasher.
  • The latch on many dishwashers is adjustable. If your door is easy to close but difficult to latch, adjust the latch to let the door close more easily. If you can't see any way to adjust the latch, yours may be fixed in a certain position. Check for other reasons for the latching problem.
  • If the latch has worn out in a way that makes it impossible for you to close the door properly, you probably need to replace the latch.
  • Your dishwasher has two springs that counterbalance the weight of the door. If either or both of these are broken, the door feels quite heavy and you need to replace both springs.
May 04, 2010 | Maytag 24" Tall Tub Built-In Dishwasher -...
Dishwasher door drops hard when opened.
Sounds like one of the doors springs is broken or has come detached from the dishwasher housing frame. If you have a plain dishwasher door, ie one that does not have a wood panel matching your cabinets, and the spring(s) are broken, new springs cost about $20. If you have wood panel on the dishwasher door, then you may need heavy duty replacement spring at about $22.
Jan 15, 2010 | GE Dishwashers
Nov 28, 2009 | LG Dishwashers
Door hinge spring broken
Yes, it can be fixed. Sounds lilke just a matter of either fixing or replacing hinges/springs.
May 10, 2009 | Maytag 24 in. DWU9202 Built-in Dishwasher
Heavy dishwasher door that falls open
I think any parts person would recognize it by that name.
It's a fairly simple fix.
The one you have may just be loose on one end and not broken -- check that before you buy one.
May 06, 2009 | Dishwashers
Maytag dishwasher heavy door (broken door spring(s))?
Hi thanks for the question. to repair . bottom kick plate must be removed ,to get to the door springs .4 screws . remove them. springs on each side . replace them thanks the appliance doc.
Oct 06, 2008 | Maytag 24 in. MDB7600A Jetclean® II...
Broken Door Spring
Mar 23, 2006 | GE 24 in. GSD500X Built-in Dishwasher
Dishwashers Logo
53 people viewed this question
Top Dishwashers Experts
