Question about Oreck XL U4150 Gold Bagged Upright Vacuum
The motor i ordered for the excel is different from the one already in the vacuum. The are no connectors with a black dot on them.
I looked at the four gold contacts on the "top" of the motor. They are all shorted to each other. I see the ground connector for the ground. I don't know how to connect the white and black connectors from the power line.
How to replace three wire on a Oreck U4180 motor
http://www.fixya.com/fullimage.html?src=http://i.fixya.net/uploads/images/2e7c587.jpg
ck out these wiring diagrams. usually black goes on 1 side where the black dot is and white is piggy backed on the opposite side.
Good Luck
Aug 30, 2015 | Oreck Vacuums
Rainbow e2 type 12 120v , accidentally plugged into 220v, would barely power up, possibly controller board defective?
probably need both as the extra 100 volts would burn the board and the motor
it is never advisable to buy electric equipment from another country because of the voltage differences but even then the plugs are made different so that the cord will not plug directly into the power outlet.
Aug 12, 2015 | Rainbow Vacuums
HOW DO I HOOK UP THE WIRES TO THE MOTOR I FORGOT
You should only have 4 wires to hook up to an Oreck motor. The black wire from the cord coming into the back of the motor housing will be attached to the closest lead when the motor is in it's normal position. Most of the time there will be a black dot next to the terminal. On the other side of the motor you should have two white wires that should be connected together, one from the same cord just mentioned and the other one coming from your lights. Those two wires should also be connected to the motor where there is a black dot beside the terminal. Your last black wire coming from the lights should go to the terminal next to where the white wires are connected or to another terminal that is on that side of the motor. Hope this helps!
Mar 14, 2015 | Oreck Single Speed Handle Assembly - White...
How do I wire an oreck xl9100 motor
The black wire coming from the power cord will go onto the terminal closest to where the cord goes into the vacuum. Sometimes there is a black dot next to the terminal. The white wire from the cord will attach to a piggy-back terminal on the white wire coming from the lights and will attach to the motor on the other side of the motor from where the black wire attached. There may also be a black dot beside that terminal as well. The black wire from the lights will attach to a terminal on the side where you attach the white wires, either right next to them or above them on the same side of the motor. Hope this helps you.
Sep 06, 2014 | Oreck Lamp Housing with Reflector XL9100...
How do i reattach wires to motor from cord and lights
Black wire from the power cord goes onto the wire connection closest to where it comes into the back of the vacuum. There should be a black dot beside the wire connection on the motor. On the other side of the motor, there should be another black dot beside a wire connection and the two white wires will go there. The white wire coming from the lights usually has a double connection and it will go on first and then the white wire from the power cord will go onto the other side of the double connector. The black wire coming from the light usually will go to a wire connector right next to the white wires or just above it . Hope this helps!
Jun 02, 2014 | Oreck XL Deluxe U3700 Bagged Upright...
I need a good wiring diagram for my Oreck xl vac
Chuck,
I do not have a diagram for you but I can tell you how they normally are hooked up. When you have the motor sitting in it's normal position the black wire from the power cord will attach to the terminal closest to where the cord comes in. There should also be a black dot next to the terminal. The two white wires will connect together and they will go on a terminal on the other side of the motor that also has a black dot next to it. The remaining black wire should connect to a terminal next to the white wires or at least on the same side of the motor as the white wires. Hope this helps you.
Apr 12, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Oreck U4148 motor wiring
Pat, I do not have a diagram for you but I can tell you how they normally are hooked up. When you have the motor sitting in it's normal position the black wire from the power cord will attach to the terminal closest to where the cord comes in. There should also be a black dot next to the terminal. The two white wires will connect together and they will go on a terminal on the other side of the motor that also has a black dot next to it. The remaining black wire should connect to a terminal next to the white wires or at least on the same side of the motor as the white wires. Hope this helps you.
Mar 09, 2014 | Oreck XL2600 Vacuum
I'm looking for CV1801 Vacuum Motor, Greator Toronto... Thanks
Hello There,
I've looked up your model vacuum cleaner, and it seems that I am able to still get this motor for your Eureka central vacuum cleaner. We're located in the United States, but we can certainly ship this to you.
Here's a picture of the diagram for you;
We sell the genuine Eureka motor for $199.00, however you may save substantially on this motor by purchasing it under the Lamb Electric name. The motors are identical, and Lamb actually makes this motor for Electrolux, and sells the replacement parts for MUCH less money they Electrolux. We sell the motor under the Lamb name for $119. I went ahead and added this part to our site so you could place your order if you wanted to. I don't have it in stock today, but my parts distributor is showing 3 in stock, so we can easily have your order shipped out within 2-4 business days.
Here's the link to the Eureka CV1801 Central Vacuum Cleaner motor, Part number 54586;
http://www.govacuum.com/10661-Eureka-Central-Vacuum-Cleaner-Suction-Motor-Assembly-Part-54586-.aspx
Hopefully this was helpful to you. I've also left you a link below to the parts diagram of your vacuum cleaner, in case you need some visual help to see how it comes apart. If you found this repair to be helpful, please be so kind and rate the repair helpful, or leave feedback for me. I really do appreciate it, and this also helps people with the same question find the answers easier. If you have any questions, please feel free to email me at chris (dot) jones (at) govacuum (dot) com.
Full Size Schematic in .pdf form:
http://lib.store.yahoo.net/lib/vacuumcleanerbacgs/eureka-cv1801-central-vacuum-cleaner-part-diagram.pdf
Thanks so much,
Chris Jones
GoVacuum.com
Jan 06, 2011 | Eureka CV1801 Bagged Vacuum
Wiring diagram s3755 hoover
Today I shortened my hose by 4" to get around a tear problem. You can use an Ohm meter to find the right 4 wires. When looking from the top of the canister with the hose heading to your left, the wires should be:
White (furthest connector away from you)
Black - to the switch
Red
Blue
With the Red and Blue going to the speed con trol curcuit board.
Aug 05, 2009 | Hoover S3755 WindTunnel Bagless Canister...
Clear oreck schematic
Here is Oreck's motor wiring diagram, if it isn't big enough to make out, give me your email addy and I will send it to you.
Oct 01, 2008 | Oreck XL21 Bagged Upright Vacuum
Oreck XL U4150 Gold Bagged Upright Vacuum Logo
Top Oreck Vacuums Experts
Jim Parker
Jim Parker
xalint1
xalint1
Are you an Oreck Vacuum Expert? Answer questions, earn points and help others
