Question about Toto Home
Why does not water keep spraying even after I press off button?
Unplugged and plugged back the electric cord
SOURCE: timer light did not stop flash
Lamp is not the issue. It most likely is a your DM card. You most likely have some capacitors that need to be replaced. This is a terrible issue with this unit. Do a google search for "DM" and the model number and you should see hundreds of posts.
Posted on Jul 05, 2009
SOURCE: MAGNAVOX PR1910 C125
try pushing the up volume button and the down volume button at the same time.
Posted on Nov 07, 2009
  • 15 Answers
SOURCE: My Gateway 700X PC (Windows XP) will not Shutdown/Will not Start.
Best to format and reinstall a fresh copy of your operation system.
Regards
Posted on Feb 26, 2010
budmrtn
  • 11361 Answers
SOURCE: screen won't turn on - power button continues to f...
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed LG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 22, 2010
  • 6771 Answers
SOURCE: brother fax p275
Remove the backup battery and unplug the fax machine and leave overnight. By morning I'am hoping it will wipe everything clean when plugged back in along with the battery. But it will mean you will have to set your date and time again.
Posted on Mar 08, 2012
Fridge keeps beeping, have unplugged, checked door and drawer seals and still keeps beeping
http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator. Cause of Beeping Noise in Frigidaire Refrigerator eHow
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Jan 20, 2016 | GE Refrigerators
How do you reset the system.
To reset the component Hi-Fi stereo system to factory settings.
  1. On the stereo system, on DECK B , press and hold the STOP button.
  2. While holding the STOP button, press and hold the TUNER ENTER button.
  3. While holding the STOP button and TUNER ENTER button, press the POWER button.
  4. Unplug the power cord from the electrical wall outlet.
  5. Plug the power cord back into the electrical wall outlet.
  6. Turn on the stereo system.
Sep 30, 2014 | Sony STR-DA3000ES Receiver
Blue light flashing on shark steam and spray mop
Read manual under trouble shooting.
1. If you have already plugged in the power cord, unplug and re-plug into another electrical wall
outlet. This may reset the Standby mode.
2. Add water to the water tank and press the On/Standby button to select a steam setting.
3. If your unit still does not work, call Customer Service at 1-800-798-7398.
May 27, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
0xc18a0001 failure
You could try a power reset of the printer.
Press ON button to turn off printer
Unplug the power cord from the back of the printer
Remove all of the ink cartridges
Wait 3 minutes
Plug the power cord back into the printer
Press the ON button to turn on the printer
Install back all of the cartridges
If this does not work, you could try a hardware reset.
1) Press and hold LEFT ARROW and then press SETUP
Release both buttons
2) Press OK
3) Press & release RIGHT ARROW until LCD reads System Configuration Menu 2
4) Press OK
5) LCD reads Hardware Failure Status: Clear, Press OK to clear
6) Press OK, LCD now reads Cleared, Press Cancel to continue.
7) Press & release CANCEL until the Welcome or Ink System
Failure screen appears on LCD
8) DO NOT PRINT AT THIS STAGE
9) Use POWER button to turn OFF printer
10) Unplug power cord from electrical outlet and from back of printer
11) Wait 1 minute. plug power cord back into outlet first then back into the printer
12)Turn on the printer, Press OK
The printer will start to initiate, do not interrupt.
Dec 31, 2013 | HP Photosmart C6180 All-In-One InkJet...
Hp officejet 6500 all lights are flashing and mechine says turn off and on . Please can someone Help??
: Check the power cord
1.
Turn on the product.
2.
Remove the power cord from the back of the product.
3.
Check the power cord for any physical damage. If the power cord is damaged, replace the power cord.
If these steps resolved the issue , you do not need to continue troubleshooting.
If the issue persists , continue to the next solution.
Turn the product off and then on again
1.
Press the Power button ( ) to turn the product off.
2.
Wait 60 seconds, and then press the Power button ( ) to turn the product back on.
3.
If the product does not turn off when the Power button ( ) is pressed, wait three minutes, and then proceed to the next solution.
Plug the product into a wall outlet
Follow these steps to make sure the product is plugged in correctly.
1.
Unplug the power cord from the back of the product.
2.
Unplug the power cord from any surge protectors or power strips.
3.
Select a wall outlet to plug the product into. Test the wall outlet by plugging another electric appliance, such as a lamp, into the wall outlet and turning it on. Unplug the test appliance.
4.
Plug the power cord into the back of the product.
5.
Plug the power cord into the wall outlet.
6.
Press the Power button ( ) to turn the product on.
Solution six: Reset the product
Follow these steps to reset the printer.
1.
2.
Unplug the power cord from the wall outlet.
3.
Wait 10 seconds, and then plug the power cord back into the wall outlet.
4.
NOTE: Many power cords have an LED light on the power module or on the end of the cord that plugs into the product. Make sure the LED light is lit and steady.
5.
6. Perform a partial reset of the product
  1. Disconnect the power cord from the product.
  2. Wait for 20 seconds.
  3. Press and hold # and 3 while reconnecting the power cord.
  4. When the product turns on, release both buttons.
  5. Try printing again.
IF still won't resolve it by following steps mentioned above then your printer needs replacement. Malfunctioning hardware.
Mar 28, 2011 | HP Officejet 6500 Wireless All-in-One...
Flashing orange light, third from the left on the front edge, left side. Just replaced the battery yesterday.....
I had same problem. PC wouldn't even start at all. New cord & battery.Computer repairman said- remove battery, remove electrical power (& unplug the cord from power source :) don't electrocute yourself), then press the start button for at least 30 seconds. I pressed it for about a minute. Replace battery & power, (don't forget to plug the cord into electricity again), and press start button. That resets something inside.
It worked!!!! I couldn't believe it. I almost gave it away before I called repair guy. Yikes. :)
Feb 17, 2010 | Dell Inspiron B130 Notebook
Psc 2210 sounds like the gears just keep grinding then after a bit it stops. says press enter and nothing happens.
perform power cycle
1. Unplug the unit’s power cord from the back of the printer while the printer is 'on'.
2. Hold down the ‘On’ button for 60 seconds
3. Plug the power cord back to the unit while holding the ‘On‘ button down.
4. This will reset the printer’s mechanical systems and discharge all capacitors.
If the issue still persists, then
  1. Unplug the power cord from the wall outlet.
  2. Unplug the power cord from the all-in-one.
  3. Wait 30 seconds, and plug the power cord back into the wall outlet.
  4. Press and hold the # and 6 buttons on the numeric keypad.
  5. While still holding the buttons, plug the power cord back in to the all-in-one. Continue to hold the buttons for two seconds, and then release them.
This should resolve your issue.
Sep 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
Carriage jam, load paper, 2575 won't print
Step1:
  1. Turn off the HP All-in-One by pressing the On button on the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Plug the power cord back into the HP All-in-One.
  4. Turn on the HP All-in-One by pressing the On button on the HP All-in-One.
If the issue persists, then
Unplug the power cord from the all-in-one. Press and hold # and 3 while plugging in the power cord.
Note: For models that are not fax capable, press Plus (+ ) instead of # . Press and hold the button combination for your all-in-one. While still holding the buttons down, plug the power cord back in. Release the buttons after the all-in-one starts up.
Unplug the power cord from the all-in-one. Press and hold # and 6 while plugging in the power cord. if you are unable to perform this leave it and get back to us.
Aug 27, 2009 | HP Photosmart 2575 All-In-One InkJet...
Dryer runs intermittently
"Could the cord/plug and/or receptical be bad and need replaced or is it likely to be something in the dryer's internal wiring?"
Yes, that electrical smell and the dryer not working are all signs of a bad motor.
"I noticed that the plug looked like it was somewhat scorched."
I would replace that plug. This is how electrical fires start.
Dec 21, 2008 | Dryers
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
Home Logo
70 people viewed this question
Top Toto Home Experts
Donni Steen
john h
Robert McCall
Robert McCall
Are you a Toto Home Expert? Answer questions, earn points and help others
