Question about Streetwise Security Products SF3000RH Hottie 3000000* High Powered Rechargeable Stun Gun And Led Light
Elstun Maxam Stun Gun and Flashlight with Sheath.
Elstun Maxam Stun Gun and Flashlight with Sheath. Searching for maker contact info to find correct voltage and user's manual.
What is the difference between a stun gun and a taser?
Basically, Taser is a brand name like Band-Aid or Kleenex. The main difference is that a stun-gun is a handheld electronic shock device while a Taser actually fires prongs using compressed gas that will stick into a target to deliver the shock. There's a ton of info on this Taser VS Stun Gun article here:
https://goo.gl/zDHymJ
May 25, 2017 | Microwave Ovens
Elstun Maxam Stun Gun and Flashlight with Sheath. Looking for maker contact info for the correct specs including voltage. Also looking for user's Manual
OK so this is listed under Microwaves!!
Not a Microwave!
A low cost "stun gun".$15 to $29 depending on the seller.
Requires a 9 v battery, provides a "stated" 300,000 volts to stun and a flashlight too.
This product is a side market product with no manufacturer support found on line. good luck on an owners manual but don't think one will be readily available.
you can check the usefulness by applying it to your thigh (outside lower section just above the knee) and seeing how much it contracts the muscle. odds are it will not stop a big guy or a crazed maniac.
Nov 29, 2014 | Microwave Ovens
Istun gun how to put it back together
Get service manual from manufacture. Also, search youtube as there are many stun gun youtubes to look at.
Nov 23, 2014 | Televison & Video
Not heating anything up
if the light comes on and you here it buzzing but its still not heating up its likley to be the megertron burned out,, (thats the aerial for the microwave's to transmit off) its very expenive to replace,,,
bont try replacing it yourself, inside the microwave is very high voltage even if its been turned off for a long time,, 1000's of volts and they kill,,
have you ever seen a stun gun working??? this microwave has the stun guns very big brother inside it?? it dont stun,, it kills! play it safe drop it into a repair man to fix or better still buy a new one,,there so cheep now its realy not worth spending good money on an old microwave,, go out and treet yourself and play it safe!
Oct 25, 2009 | GE JVM1650SH Microwave Oven
The microwave makes a popping noise, then a loud grinding noise
this could be any thing? first ask yourself how old is it???
if its more that 3 years old you would be better off just dumping it as getting it fixed would cost more that its worth??
and there so cheep now too!
however dont go trying to get inside of it to see if you can fix it yourself
there is a lot of very hight voltage in there even if its been turned off for a long time,,this voltage is in the 1000's of volts and it kills
have you ever seen a stun gun working???????????
well this microwave has the stun guns very big brother inside of it,,
it dont stun,,,, it kills! is it realy worth taking a risk for a fuw bucks?
please play it safe
Oct 25, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Carnt get goodmans me21w microwave out of defrost mode
this is most likley to be the programer packed up,if it wont let you out of defrost its not worth getting it repaired as it will cost to much
ask yourself how old is it? rember there so cheep today! from £50 up!
please dont think of trying to have a go yourself at fixing it,
inside this microwave there is very high voltage,, in the order of 1000's of volts,,,it could kill you if you tuch it! be warned,
have you ever seen a stun gun working?? it realy hurts you!
this microwave has the stun guns very big brother inside of it,,,,,
it dont stun you,,,,it kills you? is it realy worth it for a fuw bucks!,
Oct 25, 2009 | Microwave Ovens
Not all the buttons work on the panel of the mircowave
buttons that stop working could be many things more often its the pad its self but it could also be the programer,,,what ever it is, its not realy worth having it repaired a new microwave costs from £50 up at todays prices,, ask yourself this,,,, how old is it?????
also please dont try fixing it yourself, there is some very high voltage inside your microwave even if its been turned off for a long time,,,
this voltage can kill you,,, be warned!
have you ever seen a stun gun working,,,it realy hurts you!!!
your microwave has the stun guns very big brother inside of it
it wont just stun you,,, it would kill you,,,
is it realy worth it just to save a fuw bucks??? play safe buy new,,
Oct 25, 2009 | GE Microwave Ovens
GE XL1800 model #JVM1850CD 001 -turntable won't turn and makes a grinding noise when turned on. Any suggestions on part number to replace the motor?
why are you diceing with death ???
to fix your microwave will cost you more that £50 thats over the price of a cheep new one??? darft that is,, why not just buy a cheepy and use that? also i do hope you know that inside your microwave there is very high voltage over 1000 volts,,, it could easly kill you if you tuch the wrong part,,,
have you ever seen a stun gun working? it realy hurts you!
your microwave has the stun guns very big brother inside of it,,,
it wont stun you,, it will kill you,, so far you have been lucky your still here, please stay that way play it safe go out and buy a new one?
Oct 24, 2009 | Samsung MW1030WA Microwave Oven
Streetwise Security Products SF3000RH Hottie 3000000* High Powered Rechargeable Stun Gun And Led Light Logo
87 people viewed this question
Top Streetwise Home Security Experts
Lawrence Oravetz
Are you a Streetwise Home Security Expert? Answer questions, earn points and help others
