Question about LG Washing Machines
Constant AE error on brand-new LG WT H550
Bought it a couple of years ago. It's never been out of its box. Yesterday I took it out of its box, plugged in the correct inlet hoses and the correct outlet hose, turned it on... the drum starts twisting backwards and forwards without making a full cycle (normal?) and after about 20 seconds, BEEP BEEP, BEEP BEEP, and the letters "AE" are shown on screen, which according to the manual is a "clutch error'; the only solution offered is to call a technician. HELP!
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 146 Answers
Sounds like "Agitator Error" but the manual says it is indeed a clutch error. Sometimes on the transmission the wire connector is not secure - unplug the unit from the wall and check for bad connections. Better yet, disconnect (if you can) and re-connect each wiring connector in that area, and maybe also where they connect to on the other end.
This is a very high-tech washer, so there should not be too much that can go wrong. It could be, and it does sound like it, that the clutch plates are stuck together and it is not releasing. Look for rust or some other problem like that in the clutch area.
Posted on Nov 29, 2014
  • Alexander Harmer Nov 29, 2014
    Thank you so much, that was exactly the problem. The three-pin connection to the drum was just about completely disconnected. I feel so silly for not checking before!
  • Orlando Dungca
    Orlando Dungca Jul 24, 2017
    can u send the picture please i have the same problem thanks send to my email dungcaorlando@yahoo.com
zaids
  • 456 Answers
SOURCE: The ?Check ? indicator lamp is flashing, but hoses & filters look good
complicated
Posted on Dec 17, 2007
zaids
  • 456 Answers
SOURCE: cold/cold cyle wash water not cold
try to do cold cycle first without doing warm cycle first
Posted on Apr 12, 2008
  • 236 Answers
SOURCE: Need Longer hoses for water inlet and outlet for Danby Twin Tub
get an adapter for both of the hoses to extent.
Posted on Apr 05, 2009
SOURCE: LG Tromm WD 12270 RD washer and dryer
Hi, I don't know how to fix your problem, Lia, unfortunately, BUT wanted to say "Thank You!!" for mentioning that you can get the washer to run through the cycle by rotating the drum and switching to cold water wash! We'd tried unplugging, leaving it unplugged overnight even, but the code/beeping started immediately after plugging back in. I'm kind of longing for an old-school washer right now, thinking of all the things that can go wrong with the newer digital-age computerized ones :-) If you see this, please share what you did to solve your washer problem! Hoping it's not too expensive to fix...or I should say to GET it fixed :-\
Posted on Jun 08, 2010
  • 500 Answers
SOURCE: Got an LG front load washer WM2277HS with an error
Replace the Drain Pump. Its very cheap to replace, so do not worry. The impeller magnet was most likely damaged by a small object or normal wear & tear,
If you want to be sure, first remove it and attach power to its 2 pins.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively.
Posted on Feb 16, 2011
Testimonial: "You saved me!!!!! I would have never figured this out without your help."
Hi I have lg WT H550 machine when I turn on the machine the water is not stopping come into the machine what should I do water level is coming upto the top
2 possible causes
the water solenoid control valve is split in the diaphragm and not stopping the water
the small hose from the base of the tub to the level control pressure unit is split or disconnected or the pressure unit has failed and is not activating the water control valve
Mar 25, 2016 | LG WM Washing Machines
Model Wt-h550. What does fault code AE indicate?
This error AE normally indcates a water leak,try tilting machine backwards or forwards 2 see if any water comes out from base of machine
Dec 22, 2015 | LG Washing Machines
Brand new portable air con- burn smell
Two units, same plug, burning smell ... hire an electrician to check your wiring
Jul 19, 2010 | Sharp CV-P09FX Air Conditioner
Lasko Box Fan Stinks!
same thing with my lasko box fan awful oil smell
Aug 05, 2009 | Lasko 3720 Floor / Box Fan
New Unit Not Cooperating ;(
have u tryed to phone the manafactor for help
can u go into any settings
have u tryed changing the fuse in the plug
pos faulty
Jan 23, 2009 | iLO DVDR05 DVD Recorder
Bad vibration,constant beeping on brand new unit
Did the machine work befor the spellcheck was installed? If so look inside the T/W for forgien objects that interfear with the carrier.
DICKYO
Oct 16, 2008 | Nakajima AE-740 Typewriter
Washing Machines Logo
590 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
