Question about Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet washing machine will intermittently get a F8 D1 error code. My wife will pause the machine and after a while she will restart it and it will then run. Any thoughts?
Pausing and waiting
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 146 Answers
Whirlpool wants a model number before it can get the manual. It should be underneath the lid on the rim.
Posted on Nov 29, 2014
SOURCE: whirlpool duet washer sport ht - error codes
FYI: The pump cleanout is located on the front of the machine, bottom right corner. There are only three screws holding the bottom cover on. It is easy to get to if you prop it up a few inches off the ground. Just thought this would be helpful as I just did this as of 5 min ago. Should take 10 min. or less.
Posted on Jul 28, 2008
SOURCE: Whirlpool Duet Sport Front loading washer and dryer with error code
An easy Fix. Take off the kick panel, 3 screws 1/4 inch. Make sure you have a shop vac ready or a lot of towels as there will be some water. Always disconnect power to washer and dryer, and turn off water to washer. Your filter most likely is clogged with change, screws, lint, and other household stuff that we leave in our pockets! Unscrew the cap on the filter, easy to find, since you have the kick panel off! Take everything out of the filter. Take your shop vac and **** out remaining stuff in hose. Also, **** up any water that has leaked in and around the washer. Screw the cap back on hand tight, put the kick panel back on, turn your water back on, plug it in and there you go! Maybe takes an hour and saves you a repair bill. If you are not comfortable with this procedure then call a maintenance person that is qualified. 775f844.jpg
Posted on Jan 06, 2009
jonniewalker
  • 1029 Answers
SOURCE: error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Posted on Mar 14, 2009
  • 3230 Answers
SOURCE: Error Code F-01
Hi, After about year and half Whirlpool duet sport gave F01 error code. The technician manual is located under the lower front panel. There are three possible reasons for F0: 1) EEPROM ERROOR. Unplug a washer for two minutes. Try running it again. (Did not work for me). 2) MAIN RELAYS ERROR. The tech manual suggests replacing CCU. The following is what I did and it fixed the problem, however. Unplug the washer. Remove the top cover by removing the three screws on the back. The CCU unit is in the right bottom corner if standing in front of the washer – it has a lot of wiring. Plug in the unit. While listening to the CCU start any washing cycle. After pressing START you should hear the relay to click. If it clicks twice, within a less than a second, it has a problem. Unplug the washer. Without disconnecting any wires remove the CCU cage from the washer wall. Stand now on the right hand side of the washer in such way that the CCU cage is under your left hand. Pull the right upper corner of the CCU plastic cage (it has a tab) away from you, slide the cage to the right by about an inch, and pull the entire cage away from you. Now knock on the back side of the cage 4-5 times with a bit of force (watch “Armageddon” movie for more instructions on it). Install the CCU cage back. Plug in the unit. Try some washing cycle again. If it did not help, repeat the procedure. If it did not work again, see the following. 3) PUMP DRIVE ERROR. The tech manual suggests replacing CCU.
Posted on Jun 06, 2009
  • 289 Answers
SOURCE: f14 code on whirlpool duet
the central control unit{ccu}receives its data from an eeprom onboard the ccu.a power glitch may couse this error.unplug washer for two minutes.verify ccu operation by running a diagnostic test or any cycle.if you still have a problem you nead ta replace tnhe ccu.
Posted on Jan 15, 2010
F8 error code Whirlpool Duet
see this causes and fix it. See yur section troubleshooting in your owner manual, or call some tech.
F8 Board failure Replace control board (also called ERC or clock).
Sep 25, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet f09 error code
it is an overflow condition caused by either a plugged drain pump or a bad pressure switch,if you hit pause/cancel and the drain pump continues to run then check the drain pump cleanout for foreign objects
Aug 31, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: I put my machine on pause and now I can't restart....
Press "end of cycle" for 3 seconds, wait for 2 minutes, try door. Shut door and restart your cycle. If door still does not open - repeat 'end of cycle' press for another 3 seconds.
May 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport washing machine with a leaking door.
You need to check if the door is not loose on the washer, make sure you tighten all the screws on the door
Jan 07, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
I have a whirlpool catalyst washer and recently it started blinking an F4 error code..my ? is what should I be looking at when it shows that error code? I have a whirlpool Duet GHW9150P Front loader. When...
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
"F" error code in WTW6600SG1 Cabrio Washer
I don't have a solition and am looking for one my duet whirlpool keeps coming up code F
Jul 07, 2008 | Whirlpool WTW6600SW Top Load
THE MODEL # IS WFW8300S WHIRLPOOL DUET SPORTS WASHING MACHINE
a power glitch can cause this promblem first push pause cancel twice to clear this error code then try the washer on drain spin and listen for the pump to come on if it does then clear the machine by pause cancle twice then try to start again if code resets then the promblem is most likely the ccu or the board but try clearing the error first if that dont work get back with me and we will run diagnostic mode
Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
113 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
