Question about Craftsman 2.0 A Multi Tool With Case and accessories
Model 32023465 sputters on and off when I turn it on, Sears recommended part shaft assembly, which I piurchased, installed and it did not fix the problem. What part do I need?
Model 32023465, sputters on and off when ypou turn it on. I have taken it apart and cleaned it. Replaced the shaft bassembly which did not correct the problem. Sputters regardless of speed you run. LED live tool indicater sputters same way.
  • 739 Answers
Sounds more like a bad solder connection. finding it will take careful examination of wiring and control boards. check the power connections and power switch connections first.
Posted on Nov 29, 2014
Testimonial: "Found a loose connection under the mother board, runs normally now. Thanks."
    Scholar:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 146 Answers
I agree basically with jabberwoky, except it could also be a bad cord. Have someone hold it and turn it on (be careful!) while you move the cord around slowly. If it IS broken, it could be on the tool end or on the plug end. Both are quite common.
How do you remove the blades on a Sears 6HP Lawn-Garden Shredder Bagger, Model #242-28566?
Remove the 5/16" allen cap screw on the end of the shaft. The knife assembly slides onto the crankshaft and is keyed with a woodruff key. Soak the shaft in pentrating oil overnight and try to slide it off or use more persuasive measures like tapping or a slide hammer. You'll see a big nut it's a LH thread so to remove it turn it CCW. The rest is straight forward. I can send you the owners manual if you provide an email address. It illustrates the process in detail. Ronald
Reply
Aug 25, 2011 | Sears Heavy Machinery
I have a sears craftsman riding lawnmower 5 years old. It will steer only hard to the left and will not turn to the right. the steering wheel turns but the mower does not. any suggestions
I had the same problem with my 15 year old Craftsman lawn tractor. I tried to adjust the steering travel but it gave me marginal relief for a year until the steering failed with my steering wheel spinning freely and the wheels free to go left and right. The left bias for steering indicates that the steering shaft pinion weld was shearing prior to failure.
I took the steering apart and found that the drive pinion gear was sheared off the end of the steering shaft at the weld. I replaced the shaft and sector gear to fix this issue.
This fix requires good amount of mechanical disassembly to get the replacement parts in place so you might need to go to a shop to get a mechanic to fix this if you aren't set up for this kind of fix by disconnecting the mower deck and jacking up the front end to access the steering gear assembly and steering arm links.
Mar 26, 2011 | Sears Craftsman 46 in Mulching Tractor...
I installed a sprocket and gear assembly kit to the garage door opener. It runs forward and then quickly runs backwards. Tried to adjust sensors and the motor does the same thing. Goes forward for a bit...
Make sure you put the black cup back on the end of the motor shaft and that it is pressed all the way on. Make sure the RPM sensor is plugged in. If neither of these are the issue, then you probably did not have the motor shaft pushed all the way back when you tightened the coupler after replacing the worm gear. Loosen that coupler up and from the front of the motor (opposite end in which the coupler is on) push the shaft back as far as it will go. Hold it there while you tighten the coupler back up and then try it.
May 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
Trimmer model: Sears 358.796121: no start
Could be a faulty kill switch not allowing it to start, sounds like you covered all the things I would check.
Jul 09, 2009 | Craftsman 25cc Gas Line Trimmer
Cannot remove starter housing assembly on Sears Blower Vac
Take cover off were the belts are located. turn power button to off! see if the shaft can turn with a wrench. That should turn 180 degrees. If stuck you may need to forch it. Then try to pull cord.
Good luck
Jun 20, 2009 | Craftsman 4 Cycle Blower/Vac
Craftsman Garage Door Opener Model# 13953919 not working.
Yes replace the entire assembly. The part number is 41C4220A Sprocket and Gear Assembly and is available at Sears or any good door opener service company. It comes with instructions.
Jun 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do you remove the arbor assembly on a craftsman 10" table saw
go to sears service center and get a new arbor, and ask them to show you the motor and arbor assembly drawing. it should show how the arbor is attached to the shaft.
you can pull the arbor off with a pulley. you can get that from auto parts store.
Mar 31, 2009 | Craftsman 10" Table Saw
Headlight switch
REMOVAL & INSTALLATION
See Figures 1 and 2
  1. Disconnect the battery ground cable.
  2. On 1991-94 models, perform the following:
    1. Remove the ash tray assembly and the finish panel (snaps off).
    2. On the Explorer, remove the rear window wiper and heated backlite switch assembly (snaps out).
    3. On the Ranger, remove the storage bin (snaps out).
    4. Pull the headlight switch knob to the headlight on position. Depress the shaft release button and remove the knob and shaft assembly. 0900c1528018ef70.jpgFig. 1: View of the 1991-94 model headlight switch control knob release button
  3. On 1995-99 models, remove the instrument panel finish panel.
  4. Unscrew the mounting nut and remove the switch from the instrument panel, then remove the wiring connector from the switch.
0900c1528018ef71.jpgFig. 2: Exploded view of the 1995-99 model headlight switch componentsTo install:
  1. Connect the wiring connector to the headlamp switch, position the switch in the instrument panel and install the mounting nut.
  2. On 1995-99 models, install the instrument panel finish panel.
  3. On 1991-94 models, perform the following:
    1. Install the headlamp switch knob and shaft assembly by pushing the shaft into the switch until it locks into position.
    2. On the Explorer, install the rear window wiper and heated backlite switch assembly.
    3. On the Ranger, install the storage bin.
    4. Install the finish panel and the ash tray assembly.
  4. Connect the battery ground cable, and check the operation of the headlight switch.
Nov 29, 2008 | 1998 Ford Explorer
Craftsman 2.0 A Multi Tool With Case and accessories Logo
63 people viewed this question
Top Craftsman Tools & Hardware - Others Experts
Dusty Ryan
Level 1 Expert
Mike
John Trevino
Are you a Craftsman Tool and Hardware - Other Expert? Answer questions, earn points and help others
