Question about Konica Minolta 7022/7130/7222/7228 Digital Copier Toner 30 000 Y - 950246
Koni a Minolta copier 7228. All my. Copiers stoped adding toner after six months and I have five of the copiers. May I order for some copier parts and how do I go about this. Pls assist.
I have five of this copiers and all stoped adding toner after a while. What do I check/correct before I can perform L detection.
  • Konica Minolta Master
  • 6,674 Answers
Replace the toner cart with OEM and correct image units
Posted on Feb 11, 2018
  • 31 Answers
SOURCE: Minolta Dialta Copier
C0500 refers to a low fuser temperature. You can attempt to clear the code by using the tech rep service mode. Go to "Counter" Go to "Trouble" Trouble reset If "warm Restart Swich" is asked for- This can be actuated through a small access hole on the right side of the control panel, using a straightened paper clip or something similar. You may need to clear the counter by pressing "clear" and then "end". After clearing the code, power cycle the copier. If it comes to "ready" you are all set. If not, you may have a blown heat lamp or thermal fuse which would need to be replaced by a technician. Good Luck!!
Posted on May 23, 2007
Nitrotrike
  • 589 Answers
SOURCE: copier malfunction
Code C0F36 is a low toner density error on the black developing unit.
Was it asking for black toner before this code appeared?
Posted on Feb 10, 2008
  • 26 Answers
SOURCE: ERROR CODE C-4401 On Konica Minolta Bizhub 500
CAUSE: Failed write unit. Laser
Replace write unit (p/n 50GA-6500).
Posted on Feb 21, 2009
  • 4 Answers
SOURCE: Konica Minolta Di 3010 - cannot clear trouble message
one thing you can try since you have already removed the fuser you can probably do this but i would not recommend it unless you are familiar and comfortable with the components of the machine turn the copier off remove the back cover you will see in the middle of the machine a metal cover with 4 or 5 screws, behind this cover is the main board it has many wires going to it through out the machine...remove the cover so u can see the board and all its connectors on the board there should be a little black button... turn the machine on press this button and the code should reset. If the code does not reset then the thermistor or thermostats are bad and the fuser needs to be rebuilt. as for the password 8 zeros or 1-8 are the defult passwords for the machine. you can also try 1247....
Posted on Apr 08, 2009
wheatlandsvc
  • 1110 Answers
SOURCE: Service Call error C0F32 in Konica minolta copiers
Since you did not include the Model number I will suggest the following:
This code means pretty much the same on all Konica/Minolta machines.
The ATDC or automatic toner density control has experianced a problem. Have you run the copier out of toner by chance?
You can try resetting this code to see if it comes back. If it keeps coming back then you are going to need the process unit serviced. Or depending on the model you can replace the "Imaging Unit" yourself.
Posted on Oct 27, 2009
Where can this part for the printer be purchsed ? konica minolta bizhub 160
Except you don't say what 'this part' is :>)
Never mind. Here you go. Or look in Yellow Pages for a technician.
  • Konica Minolta bizhub 160 Supplies and Parts (All) www.precisionroller.com > ... > Konica Minolta > bizhub 160 Konica Minolta bizhub 160 Supplies and Parts (All) for less. Free shipping on orders over $75.00!
  • Konica Minolta Bizhub 160 Toner, Parts, Supplies, and ... www.arcservicesco.com/1016/konica-minolta-bizhub-160-i-toner-parts... Additional Info Konica Minolta Bizhub 160 is a Digital Printer and Copier which was introduced February 10, 2012. Suggested Retail Price:$1,029
  • images of konica minolta bizhub 160 parts bing.com/images th?id=oip.mcd31c057681b6e2e393bc136df5885ddo0&w=140&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.m850c92a4f48e9107608f3f81e06b2feeo0&w=99&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mdb0ced5306197a197806530dbb355967o0&w=74&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.mb7d2a296bf50d1a0bb42098505ce2c61o0&w=133&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2th?id=oip.maedc8ec17eba695445679a648922e7e3o0&w=70&h=105&c=7&rs=1&qlt=90&pid=3.1&rm=2 See more images of konica minolta bizhub 160 parts
  • Konica-Minolta bizhub 160 160f 161 161f Parts Manual www.qmanual.com/printer/konica-minolta-1/bizhub/konica-minolta... BRAND: KONICA-MINOLTA: BRANDSKU: No: TYPES: Parts_Manual: SIZE: 1.49M: PAGES: 35: FORMAT: PDF: LANGUAGE: English: QUALITY: High resolution: ...
  • Konica Minolta Bizhub 160 Printer / Copier Parts & Supplies https://discountcopiercenter.com/konica-minolta/bizhub-160.html Save big on Bizhub 160. We offer the lowest prices and highest quality, with free shipping on any orders over $100!
  • Konica Minolta bizhub 160 Parts Guide (160_PARTS) www.atec.ro/parts.../konica-minolta-mfps/konica-minolta-bizhub-160... Konica Minolta bizhub 160 Parts Guide; PN: 160_PARTS
  • Apr 01, 2016 | Konica Minolta Office Equipment & Supplies
    Minolta 7228 moved from one location to another now copies not clean.
    I doubt that moving the machine has caused the problem shown.
    Regardless- the copier drum is not being cleaned.
    I would begin by replacing the Drum Blade.
    It is technical and will require your knowledge of the service manual procedure.
    Good luck
    Jan 14, 2015 | Konica Minolta Office Equipment & Supplies
    Can Xerox DocuColor 3535 toner ink be used in Xerox WorkCentre 7228?
    From experience, I wouldn't do it...
    The different series usually have slightly different toner composition, so you may find that your copier will be majorly over-toned or under-toned. by doing that.
    I personally wouldn't risk it, and I have been in the industry 24 years...
    Oct 26, 2014 | Xerox Office Equipment & Supplies
    After adding toner it continues to say replace toner
    which copier:printer? may be an electical problem, or the sensor toner. are u sure about the toner (is it really new?)
    Dec 30, 2013 | Konica Minolta TN601K Toner for 7155,...
    My bizhub 7228 has this on the screen F-26-1 and says i need to contact service
    F-26-1 is the low toner ratio code.Check the toner bottle, if its empty then replace it with the new one.If its full then pull out the bottle and again inert it.Now restart the machine and it will start working.
    Apr 26, 2011 | Konica Minolta Bizhub c203 Copier
    I have an error message on my magicolor 2550 ( Konica minolta) that says Replace K toner??
    The K toner is the black toner. The K stands for "Key" as in primary toner.
    Pages 80-107 list the toner part number that you will need to order as well as how to remove the old and install the new toner.
    Mar 15, 2011 | Konica Minolta magicolor 2550 Laser...
    Dear sir my minolta problem the minolta is stoping after copier one paper please i needed the of 1083 including the problems and soulving for this copier
    IS there toner in the machine or is it low if low you need to add toner if there is toner try doing an f8 adjustment
    Jan 23, 2011 | Minolta EP1083 CS/PRO Copier
    The machine (ir2018)is six months old, The password was tempered
    under service mode: * 2 8 *, under clear, select all and OK. then set up copiers properties and settings again.It should be OK.
    Apr 23, 2010 | Canon iR 2016i Black and White Copier
    Konica Minolta 7022/7130/7222/7228 Digital Copier Toner 30 000 Y - 950246 Logo
    75 people viewed this question
    Top Konica Minolta Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Adorjani Laszlo
    Ben
    Ben
    Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
