Question about Garden
Problem with traction
It go back but not in front
  • 937 Answers
Not really clear what the problem is but sometimes reducing the air pressure in the tires can help a little with traction - to a point. You may have to use the lowest gear as well. Some of these lawn tractors simply can't climb a much of an incline.
Posted on Nov 29, 2014
2001 Chevy Impala. When I turn my traction system off the steering act like the pump is going out. But when I turn it back on it go away. But when it the traction is on it sometime stall in the front...
check the hub assemblys when the traction control is engaged the computer does not allow full power to be distributed to the traction wheels should also check the rack and pinion either 1 of these issuses can cause problems with the steering and control of the vehicle also check the traction sensors
May 27, 2014 | Cars & Trucks
When i take off from a starting position it feels like the back wheels are spinning, losing traction and power it doesn't happen all the time
You are a front wheel drive all traction is in the front,either you are overeving which is a transmission slip,if you say you loose power when accelerating you are describing a plug air filter and even a plug catalytic
Mar 06, 2012 | 1989 Mazda 323
I bought 4 tires at the same time, just had them rotated and was told that the front tires have more traction on them now than the back and that they shouldn't of rotated them. On a 2001 Chevy Cavalier...
You want the tires with deeper tread on the front of the car. As you drive, being front wheel drive the front tires do all the work, the rears are just along for the ride so the drive tires will wear down twice as fast. About ever 6000 - 8000 miles, you will need to rotate the tires to keep all 4 wearing evenly
Oct 16, 2010 | 2001 Chevrolet Cavalier
Have bmw dtc of 5D66 looking for an explanation of what is involved
DTC - Dynamic Traction Control is it system takes care of that order, for example in winter into the snow when you need fast acceleration, wheels without DTC rotate,and traction is no good! DTC via the ABS sensors to monitor the movement of each wheel identifies the situation when: front-wheel stands, but the back spining = traction is poor and corrects output from engine, gearbox, braking and traction conditions that were ideal for smooth start!
May 06, 2010 | 2006 BMW 750Li
Service traction system light
Should be a sensor (look for a wire running to the back side or inside of the wheel.) that picks up the rotation.
I'd suspect that it got damaged during the wheel bearing replacement. If the wire is missing, look at the left side front wheel as a mirror image of what should be there.
Sep 14, 2009 | 2001 Chevrolet Monte Carlo
Service traction system light on after getting new tire
wheel bearing about to go bad.. Notice any slight roaring noise??
Mar 17, 2009 | 2003 Oldsmobile Silhouette
Anti lock abs and traction control light.
did you accidently unplug a rear speed sensor
Feb 27, 2009 | 1996 Cadillac Seville CA Value
Check Traction Control warning light
I can't give you an explanation for why the car is telling you to check trac. control but i can try to give some help on maybe fixing it. Try - turning on the car, turn the traction control off, turn the car off, turn the car on. Then turn the traction control back on and push the system check button. That should i guess "reset" the trac control system.
Now the noise from the front right of the car is MOST LIKELY the air compressor pumping air into the bags. (i own a 97 Continental but i've never had a problem witht the trac control)
Jan 21, 2009 | 1997 Lincoln Continental
2001 olds ABS and traction control sensor issue
An ABS sensor DOES affect the traction control system. Traction control uses these sensors to determine if a wheel is losing traction. A bad sensor will cause both the ABS and TRACTION lights to come on.
The CHECK ENGINE light however is going to be a seperate problem.
Jun 08, 2008 | 1999 Mazda Pickup
Garden Logo
35 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
