Question about magicJack PLUS VOIP Phone Adapter
I have magicjack plus.My phone is not working for 5 days. It says There is a system error". I checked all my connections.This a 6times since Jan.2014.
I unpluged every thing from the wall.Checked all the connections.Waited 5 days before contacting you. Checking the phone every hour on the hour. HELP CE #S1013FC S/n1031020147744 FCC ID:Y79S1013.
  • 739 Answers
Did you make sure to install the drivers on your 'prime' computer? you have to configure using a computer for the system to function.
Posted on Nov 29, 2014
2 Suggested Answers
flekota
  • 18 Answers
SOURCE: my laptop window 7 OS wont recognize my magicjack plus. what will i do?
make sure its updated?try running it as administrator your firewall or anti virus IP maybe blocking it check all three to see if IP is blocking it use the USB port if it dosn't work trough that your IP is blocking it try reinstalling it follow instruction don't just click next read what it says. it may ask do you want to run as adminnistrator
Posted on Oct 27, 2012
MY MAJIC JACK IS NOT WORKING SO I THINK I NEED TO UP GRADE
Tonya, To help diagnose Magic Jack issues, check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
magicJack Live Chat
How to Fix Your MagicJack Problem
Magicjack Plus not working when plugged directly in the router SOLVED
Top Ten Frustrating Reasons Why Your magicJack Plus Wont Connect
Jul 22, 2016 | Cell Phones
Can a security system be run off magic jack
It should work just fine as long as you are not using the old MagicJack or a newer one via USB connection to through a computer as our will create too much of a latency or delay to operate properly. It should be a newer model connected directly to a router via the Ethernet connection.
Feb 19, 2015 | magicJack Two, 2 Magic Jack Plus Voip...
For the past 3 weeks, my magic jack plus is not connecting after dialing number.
Whose number are you trying to dial? Only a certain number?
Go to this site: http://www.magicjack.com/customercare.html
They should be able to help you with your problem.
Nov 07, 2014 | magicJack Plus
How can I fix my majicjack plus to work with anew service provider?
tab_l.gif Answer tab_r.gif If you hear error 1 while trying to place a call with your magicJack, it means that you are not connected to the Internet.
You need to check your new internet connection first.
Then sign into
You must check your new internet connection gets to magicjack.com
sign into VoIP Phone Service Internet Home Phone Service Providers magicJack
Jul 12, 2014 | magicjack.com
If you are still having problems, the correct method of solving it is to go to magicjack Customer support. International VoIP Phone Service Customer Care Support magicJack
May 29, 2014 | Computers & Internet
Magic Jack frequently loses connection even though it should stiil work when offline
To use without computer plug ethernet cord into magicjack otherend into router plug phone in to magicjack plus plug magic jack plus int power adapter plug power adapter into power outlet should work but does not no calls in or out in reverseorder and has to be online with internet conection .
Dec 27, 2013 | magicJack Plus Pc To Phone Adapter
Magicjack doesn't always work right sometimes the phone works , sometimes I get an error 3002 message when I try to call out.
Actiontech what, they many vast models, and routers, and mix.
what are you exact connections here>
NO PC stated, HP model number, this is HP forum. so.....what?
no OS stated, opr. system , windows WHAT?
No modem models stated.
No ISP service stated,
what ISP, what service,? DSL> must I GUESS that?
My guess is not DSL no land line but it is possible to buy DSL
with Landline, disabled, I did for years.
or cable modem, ? uses COAX ! not 2wire twisted like DSL.
or are you doing the MAGIC jack , with NO COMPUTER owned
yes?
The magic jack does not plugin to any modem ethernet port
ever. its usb.
t
Broadband, high-speed internet, cable internet, DSL - WiFi, Fios fiber. and more , dial up? nah you dont have LAND LINE./
error codes,. the first page in the manual states !
Contact your Internet service provider to verify your modem allows more than one device to access the Internet if you receive error 3002 when trying to use MagicJack Plus. Some modems and modem/routers-in-one may not be compatible for use with MagicJack Plus if multiple devices are connected to your network.
We dont know what ISP you have nor the connection type
cable tv modem, DSL, FIOS what?
nor the modem you have , you never said,
this is far more complex
its not magic at all,
fire walls set wrong
ISP blocks you, at your mixed, router and modem
using the routers, USB port is a FAIL.
if you want great help answer what you have and what is connected
in details.
the MAGIC jack as 3 ways to connect,
USB or ethernet.?
Jun 11, 2017 | HP Computers & Internet
Magicjack problems
If the telephones work without MagicJack connected, you have your answer. BUT, the "no power at base" message means just that. Find out why and fix it. The loss of dial tone may be because the telephone system detected a problem and disconnected service until it is resolved.
Dec 03, 2013 | Computers & Internet
Need magic Jack plus software download
Magicjack software is stored in the Magicjack module. Plug that module into a USB port on your computer. You should get an onscreen message like: "Install or run program from your media".
Click on "Start Magicjack". That will install the software on your computer.
More information at:
http://www.magicjack.com/how-it-works.html
Jul 29, 2012 | magicJack Two, 2 Magic Jack Plus Voip...
magicJack PLUS VOIP Phone Adapter Logo
41 people viewed this question
Top magicJack Cell Phones Experts
gaucherre
David Payne
David Payne
Are you a magicJack Cell Phone Expert? Answer questions, earn points and help others
