Question about Frymaster Dean 2424G Deep Fryer
I have a frymaster sr14esd, it turns on and makes noise but does not heat up. Is it my thermostat?
My fryer is turning on and making noise but is not actually heating up. Is it a bad thermostat or something as simple as a flipped breaker
  • 937 Answers
If the unit seems to be powering up and making noise, then you have power and it doesn't sound like a tripped breaker. About the only noise I would expect would be the element heating up and maybe the oil popping unless there is a fan. What kind of noise is it making? IF you have the equipment & know how, you could confirm power to the heating element or check the load the item is placing on the electrical service. One way to check the thermostat is you can turn the Tstat all the way down, turn on the power and see if you can hear the power engage as you slowly bring the temp setting up.
Posted on Nov 29, 2014
5 Suggested Answers
kstfas
  • 75 Answers
SOURCE: gf 40 frymaster fryer
Hi, I am suposing that this fryer has worked good in this location before. If not, check to make sure it is set up right for your gas supply. (LP-Nat) There is something wrong with the gas - air flow in your unit. Look for obvious things first like exhaust being blocked, Flame dancing out side of fire area, Pilot too small, Build up of debris in fire box. The pilot should be able to be adjusted at the gas valve if it is too small. I believe you problem could be taken care of best with a good cleaning of the burner, fire box and pilot assemble. Make sure that all burner holes are clean especially around the pilot light. Check for oily debris inside the fire box to make sure its not leaking into the fire area. If you are unable to do this yourself, contact some one either in the restaurant equipment service business or heating and air conditioning business. Hope I have helped you. kstfas NOTE: If this answer does not rate at least 4 marks, (almost there) please do not rate. Thank You.
Posted on Sep 27, 2007
  • 7 Answers
SOURCE: frymaster fryer mj45eusd
If this is an electric fryer you may have a shorted element that will continue to heat when ever the fryer is turned on,even when it is not calling for heat. If it has 3 phase power, the elements could be wired wrong
Posted on Sep 18, 2009
qasolution
  • 107 Answers
SOURCE: Frymaster fryer keeps calling for help on electronic keyboard.
There should be some kind of spark sensor usually where the gas line plugs into the pot. There is one wire hooked to it take the sensor out and clean it good. Soot could be building up on it causing it to nolonger sense a flame.
Posted on Apr 19, 2012
  • 5 Answers
SOURCE: Frymaster fryer over heats
Where exactly is your thermostat tube located?
Posted on Nov 10, 2014
Frymaster Dean Deep Fryers pilots light automatically go off
Will this heat up at all. Is it the same Model # as the one you .have some changes from the one you have for 2 years ago might have been made. check model # and make sure it is the same The light that go's out might be when the unit come up to the setting you put you Thermostat on meaning it heated up and will come back on when the temp drops and it starts to heat back up. it's that simple. if you just got this unit it should work if you turn the heating setting up . Let me know if the unit heats that is the starting point.
May 04, 2014 | Frymaster Dean SR42G Deep Fryer
I have a frymaster gf14sd and when turned on for about 20 minutes the fryer turns off and pilot light goes out and will not restart til it cools down .
First you will need to determine what the oil temperature actually is when the fryer shuts down. The reason for the shutdown is likely the hi-limit thermostat is tripping. That could be the result of the hi-limit thermostat being faulty or the thermostat is faulty and the oil is actually too hot eg: 450F. Once this is determined, either the thermostat or the hi-limit will need to be changed. The part number for the thermostat is 807-1692 and the hi-limit is 826-1177. I know this post is late, hopefully it will help someone.
Aug 20, 2010 | Frymaster Dean 1824G Deep Fryer
Pilot will lite,but burners will not lite when you turn the thermo. up
Make sure gas valve is in the ON position after lighting the pilot. Try jumping the thermostat terminals together to see if burner comes on. Three things could cause this problem 1. bad operator on gas valve 2.low millivolts 3. thermostat not functioning
Tom
Aug 03, 2010 | Frymaster Dean SR42G Deep Fryer
Pilot light stays lit when I turn the gas valve to on. But nothing happens when I Turn the thermostat on. Help
The thermostat control is bad, you will need to replace the thermostat switch and everything will work just fine. Basically the thermostat switch is not sending a signal to the gas valve telling to to turn on
May 25, 2010 | Frymaster Dean SR42G Deep Fryer
Frymaster will not re-light after reaching temp on initial start
You have a lazy thermostat that needs replacing. Not uncommon.
Tom
May 21, 2010 | Frymaster Dean FM345EETC Deep Fryer
Frymaster Pilot not lighting
first thing I would check is to make sure the quick disconect on the gas hose is fully connected,and that the cut off valve is tured on.Sometimes the orifice in the pikot assembly can become stopped up.(where you light it by the burner)you can check there by undoing the gas line at the compression nut on the assembly.the hole is really small and you can use a small needle to clear it.
Mar 28, 2009 | Frymaster Dean FM345EETC Deep Fryer
Frymaster fryer over heats. Replaced thermostat. Runs for a couple of hours then overheats again.
Make sure the t'stat is located properly. If it is too low in the vat, it will not read correctly. At the bottom of the vat, it can be as much as 150 degrees cooler than the top or more. Especially if the the t stat is below the burner, it will not read correctly.
Mar 03, 2009 | Frymaster Dean H17-SC Deep Fryer
Fryer not starting
I'm suspecting one of the following causes:
1. The thermo couple/thermo pile
2. Gas valve sticking, intermittant operation, doesn't snap open when required all the time. THIS CAN ONLY BE PROVED WITH A MANOMETER and specialized meter that can measure thermocouple or thermoppile current, and volt meter.
I've worked on many a McDonalds Frymaster beeping fryers that intermittantly go into ignition failure that TURNS OUT TO BE THE ACTUAL GAS VALVE FAILING TO SNAP OPEN, and hang only once in a while. Gas valves are only good for so many operations, once that has been reached start failing. The indicator you gave, IT WAS USED BEFORE YOU GOT IT makes me believe it is your gas valve!
ps: manual for your unit
http://www.frymaster.com/docs/uploaded/fry/products/OperationalManuals/819-5887.pdf
Jan 23, 2009 | Frymaster Dean GF14 Deep Fryer
Heating problem with frymaster h14-2
I called IG Service in Denmark, who have their own technical experts, And they will now solve it.
I found them via the frymaster homepaige.
www.ig-gruppen.dk
Jan 15, 2009 | Frymaster Dean 2424G Deep Fryer
Frymaster fryer mj45eusd
Sep 08, 2008 | Frymaster Dean Kitchen Appliances - Others
Frymaster Dean 2424G Deep Fryer Logo
183 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
