Question about Aquaflo Pool & Spa
I have an Aquaflo 300 that was installed today and when switched on the water just kept dropping back down, when using the override switch it still didn't seem to pump it upwards and over heated. coul
It has to go 3 metres up, and about 20 metres across which the pump should be able to manage and more. we need it to work properly to meet tattoo studio legislation. any advice would be greatly appreciated.
  • 2,760 Answers
New pumps need to be "Primed" in order to work also ck mfg specs to be sure your not asking pump to lift water higher than mfg data says it could "this is known as Head Pressure"
prime'ing is a procedure in that a small amount of water or liquid is added to pump head at assembly , I use mineral oil this is easyly soaked up with rag on pool top after flow is started ,but does no harm to leave it there as it's food safe
Posted on Dec 11, 2014
XPoolGuy
  • 34 Answers
SOURCE: The pump is not pumping out water fast enough
Check the strainer housing on the front of the pump for a worn out oring. If you see water swirling around the in basket, it is a good indicator that air is making it's way in past the o-ring killing the waterflow. (the prime) Replace the oring. Make sure you lube the oring with a non-petrolum silicon grease.
Posted on Jul 04, 2009
  • 29 Answers
SOURCE: Pump hums when switched on but does not work more than 20 seconds
hi i had the same problem with my booster pump motor it hum but did not turn. to make a long story short see if there is a metal cap on the back of your motor if there is pry it off and you should get to see the shaft turn the shaft with a screwdriver if it has a notch in it or if it don't turn the shaft anyway you can and make sure it turns easy. my shaft was tight as hell but i got it to turn and it started right up again and i had no problem. the hum means it is stuck and it shuts off because the breaker is tripping and after a few seconds it will click back on again, hope this helps
Posted on Jul 06, 2009
protek480
  • 1723 Answers
SOURCE: Water in pool fountain drops when pump is shut off.
Back flow preventer (check valve) in pump is failed.
Posted on Aug 26, 2009
Testimonial: "Great,thanks for your quick response. Now I will try to see if your answer to my problem solves it. Thanks Alec"
  • 366 Answers
SOURCE: I have sp704t XL valve my cusin switch to backwash
sounds like the spider gasket has come out of place. Make sure the pump is off and remove the top of the valve and inspect the spider gasket (looks like a wagon wheel). If it's out of place, sometimes you can reinstall it with a silicone lubricant (clean thoroughly and lube). There should be some good spring tension and you may have to depress the selection handle to reinstall the valve. Hope this helps!
Posted on Sep 24, 2009
john224
  • 1378 Answers
SOURCE: My jacuzzi air pump switch does not work, however
Replace the air button because the diaphragm inside is broken.
John
Posted on Aug 28, 2010
I want my motion securtiy light to acturally stay on all night. more after animals than people, can this be done?
Usually with mains power motion lights if you switch them on and off two or three times and then back to on, the light will stay on all the time. To put it back to motion, switch off, wait a minute and then switch to on.
This is borne out by this article
Search Results Most motion detectors have a built-in override:
  1. Normally the switch is kept on all the time. ...
  2. If you turn the switch off and on within a second or so, the light will stay on, and this overrides motion detection.
  3. To go back to normal operation, turn the switch off and wait ~10 seconds, then turn back on.
More items...
lighting - How can I override a motion detector light? - Home ...
https://diy.stackexchange.com/questions/.../how-can-i-override-a-motion-detector-light
make motion security light stay on Google Search
Sep 04, 2017 | Home Security
How do I find the manual override on the six outlet Smart Electrician Power Stake?
Product not fully identified... attach photograph of product
Product manuals often do not match product today... globalization has shortcomings.
On analog timed units, override can be slide switch, round knob... or many power stakes do not have override
On digital power stakes, override can be sequence of buttons or one button.
Following link shows many common power stakes timers to help identify product and add a followup question.
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Gene
Water Heater Timers Save Money
Dec 17, 2014 | Hardware & Accessories
Flow master XP2 by aquaflo for spa; it clicks, but does not start. I could turn the shaft with a wrench, all plugs work.
the start switch has trash in it , use compressed air and blow out the back of the motor, this works most of the time for me. otherwise the motor will need to be dissembled and can be tricky do to easy to break parts. search your area for your local pool pump motor repair guy with free testing. and ahve him clean the switch
Sep 14, 2013 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Danby icemaker DIM3225BLSST, having drainage issues and trying to troubleshoot. Is the drain pump switch on if the "O" is selected, or the "----" ?
Thank you for being very descriptive. I would get the installer back out since it is new and probably still under warranty and instruct them to say with it until it has satisfactorily run a couple of cycles. They can easily troubleshoot this machine while they are on the job.
Mar 06, 2013 | Danby Ice Maker Dim3225blsst
2012 coronado truck will not turn off
Some coronados get a crack in the seam between the dome and roof water leaks down the inside and follow the wiring harnesses down to the power control module and abs module behind the drivers seat check the plugs and fuses for signs of corrosion
Mar 29, 2012 | Cars & Trucks
My 1999 lexus rx300 is stuck in park.i have to use to shift override to get it to shift,any suggestions?
There is a brake switch located underneath the drivers side on the back of the brake pedal if this is failing you will not be able to shift from park without the shift override.
Jan 16, 2011 | 2001 Lexus RX 300
Our old sump pump went out and I purchased a Little Giant pump with a remote switch. I attached the switch to the pump, attached pump to drain line and put the pump in the basin. It started pumping...
The rs-5 switch is supposed to turn the pump on at 6 inches to 10 inches of water from the bottom of the switch and shut the pump off when the water gets to 1 inch to 4 inches from the bottom of the switch. Sometimes the pump takes a while to prime itself the first time it starts up. The noise at the end of the cycle is not unusual either.
Is water coming back to the pump causing the switch to close?
However, going on & off almost immediately is not right. Is the switch installed in a specific location that it is designed to fit on the pump?
It does sound like the switch is going back on at too low a water level.
Also, make sure it is not a rs-5LL for low level. Even this should not allow the pump to go on and off.
Gary
Dec 14, 2010 | Little Giant Rs-5 Remote Switch
Help! I can't get the water heater to go on! I KEEP TRYING to set the dial, but it's not working
If I understand correctly, you have the WH40 water heater timer.
If timer dial will not rotate, then use manual override to turn on circuit to water heater.
If manual override will not move back and forth, the tripper pin might be wedged against the lever.
Lift and rotate dial out of way.
If manual override does not click back-and-forth, then timer is probably bad.
If manual override clicks, but water heater does not turn on, then check electricity.
If you need more help, post a comment and I will respond
Oct 28, 2010 | Intermatic WH40 - Water Heater Time Switch...
The water would not shut off. It just kept filling. I was able to override it and it went through an agitation cycle and it drained. It also spins.
Is there a water level switch on the console? If so, the problem may be the switch behind the panel or it may be a tube that connects to the switch from the bottom of the outer tub. Hope this helps!
May 07, 2010 | GE WHSE5240D Top Load Washer
Motor misses out and backfires when (trying to backup) ATV 4x4
Polaris quads have a reverse override that does not allow full power in reverse unless you push the override button on the left hand handlebar. Prevents you from going full speed in reverse and wiping out. You will also notice that your 4x4 will not work unless you push the button,
Mar 18, 2009 | Polaris ATV
Pool & Spa Logo
Top Aquaflo Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you an Aquaflo Pool and Spa Expert? Answer questions, earn points and help others
