Question about Electrical Supplies
How do I fix two three way switches where only one of them controls the light?
My downstairs switch controls the light in the hall but the switch at the top of the stairs does not do anything. Something must be wired wrong at the light by the previous homeowner. They are both 3 way switches. How can I fix it? I have drawn a sketch of the wiring at both switches and at the light junction box.
  • 1 more comment
  • ryan463 Nov 29, 2014
    Here is the sketch that I drew. The gray wires on the drawing represents white.
    That picture didn't work so well. Let's try this.
    Never mind. I figured it out. The switch downstairs and the box at the light were both wired wrong.
  • 739 Answers
--------------- wire #1 ---------------------
power in --- -----power out to
--------------- wire #2 --------------------- light
the upstairs switch is improperly wired. With the breaker off, un wire the upstairs switch. Using an inductive tester with the breaker back on (use caution not to get shocked, determine which wires get power from the downstairs switch in EACH position (there is no 'off' in a three way). when you determine which two wires bring power to the upstairs switch, the remaining wire is the light.
Posted on Nov 29, 2014
SOURCE: wiring a 3 way switch on 1 plate to 3 lights and 2 other switches
I have a light switch at the bottom of the stairs which works 2ways can be switched on and off up and down stairs and also an out side light on the same switch which I have messed up and would like a picture of the way it should be connected.
Posted on Oct 16, 2008
  • 323 Answers
SOURCE: Wiring Bathroom light/vent/heater switch with 3 separate controls
Wiring a bathroom combination vent, heater, light 3 way switch means more wires. In brief, you need to run two cables - one a two wire and one a three wire from the switch to the fan.
Incoming power will have white black and ground.
The two wire cable for the switch to the fan will have wht, blk, and ground.
The three wire will have red, blk, wht, and grnd.
The switch will likely have 2 blacks and a red coming from it, with two blacks and a red on one side, and a single black on the other.
The fan should have a red, blue, green, black, and white.
On the fan end: Group all green/copper grounds together and use a wire nut to fasten them together. Tape the nut to the wires.
There will be five white wires coming through. For ease of handling, using wire nuts, connect two on one nut and three on the other.
connect the blue to a blck. Connect one red to one black, and the other red to the other black.
The switch will have one red going into the 3 wire cable, a black going to the 3 wire cable, and a black form incoming power to the side opposite the 3 wires, and a blck going to the two wire cable.
There. Confused?
Posted on May 28, 2009
cj2176
  • 520 Answers
SOURCE: Wiring Door jamb switch
I'm going to guide you on how to create what is known as a "switch leg".
1- run a 12-2 w/ground wire to the light fixture from new switch.
2- connect black wire "hot wire" to the shiny bronze tinted terminal on switch.
3- connect the white wire " neutral " to the silver connection on switch.
4- connect the naked copper wire " ground " to the ground terminal on switch
5- Disconnect the two white wires in the junction box from each other.
6- Connect the ground to ground in j-box
7- Connect the black to one of the whites in j-box
8- connect the white to the other white in j-box
9- wire nut and tape all connections
Oh and be sure that you turn off the breaker before you start. Hope this helps. Good luck.
Posted on Jun 15, 2009
  • 864 Answers
SOURCE: how to wire 3 switches in a 3 gang box
WARNING: Do not attempt to do this work unless you completely understand the information provided below. If in doubt call an electrician.
Always make sure the power is disconnected from all possible sources before making any connections. Your description of the problem indicates that there may be multiple power wires coming into the same box. In that case local codes may require that the box be partitioned to prevent exposure to voltages up to 220 volts.
You need to determine where each wire goes to know how to connect them together. You cannot rely on color alone. If the power supply runs through the box to the loads then most (but probably not all) of the white wires will be connected together. If the power runs to the load boxes first then none of the white wires in the switch box should be connected together. They are used to run the switched/dimmed power back to the loads (and should be taped to cover the white in the box). In that case each switch has its own power input and they should not be tied together. A wire (could be black or white with black tape) brings power from the load box, gets connected to the input terminal of the switch and the corresponding black wire carries the switched power back to the load. The fan/light switch will have one power in and a switched power out for the fan and another for the light. The 3-way will have one "power" in (or it could be the final power out to the light) and two "carrier wires that connect to the other 3-way switch. If the power supply goes through the switch box then there will be at least 10 wires in that box. In that case see the attached diagram: a5fa64a.gif
Posted on Sep 23, 2009
  • 12104 Answers
SOURCE: I need to wire a 3 gang switches in a 3 gang box
before u start make sure power is off before working with electrical lines ---start with the 12/2 coming into box black [power] white [ground-neutral] and u will have 3 separate lines for the lights so u will have 4 lines total coming in the box== with the 3 light lines take the white and strip back the plastic and connect [wire nut] all 3 to the 12/2 white line --now take the 12/2 black line and connect it to the first switch gold color screw- bottom screw -now take some wire about 2-3 inch strip both ends and connect from the 12/2 black wire connection on the switch and connect to the gold /bottom of switch 2 than do the same for switch 3 connecting the wire from switch 2 so u will have power feeding all 3 switches-- now connect the black lines for the lights to the other side of each switch and ur done
Posted on Feb 14, 2010
Lights not working @ top of stairs
Pull the covers off the switch boxes and remove the switches but don't disconnect them. Look to see how many wires are connected to each switch. A two way switch should have 3 insulated wires connect to each switch AND a bare copper wire for ground. If you don't have that configuration, then it was not built correctly.
Jun 28, 2015 | Home
Our electrician left all the dip switches in the same position for three fans. So now if someone turns on a light downstairs the light goes on upstairs. All we have is a remote, no wall switch from Minka....
Why not give your electrician a chance to do the job right but from your description I beleieve your electrician is confused between wired and remote control operation
Apr 11, 2013 | Minka Aire Ceiling Fan
I am replacing existing three way switches to a bathroom light should both be wired the same? ive got one white wire one red and one black on each i hooked the red ont top with the white underneath ...
Look at screw color.
Dark screw on old 3-way and new 3-way is for 'common' wire.
Other two screws are brass.
Move dark-screw wire to new dark screw.
Move brass-screw wires to either new brass screw.
http://waterheatertimer.org/images/3-way-circuit-500.jpg
Jun 20, 2011 | Electrical Supplies
Need wiring for 4 light with 4(2 way switch) when on 1 switch 1 and 2 light will on when on 2 switch 1 light will off 2 and 3 light will on when on 3 switch 2 will off 3 and 4 light will on when 4 on...
i don't know about 2way switches but a three way switch that will turn a light on at both ends of a hall or off is power to one switch ,three wire between switch switch leg from other switch , make up is tie neutrals together grounds together leaving a black and red from tree wire (travelers)and a black at the switch leg (power)
Sep 24, 2010 | Home Fencing
My lutron switch turns on the upstairs light- but only if the upstairs switch is in the on position How do I wire the downstairs switch correctly
try this http://www.electrical-online.com/3waydiagram.htm you do need two three way switches and 3 conductor wire running between the switches Caution high voltage enough to stop your heart and or burn you turn off the power first
Good luck
Oct 09, 2009 | Electrical Supplies
I took a three gang face plate of now this switch is number 1 witch operates the hall number two switch operates the sitting room. number three operates the third light in the same room. but number three...
You need to determine where the power is coming into the box. That power line needs to be jumpered to each switch. The black of the lights will go to the other side of each switch. All neutral wires are tied together.
Bob Janelli
Oct 01, 2009 | Cooper Wiring Devices 3-gang Cooper Wall...
Replace two way light switch
It sounds like you have what is called a three way switch for the upstairs light. This means that the light is controlled in two locations. The extra wire you refer to as a loop is called the traveller it goes between the two locations. You need to use the proper type of switch for 3 way applications. Once you get that there will be three holes instead of 2. the traveller usually installs in the hole that is alone (usually 2 holes on the bottom and one on the top). Any 3 way switch will come with instructions, or you should be able to find diagram easily on line.
Dec 24, 2008 | Electrical Supplies
Electrical Supplies Logo
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
